jimgraham42(at)mac.com Guest
Posted: Thu Jan 02, 2014 7:16 pm Post subject: Rotax 5 Year Replacement of Hoses etc |
There's a periodic (5 year interval) hose and rubber parts replacement requirement for the 912ULS... Can anyone on the list provide your experience regarding the likely cost of that maintenance... i.e., typical # of hours to accomplish in a Rotax shop, and rough cost of the component parts (using authorized Rotax parts)?
Jim Graham
NOVA Light Flight--KHWY
Tecnam Sierra N25HV
Roger Lee
Posted: Sat Jan 04, 2014 9:43 pm Post subject: Re: Rotax 5 Year Replacement of Hoses etc |
Hi Jim,
I do about 20 hose changes a year. Your parts cost will be around $1000-$1200 for parts if you do it right. Depending on the shop and the plane type the total could cost with labor could cost any where from $2000-$4000. You can buy some things locally and will be the same as what you will buy from a Rotax distributor because they don't use Rotax parts for some things. Rotax doesn't supply everything. Time depends on the plane. it could be anywhere from a 1-2 days. All fuel and oil lines should be in fire sleeve. You should not use cheap serrated worm drive clamps like you use on a garden hose for fuel hoses. Use either Oetiker clamps or fuel injection clamps. These are both types of good sealing band clamps. The fire sleeve should have Band-It clamps, but an Oetiker band clamp will work. Don't use crap parts. Blow out each fuel line with air before the install. Throwing this together with parts from an hardware store and baling wire isn't the right way. It's your hide and your passengers hide that are on the line. If you do things the wrong way and try to cut too many corners and cause engine damage or an off field landing may cost you really big bucks for cutting those corners.
_________________ Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056 |
frank3 Guest
Posted: Sun Jan 05, 2014 7:49 am Post subject: Re: Rotax 5 Year Replacement of Hoses etc |
Roger
What style(s) of Oetiker clamps do you use and on which hoses?
Roger Lee
Posted: Sun Jan 05, 2014 8:33 am Post subject: Re: Rotax 5 Year Replacement of Hoses etc |
Oetiker one ear clamps.
I have done a few Tecnams. They are fairly easy.
Here is an article that will help.
The Task at Hand.docx |
648.68 KB |
1005 Time(s) |
Tucson, Az.
Cell 520-349-7056 |
SierraSam
Joined: 05 Jan 2014 Posts: 1 Location: Fairfax Station, VA
Posted: Sun Jan 05, 2014 8:32 pm Post subject: Rotax 5 Year Replacement of Hoses etc |
Roger, thanks for your cost summary, plus the good quality reminders. Maintenance-wise and quality-wise, we have always been committed not to cut corners, so this periodic hose replacement will be a costly implementation of that principle--but that's the reason we're planning for it now, just a bit ahead of time--to be sure we can cover the costs when we have them. Appreciate your assistance.
Jim Graham
_________________ Jim Graham |
