Mystery electronic box
jdubner
PostPosted: Thu Dec 26, 2013 1:18 pm    Post subject: Mystery electronic box Reply with quote
Can anyone identify the box in the two accompanying photos? There are four
relays, more than a dozen silicon diodes, and a power resistor. I can hazard a
guess or two but would like to hear from someone who recognizes the box and
knows what it is.
My neighbor cut it out of a Speed Canard he's rebuilding. The operative words
are "cut out"; I do not know to what it was connected.
Joe
Independence, OR
 Filesize:  433.05 KB
 Viewed:  5629 Time(s)
 Filesize:  435.09 KB
Independence, OR
JOHN TIPTON
PostPosted: Thu Dec 26, 2013 2:21 pm    Post subject: Mystery electronic box Reply with quote
What have gone an done !!!
----x--O--x----
relays, more than a dozen silicon diodes, and a power resistor. I can hazard a guess or two but would like to hear from someone who recognizes the box and knows what it is.
Joe
Independence, OR
<Mystery Box 1.jpg>
<Mystery Box 2.jpg>
Eric M. Jones
PostPosted: Thu Dec 26, 2013 2:49 pm    Post subject: Re: Mystery electronic box Reply with quote
It's a relay box.
Did I win? What's the prize?
Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net
ceengland7(at)gmail.com
PostPosted: Thu Dec 26, 2013 4:19 pm    Post subject: Mystery electronic box Reply with quote
four
operative words
Don't recognize the box, but the 1st thing that comes to mind would be a
selective controller (and high current protection for switches) for trim
functions. There are commercial products that allow 2 sets of trim
switches, and can give '1st push' priority for control, or
pilot-priority for control.
Charlie
sprocket(at)vx-aviation.c
PostPosted: Thu Dec 26, 2013 5:34 pm    Post subject: Mystery electronic box Reply with quote
It's a 2-channel relay deck. One pair is used for (pitch?) trim (labeled on
wire). The second may be for speed brakes or nose gear... not sure.
The power resistor may be used to limit stall current (landing gear) or the
speed of the trim motor.
This is a guess, but the wiring shows one wire set as 'trim'.
Vern
PostPosted: Thu Dec 26, 2013 6:20 pm    Post subject: Mystery electronic box Reply with quote
At 07:35 PM 12/26/2013, you wrote:
<sprocket(at)vx-aviation.com>
(labeled on wire). The second may be for speed brakes or nose
gear... not sure.
or the speed of the trim motor.
Vern
That's my guess too . . .
jdubner
PostPosted: Thu Dec 26, 2013 7:50 pm    Post subject: Mystery electronic box Reply with quote
Charlie England wrote, On 12/26/2013 16:18:
Vern Little wrote, On 12/26/2013 17:35:
> (labeled on wire). The second may be for speed brakes or nose gear...
> not sure.
Robert L. Nuckolls, III wrote, On 12/26/2013 18:19:
Eric M. Jones wrote, On 12/26/2013 14:49:
> It's a relay box.
I think you're all correct. A relay deck/trim controller makes sense especially
in light of the Speed Canard having electric trim switches on both sticks. Good
job -- apparently this was easy (for everyone except me Smile
Alas, there is no prize but I will have the satisfaction of telling my neighbor
he needs to repair the cut wires and re-install it <g>.
Thank you all.
Joe
Independence, OR
