Landing light LEDs - questions about Heat Sink and Flasher
rparigoris
PostPosted: Tue Dec 17, 2013 8:19 am    Post subject: Landing light LEDs - questions about Heat Sink and Flasher Reply with quote
Hi Sacha
Just keep in mind that the D2 is 10 watts, a little less than Kuntzelmans. I didn't think the Kuntzleman was a great landing light, probably OK for taxi. Kuntzelman is 12 degree and D2 can be 10 though. I Another thing to consider is if the D2 makes any sort of undesirable noise.
Ron Parigoris
saw some > pretty > slick LEDs from Denali.: > > www.TwistedThrottle.com > > The DX is the largest, 10 watts per LED and 10 degree angle and has dual > intensity, 3" square 3.75" long > > The D2, kinda slick, it comes with two lenses a 10 degree and 25 degree 10 > watts per LED, 2" square and 2.4" long, dual intensity > > Thanks Ron for the info and for your kind offer; the D2 (it's actually > round > not square) is a good size for me, probably easier to mount and cheaper > than > the Kuntzelmans; I'm actually tempted to get two; one with a 10 deg lense > and one with a 25 deg. > Sacha > > [quote][b]
