Arthur.Treff(at)smartm.co Guest
Posted: Thu Jun 22, 2006 9:29 am Post subject: Farraday cage for power distribution? |
I've got a wire routing question for the list.
Three connections are on the battery side of the starter solenoid on the
firewall:
1) 2AWG from the battery solenoid in the rear of the aircraft.
2) 4AWG from the primary alternator output.
3) 2AWG going aft to power the fuse blocks located behind the instrument
panel.
The whole ship has been wired, fuse blocks, single point ground, battery
cable, etc. I need to run the fuse block supply (#3 above) and the best
route to the fuse blocks behind the instrument panel will put the supply
cable right behind the avionics stack, running parallel to the rear of
the radio trays, specifically the Garmin 430. Is this OK? Would it be
OK if I constructed some sort of Farraday shield out of copper pipe and
a ground wire? I did a google search and searched the Matronics
archives, but can't see if anyone's covered this. Thanks for your help.
Art Treff
Asheville, NC
N666AT RV-8
rv8ch
Posted: Thu Jun 22, 2006 10:33 am Post subject: Farraday cage for power distribution? |
| Quote: | Three connections are on the battery side of the starter solenoid on the
firewall:
panel.
Wow - that's a lot of umpf for the fuse block. I think I'm using maybe
AWG#10 for my fuse blocks.
| Quote: | The whole ship has been wired, fuse blocks, single point ground, battery
I don't recall reading anything in Bob's book that indicates that
this would be a problem. Hopefully some of the gurus will chime in.
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
_________________ Mickey Coggins
http://www.rv8.ch/ |
nuckollsr(at)cox.net Guest
Posted: Thu Jun 22, 2006 5:33 pm Post subject: Farraday cage for power distribution? |
At 10:25 AM 6/22/2006 -0700, you wrote:
<Arthur.Treff(at)smartm.com>
firewall:
plenty big . . .
| Quote: | 2) 4AWG from the primary alternator output.
plenty big too . . .
| Quote: | 3) 2AWG going aft to power the fuse blocks located behind the instrument
panel.
A bit too much. Consider that full load on the fuse block
will not exceed rating of alternator and is generally limited
by design to something on the order of 75 to 80 percent of
rating. If you have a 40A alternator, #8 is good, a 60A alternator
would prompt a #6 bus feeder.
Beats me. Many a high current, fat wire has been run along side
potential victims with no observable effects . . .but then
there are fat wires that DO couple alternator noise into
vulnerable wires when given the opportunity.
The rule of thumb is not to have fat power wires and
small signal wires share spaces. There's no guarantee
that it's necessary but I prefer to eliminate the
possibility of problems by observing the rules.
| Quote: | Would it be
Why not drop the feeder to 6 or 8 awg and re route it? Save
weight and hassles to boot while eliminating the potential
for problems by design.
sportav8r(at)aol.com Guest
Posted: Thu Jun 22, 2006 6:00 pm Post subject: Farraday cage for power distribution? |
Each of those avionics boxes you are worried about is inside its own Farraday cage (called a chassis), so I don't think it's an issue, really.
-Bill B
