jag0000
Posted: Mon Dec 09, 2013 8:49 am Post subject: Europa XS Tri Gear Salvage |
Europa XS badly damaged from off airport landing... perfect for someone who would like to finsih build quickly...approx. 650 hrs TT..have just about everything needed to finish except 914 turbo is sold....
Inventory:
Airmaster prop controller
Vacuum pump (1 year old)
Radiator
Regulator (150 hours)
Airspeed indicator
Turn and bank, slip indicator
Tru track 2 axis
Vacuum gauge
DG Compass heading
Artificial horizon
Altimeter
Vertical Speed indicator
VOR nav
Fuel gauge
Turbo indicator warning lights
Rocky Mountain engine monitor, rpm, hours, Hobbs, manifold pressure
Air box differential
Engine cylinder temp 2 heads sensor
Oil temp gauge
Oil pressure
ICOM flip flop radio
Terra VOR nav
Air master prop controller (upgraded 3 years ago)
Elec flaps switch n motor
Elec. trim horizontal stabilizer
Terra nav com with markers lights n audio
Becker transponder (2 years old)
Garmin 296
Instruments lights
Map light
Nav light and strobe switches (one nav light damaged in transporting)
Rear Whelen strobe light
Finger brakes
Parking brake
Wings were not damaged in accident but have major dings from transportation. Nose gear is broken but main gear are fine.
See photos for instrument details...
Please email me directly at jag0000(at)gmail.com
271.39 KB |
2783 Time(s) |
81.33 KB |
2783 Time(s) |
