Firefly2013
Posted: Sun Nov 24, 2013 11:51 am Post subject: Thinking about buying a Firefly? |
I was wondering if a firefly with a 447 engine plus parachute and 5 gallons of fuel will fly a pilot that is around 225lbs. I would be taking off at a elevation of around 80ft, airport in New Jersey.
Also which prop would be best for me, a 2 blade wood prop or a 3 blade powerfin?
rvsimons
Posted: Sun Nov 24, 2013 1:26 pm Post subject: Thinking about buying a Firefly? |
The firefly will haul up aloft. You might find the plane a bit of a little tight fit for a guy your size but height seems a bigger issue than weight. I am 210 5'10 and was comfortable in the firefly I sat in.
Personally I perfer a three blade over a two blade anyday. They say a two blade will give you better climb performance. I had a three blade GSC prop on a Phantom and switched to a two blade to achieve better climb performance. I was sorely disappointed. Although it did climb better vibration was more apparent and the climb performance was not worth what i gave up in smoother operation. I went back to the three blade. I would recommend a three blade Warp Drive over the Powerfin if you can find one. Its the best prop I've ever ran. I have a Powerfin on a Phantom now and there is blade movement inside the hub with everything tourqued down to specs. I'm going to replace it with a Warp Drive once I run this engine out. On Nov 24, 2013 11:55 AM, "Firefly2013" <jschepis(at)comcast.net (jschepis(at)comcast.net)> wrote:[quote] --> RotaxEngines-List message posted by: "Firefly2013" <jschepis(at)comcast.net (jschepis(at)comcast.net)>
http://forums.matronics.com/viewtopic.php?p=413940#413940
="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
et="_blank">www.mypilotstore.com
"_blank">www.mrrace.com
le, List Admin.
-List" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
_________________ Vance Simons
Post Falls, Idaho
Zenith 701 |
BARRY CHECK 6
Posted: Sun Nov 24, 2013 5:10 pm Post subject: Thinking about buying a Firefly? |
Vance:
If you consider what you, are expected from a 3 blade Vs 2 blade... Then
YES - You will be disappointed.
The advantage of a 3 blade are:
Lower Tip Speed at the same RPM
Less noise
Better Vertical Speed (VSI)
More Ground clearance
Easier to do static prop balance.
Easier to do dynamic prop balancing
The advantages of a 2 blade are:
Higher IAS
Disadvantages of a 3 Blade:
Lower IAS.
A bit scary to Hand Prop.
In the winter you collect (more) snow & ice in the spinner.
When you ding a prop you usually ding 2 or more blades of the prop.
Doing R&R of the cowling is a bit more tricky.
Even though your logic was not correct the main thing is you are happy with
the prop you chosen.
*Barry*
*“Chop’d Liver”*
NJ has taken the next step. They are identifying cars with bad drivers.
You will notice some cars with a large red "R" on them. That is to
identify the drivers as "R"estricted. Restricted is just a polite way of
saying Bad Drivers. Be cautious around them.
On Sun, Nov 24, 2013 at 4:25 PM, Vance Simons <vancesimons(at)gmail.com> wrote:
[quote] The firefly will haul up aloft. You might find the plane a bit of a little
Firefly2013
Posted: Mon Nov 25, 2013 7:44 am Post subject: Re: Thinking about buying a Firefly? |
[quote="rvsimons"]The firefly will haul up aloft. You might find the plane a bit of a little tight fit for a guy your size but height seems a bigger issue than weight. I am 210 5'10 and was comfortable in the firefly I sat in.
Personally I perfer a three blade over a two blade anyday. They say a two blade will give you better climb performance. I had a three blade GSC prop on a Phantom and switched to a two blade to achieve better climb performance. I was sorely disappointed. Although it did climb better vibration was more apparent and the climb performance was not worth what i gave up in smoother operation.� I went back to the three blade. I would recommend a three blade Warp Drive over the Powerfin if you can find one. Its the best prop I've ever ran. I have a Powerfin on a Phantom now and there is blade movement inside the hub with everything tourqued down to specs. I'm going to replace it with a Warp Drive once I run this engine out. On Nov 24, 2013 11:55 AM, "Firefly2013" <jschepis> wrote:[quote] --> RotaxEngines-List message posted by: "Firefly2013" <jschepis>
Thanks Rvsimons, I'm 5' 10" so I guess it would be ok for me. I was looking to buy a firefly I saw forsale, but I think I am going to wait and get sport pilot licence as that would give me more choices. I want to fly something with a 4 stroke, that I can trailer to avoid paying hanger fee's in case I don't have time for flying allot, I don't want to be stuck paying for things I'm not using.
The phantom is the plane that I would really want, they look like a well constructed ultralight. I believe I read you have to inspect those wire's good to make sure the tangs or whatever they are called do not become elongated. How do you like the Phantom? It would be my first choice except for the need for a hanger.
I think a firestar with a rotax 912 or someother 4 stroke would work for me because I could keep it trialered in my yard and hook it up when I want to go flying? And hopefully sell it if I get bored with it.
Firefly2013
Posted: Mon Nov 25, 2013 7:54 am Post subject: Re: Thinking about buying a Firefly? |
The "R" on New Jersey Licence plates is showing support the Rutgers University Scarlet Knights.
Also the big Red "R" any where on the vehicle are for the College.
http://www.alumni.rutgers.edu/s/896/2col.aspx?sid=896&pgid=349
https://www.govtrack.us/states/nj/bills/2012-2013/s753
Thanks for the info
[quote="BARRY CHECK 6"]Vance:
Less noise
Higher IAS
Lower IAS.
*Barry*
*�Chop�d Liver�*
On Sun, Nov 24, 2013 at 4:25 PM, Vance Simons <vancesimons> wrote:
| Quote: | The firefly will haul up aloft. You might find the plane a bit of a little
tight fit for a guy your size but height seems a bigger issue than weight |
henry.voris
Joined: 02 Mar 2007 Posts: 116 Location: Pueo Field, Kula, Maui
Posted: Mon Nov 25, 2013 6:04 pm Post subject: Re: Thinking about buying a Firefly? |
Firefly 2013...
I drive a Firefly powered by a thundering 447. But at 155 lb. and at 3,800 ft. our mileage will vary...
You may want to try you question on the Kolb List...
Aloha,
_________________ Henry
Firefly Five-Charlie-Bravo
Do Not Archive |
