jaybannist(at)cs.com Guest
Posted: Sat Nov 23, 2013 7:45 am Post subject: Ignition switch |
Hey Bob,
My friend is building a Zodiac 601XLB with a Jabiru 3300 engine. He is using the Bendix-type,
5-position mag switch. Since the Jabiru does not have an impulse coupled mag, the jumper
between the switch terminals “R” and the adjacent “GND” were not connected. Engine running,
with the switch wired as you recommended, the engine would quit when “R” was selected.
This made absolutely no sense to me.
At wits end, I asked for and you sent me a diagram showing the switch internal connections.
However I have to conclude that the diagram is wrong.
Let's call the center ground Terminal "GND C" and the other one Ground R "GND R".
"GND C" is grounded at the engine through the shields, a "true" ground.
A jumper connects terminal "R" and "GND R", not a true ground.
When the switch is in the first Start position the "R" terminal is open, making the right mag hot.
When the switch is turned to Start, cranking position, "GND C" is connected to "GND R".
Since "GND R" and "R" are connected, the "R" terminal is now grounded, killing the Right Mag.
That simply can't be right; or I am reading the diagram wrong.
I had one of those “what if we do this?” moments and put a jumper between “R” and “GND R”.
Contrary to all logic, that made everything work as it should.
What am I missing?
Posted: Sat Nov 23, 2013 9:26 am Post subject: Ignition switch |
At 09:43 AM 11/23/2013, you wrote:
Hey Bob,
between the switch terminals R and the adjacent GND were not
R was selected.
Ground R "GND R".
I had one of those "what if we do this?" moments and put a jumper
between R and GND R.
What am I missing?
The diagram in for the OFF-L-R-BOTH-START key switch
in Z-27 and elsewhere is for the Gerdes/ACS A510-2
switch. What's the part number/brand on the switch
you have? I'm unaware of any variations on a theme
for these switches but they've been manufactured
for many decades.
If things are working as you wish, then it's
hard to argue with success . . . even when the
details for that success are not undnerstood.
If you do have some variant switch, I wouldn't
mind seeing it and getting the data off it. Is
it a legacy 510-1?
Posted: Sun Nov 24, 2013 9:38 am Post subject: Ignition switch |
Bob,
That switch I asked you about is ACS Products Co., A-510-2 Ignition Switch.
Jay
Posted: Sun Nov 24, 2013 9:56 am Post subject: Ignition switch |
At 11:37 AM 11/24/2013, you wrote:
| Quote: | Bob,
Jay
Interesting. I wonder what the -2 means.
Does anyone on the List have an ACS510-2
keyswitch on hand that is not installed?
I'd sure like to put my hands on it to
see if my published data needs to be
updated.
Bob . . . [quote][b]
fvalarm(at)rapidnet.net Guest
Posted: Mon Nov 25, 2013 8:52 am Post subject: Ignition switch |
Hi Bob,
According to ACS, -2 means it has a starter position. -5 means no starter position.
I cannot find any listings for 510 without the dash number.
see
http://www.aircraftspruce.com/catalog/elpages/igswitches.php?clickkey=5735
Bevan
Sent: Sunday, November 24, 2013 9:56 AM
Subject: Re: AeroElectric-List: Ignition switch
| Quote: | Bob,
Jay
updated.
Bob . . . [quote]
href="http://www.aeroelectric.com">www.aeroelectric.com
href="http://www.buildersbooks.com">www.buildersbooks.com
href="http://www.homebuilthelp.com">www.homebuilthelp.com
href="http://www.mypilotstore.com">www.mypilotstore.com
href="http://www.mrrace.com">www.mrrace.com
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-List
FatBoy
Joined: 21 Oct 2012 Posts: 19 Location: Nashville, TN
Posted: Mon Nov 25, 2013 9:05 am Post subject: Ignition switch |
Bob -- I have one mounted in the panel, but not wired. I'd rather not ship it, as I'll need it here this week to do some wiring, but is there something I can test for you here in my shop?
On Nov 25, 2013, at 10:52 AM, B Tomm wrote:
[quote] Hi Bob,
see
Bevan
From: owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com) [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert L. Nuckolls, III
Subject: Re: Ignition switch
| Quote: | Bob,
Jay
updated.
Posted: Mon Nov 25, 2013 9:48 am Post subject: Ignition switch |
At 11:05 AM 11/25/2013, you wrote:
| Quote: | | Bob -- I have one mounted in the panel, but not wired. I'd rather not ship it, as I'll need it here this week to do some wiring, but is there something I can test for you here in my shop? |
Absolutely. Can you confirm the validity of this
figure intended to describe operation of this switch?
[img]cid:7.1.0.9.0.20131125114653.04e23860(at)aeroelectric.com.0[/img]
Thanks!
69.4 KB |
9547 Time(s) |
