Fiberglass Nose Wheel Boot
galinhdz(at)gmail.com
PostPosted: Fri Nov 22, 2013 3:49 am    Post subject: Fiberglass Nose Wheel Boot Reply with quote
Does anyone know where I can get a fiberglass nose wheel boot? It is the kind that is cut in half like the one in the attached photos.
 Filesize:  469.2 KB
 Viewed:  1716 Time(s)
 Filesize:  513.09 KB
bakerocb
PostPosted: Fri Nov 22, 2013 6:45 am    Post subject: Fiberglass Nose Wheel Boot Reply with quote
11/22/2013
Hello Galin, Attached are two pictures of my KIS TR-1 nose wheel pant. I put it together from a nose wheel pant from Van’s and shaft fairing from Glastar.
OC
Sent: Friday, November 22, 2013 6:47 AM
Subject: Fiberglass Nose Wheel Boot
 Filesize:  735.31 KB
 Viewed:  1714 Time(s)
 Filesize:  720.25 KB
ftyoder(at)yoderbuilt.com
PostPosted: Fri Nov 22, 2013 7:08 am    Post subject: Fiberglass Nose Wheel Boot Reply with quote
Hi Galin,
Aircraft Spruce has similar ones. You might want to change to a more aerodynamic one. For a little more speed. I think Cirrus and Vans have better shaped ones.
Tom
From: owner-kis-list-server(at)matronics.com [mailto:owner-kis-list-server(at)matronics.com] On Behalf Of Galin Hernandez
Sent: Friday, November 22, 2013 4:48 AM
To: kis-list(at)matronics.com
