by0ung(at)brigham.net Guest
Posted: Sat Jan 14, 2006 11:10 am Post subject: cotter pins |
I like the nylon lock nuts vs the drilled
with cotter pins. One reason is climbing in and out of the airplane the
cotter pins will get caught on clothing and human flesh [Shocked]
If you are careful to bend the ends of the cotter pins so that the ends fit
nicely into the recesses of the castellated nuts. it will not grab clothing
or flesh.
Boyd
