f.kyle(at)sympatico.ca Guest
Posted: Wed Nov 20, 2013 6:43 am Post subject: unusable fuel |
Cheers,
I will shortly be fussing about W&B, or CofG if you wish, and note the need to load unavailable tank fuel to the fuselage for measurement.
Can anyone produce the figure in use by (a) the authority, (b) the kit maker, (c) the fuel guru or (d) a wild stab? I hesitate to admit the tank is a 1997 unit.....
I don’t relish all this at minus 5 Celcius but have to look busy at something.
Fair winds,
Ferg C-FFGG
Posted: Wed Nov 20, 2013 8:24 am Post subject: unusable fuel |
Ferg, Ideally you measure it yourself. Put say 15 litres
in the tank (which will run into both sides) and then
with the plane in a flying attitude (ie sill about level)
run a fuel pump with the fuel pipe disconnected and
draining into a measuring cylinder. What you have left is
the bit you are looking for and you either just weigh the
plane without bothering to learn exactly how much it is,
and/or subtract what came out into your measuring cylinder
from what you put in the tank.
All the best, David Joyce, G-XSDJ
On Wed, 20 Nov 2013 09:42:32 -0500
<f.kyle(at)sympatico.ca> wrote:
| Quote: | Cheers,
if you wish, and
a 1997 unit.....
I don't relish all this at minus 5 Celcius
at something.
Fair winds,
Ferg C-FFGG
peterz(at)zutrasoft.com Guest
Posted: Wed Nov 20, 2013 9:12 am Post subject: unusable fuel |
shouldn't it be done at max climb angle?
Cheers,
Pete
A239
On Wed, Nov 20, 2013 at 11:23 AM, David Joyce <davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk)> wrote:
[quote]--> Europa-List message posted by: "David Joyce" <davidjoyce(at)doctors.org.uk (davidjoyce(at)doctors.org.uk)>
Ferg, Ideally you measure it yourself. Put say 15 litres in the tank (which will run into both sides) and then with the plane in a flying attitude (ie sill about level) run a fuel pump with the fuel pipe disconnected and draining into a measuring cylinder. What you have left is the bit you are looking for and you either just weigh the plane without bothering to learn exactly how much it is, and/or subtract what came out into your measuring cylinder from what you put in the tank.
<f.kyle(at)sympatico.ca (f.kyle(at)sympatico.ca)> wrote:
| Quote: | Cheers,
a 1997 unit.....
I don't relish all this at minus 5 Celcius but have to look busy
at something.
Fair winds,
Ferg C-FFGG
om" target="_blank">www.aeroelectric.com
ooks.com" target="_blank">www.buildersbooks.com
et="_blank">www.homebuilthelp.com
et="_blank">www.mypilotstore.com
"_blank">www.mrrace.com
le, List Admin.
target="_blank">http://www.matronics.com/Navigator?Europa-List
http://forums.matronics.com
Posted: Wed Nov 20, 2013 9:38 am Post subject: unusable fuel |
Peter
, You could make an argument for that, but I would guess
most pilots running low on fuel will be flying level in
the hope of getting to somewhere landable, and on top of
that it seems a pity to add unnecessarily to your ready
for service weight if you are going to have your max
allowed pay load reduced by the same amount.
Regards, David
On Wed, 20 Nov 2013 12:11:30 -0500
Peter Zutrauen <peterz(at)zutrasoft.com> wrote:
| Quote: | shouldn't it be done at max climb angle?
Cheers,
Pete
A239
>in the tank
>in a flying
>fuel pipe
>the plane without
>tank.
>> Cheers,
>>if you wish, and
>>fuselage for
>> measurement.
>>to admit the tank
>> is
>> a 1997 unit.....
>>but have to look
>> busy
>> at something.
>> Fair winds,
>> Ferg C-FFGG
Posted: Thu Nov 21, 2013 7:27 am Post subject: unusable fuel |
Good day,
My thanks to David, Christoph and Bob for the advice on the topic above. I appreciate the time taken to reply with useful info - and it confirms my suspicions that I have to extricate C-FFGG from the hangar in the cold, slope it into the angle required to simulate the moment my engine quits, and divine the fuel left in both tanks.
I don’t know if there’s enough time between rain/snow showers to accomplish this, but it must be done. My fellow hangarites will be thrilled.
Again many thanks
Ferg
P.S: Congrats to Christoph, now well past his mandatory 25 hours. He can’t possibly challenge me for longest build now.
