tomvelvick
Posted: Tue Jun 20, 2006 6:31 am Post subject: Aluminum bus bar |
Hi Bob,
I am relocating and rewiring the switches/circuit breakers in my wifes plane. I found that the switch breakers in the panel were all connected to power with a .025 1/2 by 6 inch aluminum bus bar. I have never seen anyone use a thin piece of aluminum before. It seems woefully inadequate to me. Just wondering how bad an installation this was and what would have happened if all of the switches were on together for a long time. Since we dont do much night flying, most of the switches are normally off.
Tom Velvick
nuckollsr(at)cox.net Guest
Posted: Tue Jun 20, 2006 7:27 am Post subject: Aluminum bus bar |
At 10:26 AM 6/20/2006 -0400, you wrote:
Hi Bob,
normally off.
It's been done many times. Not recommended but I'm also
not aware of any cases where use of aluminum versus brass
or copper was the cause of any problem. Getting a gas-tight
connection at the fasteners is the key irrespective of what
materials are used.
If you have an opportunity to swap out for brass, it wouldn't
be a bad thing to do . . .
< with experiment. >
< --Lawrence M. Krauss >
