Switch S700 2-11
Mike M
PostPosted: Fri Nov 15, 2013 8:42 am    Post subject: Switch S700 2-11 Reply with quote
Bob,
I am looking for a switch that has three potions (Off/On/On). B&C has a switch S700 2-11 which is shown as On/On/Off but does not have a diagram which shows how this switch is wired. Can you provide a schematic of this switch?
Mike Marker
Mike Marker
PostPosted: Fri Nov 15, 2013 12:43 pm    Post subject: Switch S700 2-11 Reply with quote
At 10:42 AM 11/15/2013, you wrote:
Bob,
What are you trying to do? You can wire an on-on-on
to be off/on/on by simply leaving one terminal
unused.
Mike M
PostPosted: Fri Nov 15, 2013 1:08 pm    Post subject: Re: Switch S700 2-11 Reply with quote
Bob,
I want to wire my electronic ignition switch such that to can select the Main or Aux battery bus (Off/Aux Bus/Main Bus). The drawing depicts what I'm thinking. I'm not sure that the S700 2-11 is internally wired as depicted...that is why I asked for clarification on the switch configuration.
I also want to use this switch for a pulsed landing light (Off/On Steady/Pulsed)
Mike Marker
 Filesize:  26.71 KB
 Viewed:  7389 Time(s)
Mike Marker
PostPosted: Fri Nov 15, 2013 8:03 pm    Post subject: Switch S700 2-11 Reply with quote
At 03:08 PM 11/15/2013, you wrote:
--> AeroElectric-List message posted by: "Mike M" <mjwings(at)msn.com>
Bob,
The S700-2-10 switch can be wired for single
pole three postion as shown below . . . just leave
the lower throw terminal (3)unhooked and you
get the desired behavior.
[img]cid:7.1.0.9.0.20131115220031.02131cb0(at)aeroelectric.com.0[/img]
 Filesize:  33.87 KB
 Viewed:  7375 Time(s)
Mike M
PostPosted: Sat Nov 16, 2013 7:37 am    Post subject: Re: Switch S700 2-11 Reply with quote
Thanks Bob! I made several failed attempts to figure out how to wire the S700 2-10 switch to perform desired function...but you drawing makes it obvious. So I'll be using the 2-10.
Mike Marker
Mike Marker
PostPosted: Sat Nov 16, 2013 7:53 am    Post subject: Switch S700 2-11 Reply with quote
The 2-11 nomenclature is not carried over from
the mil-specs like the other dash numbers. I think
B&C added this callout to describe one of the
variants of the 2-10 . . . which are fundamentally
unnecessary since the 2-10 can be wired to accomplish
the same tasks.
