Filter Boards
PostPosted: Sat Dec 21, 2013 4:01 pm    Post subject: Filter Boards Reply with quote
As I have explained to Lew, there are filters boards
available at no cost which MAY prove quite useful
in reducing LED fixture noises to acceptable
levels. But there are strings attached. I'd
like to demonstrate that the boards do the
job . . . an experiment that cannot be conducted
without first identifying a problem noise source
At 09:28 AM 12/20/2013, you wrote:
Hi Bob. Lew Jennings here in the Palm Springs/Thermal, CA area
building a Glasair II with my A&P/IA son. Looking at changing over
from standard landing light to LED as mentioned on the Matronics
list. Do you still have a filter board available you mentioned this
morning that I can purchase? Thanks! -LewSent from Yahoo! Mail for iPad
Have you identified a noise issue?
I'm cautious about how many of these
things I give away and under what circumstances.
They're easy to ADD to an existing light
assembly. I would rather than they NOT
be installed until the builder first
demonstrates a noise issue . . . and then
does the experiment to see if the problem
is solved by adding a filter.
It's way too easy for everybody to assume that
because the filter exists and one experiment
was useful that the thing should become standard
equipment on every future installation.
That's how the avionics master switch came
into being and plowed a very deep furrow
in the psyche of folks who deal with
airplanes.
The filters are free but let's do an ordered
set of experiments to see which devices need
it and how effective it is on an experiment-
by-experiment basis.
