Storing wings
pdelano(at)telus.net
PostPosted: Sat Nov 09, 2013 9:01 am    Post subject: Storing wings Reply with quote
The bottom side of right is riveted and the top just clecoed ready for pre close inspection. Rather than put temporary rivets before storing it, I plan to plastic wrap it with a roll of industrial plastic wrap, remove the clecos an set the wing on a shelf. One it retrieves clecos to build other wing, prevents damage to wing by disturbing clecos, one does not have to use up rivets for temp install or drill them out later. I would like hear if anybody else has done this. Considered just leaving the ratchet straps on.
Sent wirelessly from my BlackBerry device on the Bell network.
Envoyé sans fil par mon terminal mobile BlackBerry sur le réseau de Bell.
