PGLong
Posted: Wed Jun 21, 2006 5:59 pm Post subject: Audio input to video camera |
Looking for a small microphone to put in my headset earphone cup to pickup
the audio for my video camera aux microphone input. Or, would it work to use
the rear seat headset jack ear phone portion for the audio to directly input to
the camera? Would there be an impedance matching problem? Anyone done this
that could guide me thru the process?
Thanks, Pat
Pat Long
PGLong(at)aol.com
N120PL
RV4
Bay City, Michigan
3CM
_________________ Pat Long
RV-4, N120PL
Bay City, MI |
Tim(at)MyRV10.com Guest
Posted: Wed Jun 21, 2006 7:18 pm Post subject: Audio input to video camera |
You can build or buy an attenuating cord for this and just plug the
headset jack into your cameras mic in. I built one a few years ago,
but I think maybe even Aircraft Spruce sells them, or you could
even try Rad shack.
PGLong(at)aol.com wrote:
Thanks, Pat
Pat Long
PGLong(at)aol.com
N120PL
RV4
Bay City, Michigan
3CM
KD4ZHA(at)aol.com Guest
Posted: Wed Jun 21, 2006 8:27 pm Post subject: Audio input to video camera |
My intercom has a "record" jack. I just used a standard rat shack patch
cord, and impedence wasn't a problem. Picked up everything that goes to the
headset. leave the squelch down to pickup engine sounds, wind noise, etc. (gets a
little annoying, though). Do a short video and check it.
noelloveys(at)yahoo.ca Guest
Posted: Thu Jun 22, 2006 6:16 am Post subject: Audio input to video camera |
That record jack is probably a 1-V p-p line out jack it should work properly
when plugged into your line input on your camera. You will probably have
problems if you plug it into the mic input. Check the spec on the "Record"
out in the documentation for your audio panel.
Noel
[quote] --
