Arplast PV50 problem
gholland(at)content-strea
PostPosted: Thu Nov 07, 2013 10:08 pm    Post subject: Arplast PV50 problem Reply with quote
Jim Hi....It's Gerry.Where is FIZY at moment? I'm quite happy to come down and take a look if that's of use.
As you know i'm SW of Bath. If you are still at Thruxton then it's very doable.
Let me know.
Gerry
Gerry Holland
gholland(at)content-stream.co.uk (gholland(at)content-stream.co.uk)
+44 (0)7808 402404
[img]cid:4C0DBE17-4DEB-411D-BF75-8C8AFF101B75[/img]White Ox Mead Airstrip, Bath. England
 Filesize:  7.92 KB
 Viewed:  3678 Time(s)
kennethatkinson178(at)bti
PostPosted: Mon Nov 11, 2013 3:11 pm    Post subject: Arplast PV50 problem Reply with quote
Hi,
PV50 -If you find your problem is the pitch-change motor and you find a supplier then I would like to have the details so that I can buy a spare.
It is possible to fit a resistor in the pink supply wire to the motor.It is 2 ohms-10W-RS part no:252-2489.
I love the Arplast/Smart Avionics propeller/controller system.It does take time to understand and setup correctly,particularly the coarse pitch setting to allow a reasonable climb rate on a go around.
I suspect that the micro switches may also need changing in time and even could be your problem. I have fitted the recommended mechanical stops on the pitchchange screw to limit pitch runaway in case of switch or screw failure!
Cheers Ken Atkinson G-CEKV
From: Gerry Holland <gholland(at)content-stream.co.uk>
Sent: Friday, 8 November 2013, 6:07
Subject: Re: Arplast PV50 problem
Let me know.
Gerry
Gerry Holland
+44 (0)7808 402404
[img]cid:1.1085407936(at)web87402.mail.ir2.yahoo.com[/img]White Ox Mead Airstrip, Bath. England
 Filesize:  7.92 KB
 Viewed:  3652 Time(s)
g-fizy
PostPosted: Tue Nov 12, 2013 12:43 am    Post subject: Re: Arplast PV50 problem Reply with quote
hi jerry ,fizy is tucked up safe and sound in westonair's hanger at thruxton ,that offer sounds good but dont put your self out theirs no rush in this weather Smile ,,have you still got my number ?
PostPosted: Sat Nov 16, 2013 9:57 am    Post subject: Arplast PV50 problem Reply with quote
Jim Hi!
Sorry for delayed response....getting old.
Good to hear you have a good Hangar at Thruxton.
I still have you Mobile number and will try and give you a call.
One of the simple parts of the Arplast system is the way voltage is applied to motor through the hollow prop mounting.
A single thickish piano wire comes from a potentiometer and 'seats' into a brass ferrule at the moment end.
Are you sure that is positioned correctly and also clean, not corroded?
We'll have a chat and I can probably call in later next week as I have to pick up my aircraft engine from Mike Watts in Southampton after a full overhaul.
Gerry
