hagargs(at)earthlink.net Guest
Posted: Wed Nov 06, 2013 3:11 pm Post subject: Anyone who can spare a small sample of Araldite 420? |
Andrew:
You shouldn't need to do comparison testing. When doing tensile testing your joint should not fail at the adhesive. Your sample coupon should fail at the base material. Make your coupon out of the requisite number of fiberglass layers. You want to ensure your adhesive is stronger than the material you are gluing together. I've done tensile tests on my old adhesive and always had the fiberglass break before the adhesive gave way.
Steve Hagar.
nigel_graham(at)m-tecque. Guest
Posted: Thu Nov 07, 2013 6:03 am Post subject: Anyone who can spare a small sample of Araldite 420? |
Andrew,
I read your post with interest as I have pondered the same question.
I bought my first kit in 1994. It was supplied with two cans of Redux, one of which I opened and began using until the project ground to a halt (like so many), the other remained sealed.
Long after the “use-by” date, I resumed construction and mindful of the age of the Redux but curios as to how it degraded with time, I contacted Ciba-Geigy and was lucky enough to be able to speak to one of their research chemists.
Refreshingly honest, he assured me that both resin and hardener are totally inert and very stable and that, in theory, it would not degrade over time. When I asked why they advised a 36 month “use by” shelf-life, he answered that as epoxies were relatively “modern”, there was no historical evidence of any degradation and that it was only added to placate various regulating authorities. He did warn that the yellow resin would most likely crystallize over time, but that chemically it was unaltered and a gentle warming in a water bath would restore it to its original liquid state (the opened can subsequently did, as predicted, and was restored exactly as advised).
Returning to my two original cans, both had a use-by date of October 1998 – I still have them and continue to use them today, 18 years after manufacture. It works perfectly.
This also remains true of other epoxies. My SP Systems Ampreg 20 still performs perfectly (expiry 1999) and my super-expensive Polyfibre “Super-Fill” works perfectly too (expiry 1999).
Before the finger wagging begins, I should explain that I acquired the mortal remains of a cart-wheeled Europa to allow me to develop repair strategies for the compression fractured ailerons, flaps and tail. – The time-ex’d epoxy was used on these. The resulting components are indistinguishable from new-build parts. I keep test samples of each resin mix in clear plastic egg-boxes, with encapsulated paper slips listing date, batch no and component-used-on in each compartment for trace-ability.
Here is a link to the Redux (Araldite) 420 data sheet listing the target peel strength test figures:
http://www.ambercomposites.com/downloads/datasheet/araldite-420-tds-v1.pdf
atb
Nigel
Normal 0 <![endif]--> On 06/11/2013 17:54, Andrew Sarangan wrote:
[quote] | Quote: |
Snip .....I am hoping someone can send me a small sample of unexpired Araldite
420 for comparative testing.
| [b]
