racerjerry
Joined: 15 Dec 2009 Posts: 202 Location: Deer Park, NY
Posted: Sun Nov 03, 2013 8:09 am Post subject: CONTACT EXTRACTOR |
Can someone give me the (working tip end) dimensions of the Bendix/King contact extraction tool p/n 047-05099-001 that is used to remove contacts p/n 030-01107-00xx as used on KT 76 and KX 155. Please – no guesses – I need a caliper on this one. I will be working under extremely difficult conditions.
Apparently, this tool is also known as Molex p/n HT-1884
Thank you for your help.
_________________ Jerry King |
Posted: Mon Nov 04, 2013 11:19 am Post subject: CONTACT EXTRACTOR |
At 10:09 AM 11/3/2013, you wrote:
| Quote: | --> AeroElectric-List message posted by: "racerjerry" <gki(at)suffolk.lib.ny.us>
Thank you for your help. |
How many terminals do you need to extract?
The tool size is not critical . . . it needs
to fit inside the width of the slot in the
connector housing and be no thicker than the
depth of the slot. It's a thin blade that
is used to depress the retention tang
on the pin.
[img]cid:7.1.0.9.0.20131104131604.049c16c0(at)aeroelectric.com.0[/img]
Unless you have bunch of terminals to pull,
suggest you try a sewing needle inserted into
the center of the slot. The tang is only about
.4" inside and not hard to reach.
12.17 KB |
6135 Time(s) |
racerjerry
Posted: Mon Nov 04, 2013 12:11 pm Post subject: Re: CONTACT EXTRACTOR |
Bob, Thank you for your response. Fortunately, I have only two terminals to extract.
I was hoping to get measurements of the actual tool; especially the blade thickness, so the contact would release easily, yet I wouldn’t have to worry about permanently deforming the retainer clip. Also, I don’t have a spare Bendix/King card edge connector body to give me the slot width, but I could probably guesstimate that.
My idea was to cut a sliver of shim stock. Do YOU have a guess as to blade thickness of this tool?
Yes, I may have to resort to the sewing needle approach, but I don’t know if these old eyes will be able to keep the needle centered in the slot. Besides, trying different sizes, I can ruin only so many of my wife’s sewing needles before there is hell to pay.
Thanks again,
Jerry King
Posted: Mon Nov 04, 2013 3:51 pm Post subject: CONTACT EXTRACTOR |
At 02:11 PM 11/4/2013, you wrote:
There is possibility of 'flattening' the
clip even when the 'right tool' is used.
I always tweak the clip to increase it's
grip before re-inserting a used terminal
back into the housing.
| Quote: | Also, I don’t have a spare Bendix/King card
I don't think I've ever actually measured one.
The last two that I made were fabricated from
flat spring stock cabbaged from a pocket tape
measure. I used a cutoff wheel in a Dremel to
sculpt the material.
Many moons ago I published this offering
Vhttp://tinyurl.com/nknv4bk
I believe these numbers were suited to
the various versions of this pin retention
methodology . . . but that was some time ago.
| Quote: | Yes, I may have to resort to the sewing needle
Get your own needles. In fact, I think
sewing machine needles are about the right
thickness and they offer a 'handle' of sorts
on the machine end. Again, a little sculpting
with a Dremel would tailor them to the task.
klehman(at)albedo.net Guest
Posted: Mon Nov 04, 2013 5:15 pm Post subject: CONTACT EXTRACTOR |
I find that one of my very small flat screwdrivers (watchmaker type)
often works well on these types of pins.
Ken
On 04/11/2013 6:50 PM, Robert L. Nuckolls, III wrote:
<nuckolls.bob(at)aeroelectric.com>
This email is free from viruses and malware because avast! Antivirus protection is active.
http://www.avast.com
racerjerry
Posted: Tue Nov 05, 2013 3:09 am Post subject: Re: CONTACT EXTRACTOR |
OK, I am armed. Wife gave me an assortment of different size sewing machine needles (much better to not stab yourself with) and I also raided my collection of jewelers screwdrivers. Now, if I could only see the back of the connector to tell which wire is which…
Bob & Ken, thank you very much for the tips.
