Watts on resistors
trigo(at)mail.telepac.pt
PostPosted: Fri Nov 01, 2013 6:20 am    Post subject: Watts on resistors Reply with quote
Bob and all
The VP-X Pro installation manual recomends, in order to have Volt indication from the Aux Batt, to connect the + terminal to a certain pin in the box, trough a 1Kohm - 1W resistor.
Problem is that I can only find 1Kohm - 2W resistor. So, to learn something else today, can someone please explain if there is any problem if I use the 2W instead of 1W resistor.
(Please don't answer indicating a source for 1W resistors...)
Carlos
mrspudandcompany(at)veriz
PostPosted: Fri Nov 01, 2013 7:16 am    Post subject: Watts on resistors Reply with quote
The 2 watt resistor will work exactly the same in the circuit as a 1
watt.
The only difference is that the 2 watt is somewhat larger with more
surface
area and can dissipate more heat without burning up.
Roger
Do you have a slow PC? Try a Free scan http://www.spamfighter.com/SLOW-PCfighter?cid=sigen
henador_titzoff(at)yahoo.
PostPosted: Fri Nov 01, 2013 7:33 am    Post subject: Watts on resistors Reply with quote
It should be no problem, Carlos, as long as you have enough room and the circuit isn't frequency sensitive. Wattage is the resistor's ability to dissipate heat, and the resistor is bigger as the wattage goes up.
Henador Titzoff
On Fri, 11/1/13, Carlos Trigo <trigo(at)mail.telepac.pt> wrote:
Subject: Watts on resistors
To: "aeroelectric-list(at)matronics.com" <aeroelectric-list(at)matronics.com>
Date: Friday, November 1, 2013, 7:21 AM
--> AeroElectric-List message
posted by: Carlos Trigo <trigo(at)mail.telepac.pt>
Bob and all
resistor.
resistors...)
Carlos
Lists This Month --
Some AWESOME FREE Gifts!)
Raiser.  Click on
more about
Gifts provided
www.aeroelectric.com
www.buildersbooks.com
www.homebuilthelp.com
www.mypilotstore.com
www.mrrace.com
              -Matt
Dralle, List Admin.
AeroElectric-List Email Forum -
   - MATRONICS WEB FORUMS -
PostPosted: Fri Nov 01, 2013 7:40 am    Post subject: Watts on resistors Reply with quote
At 09:21 AM 11/1/2013, you wrote:
--> AeroElectric-List message posted by: Carlos Trigo <trigo(at)mail.telepac.pt>
Bob and all
That's an easy one.
The resistor is a substitute for a fuse. Further,
it's called out as 1-watt for mechanical convenience
and robustness. Examples:
Some years back I suggested that the most valuable
and often least accessible data point for diagnosing
an alternator problem is to watch FIELD VOLTAGE
behavior while putting an alternator through
its paces.
I published this little feature in Z-23 suggesting
a permanently attached wire PROTECTED by a resistor
leading from the alternator field to some handy point
in the cockpit.
[img]cid:.0[/img]
A fuse would be okay too. A 1/4 watt would work but 1/2
watt was mechanically more robust, 1w would have
been better yet. So as long as you don't mind a larger
'lump' in your battery sense lead, a 2W resistor is
okay as well.
http://tinyurl.com/kyc6tq6
I think it was here on the List that I once suggested
a tubular, 10-watt wire wound resistor with flag
terminals as a suitable enclosure for a reed switch
current sensor.
[img]cid:.1[/img]
The 'jeep' was to put lead wires on the reed switch
then epoxy into place down the center of the tubular
resistor. Then wind an excitation coil around the
center of the resistor over the reed. Calibrate
closure current for the reed by adjusting coil
turns.
In this case, the actual value of the resistor
wasn't critical . . . just needed to be high
enough not to adversely affect current through
the the coil. The resistor became a robust
'housing' for the current sense relay offering
a convenient terminals to tie off ends
of the coil.
These are but two examples of many where the
designer's 'sizing' of a component may not
have obvious foundation in the original
design goals for the part.
 Filesize:  42.18 KB
 Viewed:  3325 Time(s)
 Filesize:  18.48 KB
PostPosted: Fri Nov 01, 2013 7:42 am    Post subject: Watts on resistors Reply with quote
Hmmm . . . I think Marc harvested that concept for
sense wire protection off of Z-23.
peter(at)sportingaero.com
PostPosted: Fri Nov 01, 2013 7:48 am    Post subject: Watts on resistors Reply with quote
Hi Carlos,
My view is 2W will be fine - it means that the resistor will cope with a
higher voltage (45v) & so dissipate more energy. A 1W resistor will cope
with 32v (theoretically).
Peter
On 01/11/2013 14:21, Carlos Trigo wrote:
Bob and all
Carlos
tim2542(at)sbcglobal.net
So it sounds like they are using a resistor to protect the sensor wire from over current/unintentional ground instead of a fuse, is that the purpose here?
Tim
On Nov 1, 2013, at 8:15 AM, "R. curtis" <mrspudandcompany(at)verizon.net> wrote:
The 2 watt resistor will work exactly the same in the circuit as a 1 watt.
The only difference is that the 2 watt is somewhat larger with more surface
Roger
PostPosted: Fri Nov 01, 2013 9:25 am    Post subject: Watts on resistors Reply with quote
Tim
Exactly. The input impedance to the instrumentation
system is either sufficiently large that added
1K of resistance is insignificant . . . or is a
calculated part of the input voltage divider.
