donjohnston
Posted: Mon Jun 23, 2014 8:34 am Post subject: Re: LED Ghosting |
Mission accomplished!
The analyzer alarm LEDs will go out before the others at around 15% brightness. But above that, those LEDs are the same brightness as the others. I played around with different resistance values and determined that 18K between the source and gate provide the widest range and relative brightness.
Thanks all!!!
40.76 KB |
8613 Time(s) |
Posted: Mon Jun 23, 2014 10:05 am Post subject: Re: LED Ghosting |
Good job Don
_________________ Joe Gores |
Thermos
Posted: Wed Nov 02, 2016 6:16 am Post subject: Re: LED Ghosting |
Bob,
Reawakening this thread, you mentioned a few years ago a potential mod to the LR3C to eliminate "ghosting" when using LEDs as annunciators -
"The 'problem' can be eliminated by snipping out the one-time-useful resistor. I think I'll suggest that B&C eliminate that resistor in future production and modify any regulators that come back for other reasons."
Am I understanding this correctly as a solution, and if so, was this mod ever made by B&C? I purchased an LR3C this year and if it's the same as before, I may wait 'till it's out of warranty then do the mod myself.
Dave
_________________ Dave Setser
RV-7 Firewall Forward
KBED/KASH |
Posted: Wed Nov 02, 2016 7:02 am Post subject: LED Ghosting |
At 09:16 AM 11/2/2016, you wrote:
| Quote: | --> AeroElectric-List message posted by: "Thermos" <dave(at)mightyrv.com>
Bob,
Reawakening this thread, you mentioned a few years ago a potential mod to the LR3C to eliminate "ghosting" when using LEDs as annunciatirs-
Am I understanding this correctly as a solution, and if so, was this mod ever made by B&C? I purchased an LR3C this year and if it's the same as before, I may wait 'till it's out of warranty then do the mod myself. |
The LV warning output from the LR3 is designed
to drive INCANDESCENT lamps while offering a
warning for loss of operating power to the
LV warning system. This philosophy has served
TC and OBAM aviation well for several decades.
LEDS are the new kids on the block . . . and like
lithium batteries, dynamic microphones, LED
nav lights, etc . . . they are not form/fit/function
drop-on replacements for their legacy ancestors.
It's easy to make an LED emulate the
incandescent lamp for purposes of using it to
annunciate low volts on an LR3 installation.
http://tinyurl.com/cgnwr5k
But if you'd rather mod the regulator instead,
that's certainly doable . . .
Bob . . . [quote][b] [quote][b]
Posted: Wed Nov 02, 2016 8:14 am Post subject: LED Ghosting |
DON'T KNOW WHAT HAPPENED . . . THE ORIGINAL
REPLY GOT TRUNCATED. LET'S TRY AGAIN.
Bob,
Posted: Wed Nov 02, 2016 8:30 am Post subject: LED Ghosting |
Subject: Re: Re: LED Ghosting
MAYBE THE THIRD TIME IS THE 'CHARM' . . . I
RAN A CUT-N-PASTE THROUGH A VISIBLE TEXT ONLY
FILTER JUST IN CASE SOME HIDDEN CHARACTER
WAS CAUSING THE MESSAGE TO END EARLY . . .
Bob,
drop-in replacements for their legacy ancestors.
See: http://tinyurl.com/cgnwr5k
But as you've noted modifying the regulator instead,
is certainly doable . . .
