EXP 2 Bus workaround
Goto page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Fri Oct 25, 2013 6:43 pm    Post subject: EXP 2 Bus workaround Reply with quote
At 07:35 PM 10/25/2013, you wrote:
--> AeroElectric-List message posted by: Fred Klein <fklein(at)orcasonline.com>
Bob, thank you for your analysis and recommendations...they greatly enhance my learning experience here...please see my indents below...I have additional comments (later) on your posted circuit diagram of this morning...Fred
We're getting the cart out in front. Let's get a 98%
golden list of electro-whizzies and where they'll
get powered.
The Z-08 drawing is just architecture for now, the mechanism
by which an EXP-Bus duplicates or emulates the philosophy
is a separate task.
> (3) Take E-Bus alternate feed directly from the battery on
> it's own 7A fuse and 14AWG wire . . . 10A fuse if determined
> necessary later.
I can do that; this adds another wire forward from rear battery to bus...What's the advantage of doing this rather than using a short wire to the Engine (MP) bus, as long as the total E-bus + MP bus loads can be handled by the EXP Bus circuit from which power is being drawn? Normally (I believe the) E-bus alternate feed will ONLY be activated in conjunction w/ the Engine (MP) bus alternate feed (sized accordingly) is activated.
We can thrash this detail later . . .
Let's talk about the 2 fuel pumps for a MPEFI engine. Unlike w/ carb engines, the 2nd pump is not used as a boost pump. I'm advised that w/ a MPEFI engine, one never wants to run more than ONE pump at a time due to excessive pressure in the system.
How does this happen? I understand that there's a pressure
regulator downstream of the pump outputs. Paralleling two
active pumps only increases potential for flow . . . like
hooking two batteries in parallel.
> (7) Suggest separate fuses for each injector and coil
> assuming engine produces some useable power with any
> one fuse open.
This sounds like a novel idea...I'm wondering if anyone's ever done this before?.. how much increased complexity is entailed?...and whether or not historical rates of injector and coil failures suggest that this would be prudent?
I've seen this before. The idea is that no single failure
takes out all injectors and an engine will produce useful
power with one injector down.
> (Cool Starter can control from main bus.
True...and...w/ my particular combination of engine, reduction ratio, propeller, and aircraft performance envelope, although I THINK that with engine out, prop would windmill sufficient to restart engine, if Master switch was OFF, I'd like to be able to spin the starter...that was the INTENT of what the diagram shows...What do you think?...I'm unsure as to whether or not the wiring diagram allows for that to happen.
Is anyone flying this combination of hardware? How much does
IAS need to be reduced to stop a windmilling prop? The few
times I stopped the prop on a TC airplane I had to really
work at it. The idea that one needs access to a starter
motor in flight is mostly without foundation. This is a
fact you need to resolve for your harware combination.
> (9) Turn existing avionics bus into e-bus, convert
> old avionics master into alternate feed path control
> switch. Normal feed path comes from main bus through
> diode.
I'm completely in the dark as to my understanding of what physical changes must be made to the EXP Bus to accomplish this.
Later . . . I don't think it's going to be difficult.
> (10) You speak to "room for breakers/fuses on panel"
> suggest these be out of sight, of reach.
That would be possible of course, though if CBs are used, questionable. I'm presuming that you want them out of sight to reduce workload in an emergency, and to avoid possibly exacerbating conditions by resetting popped CBs...is that so?
The only time a fuse or breaker opens is because something
is broke (which means new fuse doesn't help) or the circuit
protection is undersized (nuisance trip - which on an OBAM
aircraft gets fixed). Hence, no value for being able to see/reach
breakers and fuses.
Bob . . . [quote][b]
livingjw(at)earthlink.net
PostPosted: Fri Oct 25, 2013 8:47 pm    Post subject: EXP 2 Bus workaround Reply with quote
I am still stumped as to why you would recommend one battery. I could agree if the one alternator is guaranteed to work without the battery in the circuit, but not without that backup. You must think batteries are much more reliable than I do.
John
On 10/25/2013 10:42 PM, Robert L. Nuckolls, III wrote:
[quote] At 07:35 PM 10/25/2013, you wrote:
--> AeroElectric-List message posted by: Fred Klein <fklein(at)orcasonline.com> (fklein(at)orcasonline.com)
get powered.
is a separate task.
> necessary later.
> one fuse open.
> diode.
breakers and fuses.
Fred Klein
PostPosted: Fri Oct 25, 2013 10:41 pm    Post subject: EXP 2 Bus workaround Reply with quote
Bob...I get your point about pressure...let me try to get better info...it may be that restriction due to size of return fuel line can't accept the increased flow...I'll check back about this.
Bob...I'm getting some data on this.
Fred
Fred Klein
PostPosted: Fri Oct 25, 2013 10:52 pm    Post subject: EXP 2 Bus workaround Reply with quote
On Oct 25, 2013, at 6:32 AM, Robert L. Nuckolls, III wrote:
Attached are the preliminary sketches for my current
thoughts on an architecture for single battery, single
alternator, electrically dependent engine. This line of
thinking is being developed as an preferred alternative
to Z-19.
Bob...I'm delighted that my queries have triggered your taking a fresh look at Z-19...and presumably, Z-19RB.
This architecture has roots in Z-11 Three-Bus structure
with the addition of a Motive Power Bus (engine). With
the term E-bus already in legacy use, the MP-Bus terminology
offers a stand-out label that avoids confusion.
...perhaps it won't be too long before MP busses will morph into ones intended for truly all electric power trains...
The major difference is the addition of the MP-bus having
normal feedpath from the main bus, alternate feedpath from
the battery . . . same as the E-Bus except BOTH pathways
have panel mounted switches. The e-bus is always hot any
time the main bus is hot, but the MP-Bus as power to the
engine needs to be controlled through both pathways.
I'm thinking that the EXP-bus can be folded into this
architecture by conversion of battery switch to DC master
and take alternator field through second pole. Convert
the 'avionice master' Engine A. Use switch between the
big red rockers as e-bus alternate feed. Switch to right
of Engine A is Engine B.
From the get-go, my intent has been to supplement the capabilities of the EXP Bus to provide for the special requirements for a MPEFI engine AND to provide the alternate feeds featured in AeroElectric's Z-xx diagrams in case something goes amiss.
I question your suggestion to:
Use switch between the big red rockers as e-bus alternate feed. Switch to right of Engine A is Engine B.
I'm reluctant to interpose within the row of EXP Bus rockers, switches which would only be used during an emergency.
Conceptually, I much prefer the notion of having a row of rockers, all of which are used in the course of normal operations...and a second, distinctly different row of rockers which will only be used during emergencies.
(The wide, red, Master switch at the left end...distinctive in both width and color...is of course used both in normal and emergency ops.)
Organizing the panel in this manner...at least to me...sets the stage for calm and cool actions when under stress.
I understand your desire for me to proceed w/ listing of elec loads for all components...a task I recognise as essential...but first I want to be confident that I understand the big picture. And the big picture for me is how we supplement the capabilities of the EXP Bus in order to have the benefits of engine and endurance busses with alternate feeds from the battery.
Notwithstanding the shortcomings, some poor choices, and undoubtedly some serious errors, the last diagram I posted (Revision #XX) did two things of note:
First, it pulls power from the EXP Master Bus for the MP (engine) bus from 2 - 11 amp circuits, AUX1 and AUX2. (...now I don't know exactly how those 2 circuits can be combined, but something tells me there's a way which is simple and direct...)
Second, the Revision XX diagram shows the EXP Avionics Bus powering the E-bus (endurance) from a 7 amp circuit. (...btw, I don't understand the notion that we should be rid of the avionics master switch...). Also...note that w/ Skyview and the back up GPS both having their own back up batteries, if either the Master switch or the Avionics Master is turned off and the E-bus Alternate Feed is energized, we'll be back in business w/ a full suite of avionics.
It strikes me that this approach is elegant, simple, and direct; I shudder at the thought of altering any part of the circuitry within the EXP Bus other than changing some Fast-on spades of a couple of switches and relabeling them.
I'm baffled when you write,
Old avionics bus becomes e-bus.
...as I look at the circuit board of the EXP Bus, I haven't a clue how this can happen and create the alternate feed intrinsic w/ the e-bus concept...way outside my comfort zone to poke around in that circuit board.
Fred
klehman(at)albedo.net
PostPosted: Sat Oct 26, 2013 2:52 am    Post subject: EXP 2 Bus workaround Reply with quote
FWIW two parallel subaru oem EFI pumps from a 4 cylinder legacy work
fine with a oem regulator all of 1990 to 1994 vintage. Pressure goes up
no more than 2 psi. even with my somewhat restrictive 5/16" return
plumbing. Some fellows run both pumps for landing and takeoff. Selecting
both on is the first thing we do if the engine is not running properly.
Injector flow increases with the square root of pressure so that is not
an issue since normal EFI pressures run around 38 psi above manifold
pressure.
Ken
* How does this happen? I understand that there's a pressure
hooking two batteries in parallel.*
PostPosted: Sat Oct 26, 2013 5:05 am    Post subject: EXP 2 Bus workaround Reply with quote
Oky, let's ex[;pre that premise. What in your
studies and/or experience with batteries leads
you to believe that they demonstrate a risky,
in-service failure rate?
Before you add a second battery, are there things
that can be done to mitigate your concerns and
reduce in-service failures to acceptable risk
levels?
Recall that the original premise for dual batteries
had nothing to do with worries for battery failure
and everything to do with walling off known quantities
of energy off to do separate tasks . . . where one
of those tasks was critical to continued flight:
keep the engine running. The two battery concept was
never intended to be a hedge against the failure
of one battery.
PostPosted: Sat Oct 26, 2013 5:50 am    Post subject: EXP 2 Bus workaround Reply with quote
Attached are the preliminary sketches for my current thoughts on an architecture for single battery, single alternator, electrically dependent engine. This line of thinking is being developed as an preferred alternative to Z-19.
This architecture has roots in Z-11 Three-Bus structure with the addition of a Motive Power Bus (engine). With the term E-bus already in legacy use, the MP-Bus terminology offers a stand-out label that avoids confusion.
The major difference is the addition of the MP-bus having normal feedpath from the main bus, alternate feedpath from the battery . . . same as the E-Bus except BOTH pathways have panel mounted switches. The e-bus is always hot any time the main bus is hot, but the MP-Bus as power to the engine needs to be controlled through both pathways.
I'm thinking that the EXP-bus can be folded into this architecture by conversion of battery switch to DC master and take alternator field through second pole. Convert the 'avionice master' Engine A. Use switch between the big red rockers as e-bus alternate feed. Switch to right of Engine A is Engine B.
Please . . . purge the work EMERGENCY from your
thought processes. Things on airplanes break all
the time. If they did not, FBO maintenance shops
would be out of business and Jiffy-Lube could move
into the empty space while adding a wash-rack.
You have Plan-A, everything works in accordance
with the refined constellation of design goals.
Then there is Plan-B, something broke . . . a
condition that has been anticipated in our FEMA
and we're dealing with it under a sub-set of
the original design goals. Then there's Plan-C,
supported by some goodies in the flight bag
that describe yet a smaller sub-set of original
design goals.
An airplane configured artfully conducted FMEA
operating by a pilot who understands the machine's
strengths and weaknesses does not experience
electrical emergencies . . . only events of
in-service failure or wear-out that will need
to be hammered on once you've arrived at your
intended destination.
The BIG picture is that drawing I published.
You're getting distracted by the existence of
the EXP-Bus.
The avionics master switch was a flawed idea
from the get-go. I was at Cessna when the thing
was birthed and I've come to understand how
we marched off down that no-value-added
path. See:
http://tinyurl.com/pgcgx9m
Ignore the EXP=Bus for now, we need to
make the architecture work first.
"Old avionics bus becomes e-bus."
There is presently an avionics master switch that
controls all power to a chunk of copper glued
to the epoxy-glas that distributes power to terminals
on the board through an array of poly-fuses. This
is your 'avionics' bus which I believe can become
your new e-bus.
It's just "wires" glued to a piece of epoxy-glas.
Nothing happens on that assembly that a large
number of our contemporaries haven't done with
fuses, wires, breakers and switches. The marketing-hook
for an EXP-Bus is it's relative complexity for stuffing
a lot of activity into a small volume and then offering
it to the customer as, "Here, look at all these things
we did FOR you so that you don't HAVE to."
The question never asked and answered is, "Does that
assembly DO things that people who choose not to
use your product will wish they had included at
some later time?" In other words, what is the
return on investment for you having exchanged your
dollars for their time, talents and resources?
That's what we're doing here right now. The sketches
I published don't speak to how the EXP-Bus will be
'jeeped' (Old television vernacular for modifying
a piece of equipment to some new task not offered
by the designers) into the spirit and intent of
the new Z-figure. Let's assume for the moment that
EXP-Bus is not present. The sketches are not
a "Z-figure for EXP-Buses" . . . it's a new architecture
is a stand alone recipe for success crafted from
rudimentary ingredients. Making a practical
adaptation of an EXP-Bus to the task is a separate
activity we can tackle after the cake is in the oven.
It's just 'frosting' . . .
PostPosted: Sat Oct 26, 2013 5:52 am    Post subject: EXP 2 Bus workaround Reply with quote
up no more than 2 psi. even with my somewhat restrictive 5/16"
return plumbing. Some fellows run both pumps for landing and
takeoff. Selecting both on is the first thing we do if the engine is
not running properly. Injector flow increases with the square root
of pressure so that is not an issue since normal EFI pressures run
around 38 psi above manifold pressure.
Good data sir. Thanks!
PostPosted: Sat Oct 26, 2013 5:58 am    Post subject: EXP 2 Bus workaround Reply with quote
Does your engine feature a PSRU? If so, does it
include a spag-clutch on the propeller shaft
for mitigation of rotational vibration stresses
on the gearbox?
If so, then the prop windmills at all speeds and
does not back-drive the engine. But in any case,
pushing a starter button with the notion that a
starter will respond assumer is ales a battery contactor
is closed and FAT-wire power is also available to
the starter. Starter button is not an E-bus load.
PostPosted: Sat Oct 26, 2013 5:59 am    Post subject: EXP 2 Bus workaround Reply with quote
On this list we have seen examples of internal battery failures and wire connector failures and switch failures. Granted that these things typically have low failure rates, but if they happen, you have no backup. By going with one battery and not knowing if the alternator will back you up you have elevated these failures to the status of a prop, engine, wing or control surface failure.
John
levels?
of one battery.
Fred Klein
PostPosted: Sat Oct 26, 2013 6:45 am    Post subject: EXP 2 Bus workaround Reply with quote
On Oct 26, 2013, at 3:51 AM, Ken wrote:
FWIW two parallel subaru oem EFI pumps from a 4 cylinder legacy work fine with a oem regulator all of 1990 to 1994 vintage. Pressure goes up no more than 2 psi. even with my somewhat restrictive 5/16" return plumbing. Some fellows run both pumps for landing and takeoff. Selecting both on is the first thing we do if the engine is not running properly. Injector flow increases with the square root of pressure so that is not an issue since normal EFI pressures run around 38 psi above manifold pressure.
Thanks Ken...I stand corrected...my engine at 1.8 L is a tad smaller than your Legacy...it's set up w/ 3/8" fuel supply line and a 1/4" return line using R9 injector hose aft of my firewall. I believe the fuel pressure regulator has been set to factor in whatever restrictive backpressure the 1/4" return line contributes.
Ron Carr at RAM Performance sez my engine's fuel pressure will be 38 psi at idle and rise to 43 psi at WOT.
(I have not discussed the dual pump issues w/ him because he sells his engines with only one pump.)
Fred
rickofudall
PostPosted: Sat Oct 26, 2013 6:58 am    Post subject: EXP 2 Bus workaround Reply with quote
Fred, Bob, et al, I have no dog in this fight, I've just been following the discussion but I've got to ask; with all these workarounds you're doing to make the EXPBus work with your airplane's systems, what is it buying you? The Spruce description of the EXPBus is all about easy squeazy installation and time savings, yet you're being forced into more and more redesign and adaptation in order to make it work for you. I realize that you're a long way down the road with this thing but have you thought about just grabbing a clean sheet of paper and sending the EXPBus to eBay?
Rick Girard
On Sat, Oct 26, 2013 at 8:58 AM, John W Livingston <livingjw(at)earthlink.net (livingjw(at)earthlink.net)> wrote:
John
  levels?
  of one battery.
ist" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
tp://forums.matronics.com
Zulu Delta
Mk IIIC
Thanks, Homer GBYM
  - Groucho Marx
PostPosted: Sat Oct 26, 2013 7:42 am    Post subject: EXP 2 Bus workaround Reply with quote
For me, this discussion is NOT an attempt to
craft a Z-Figures for EXP-Bus. It's a new look
at Z-19 and other manifestations of two-battery
installations to explore well reasoned alternatives.
When and if the new Z-figure makes it to the back
of the book, then well see if we can fiddle with
an EXP-Bus to achieve the same architecture crafted
to design goals.
PostPosted: Sat Oct 26, 2013 7:46 am    Post subject: EXP 2 Bus workaround Reply with quote
The question to be answered for evolving this
new architecture is whether or not having two
pumps on at the same time represents any kind
of hazard.
The second pump is included to mitigate the
failure of the first pump. The first pump is
presently powered any time the MP-Bus is hot.
If the pump works, then the second pump is
not needed. If the first pump fails, the second
pump is available. At no time has anyone
suggested that the pumps should be operated
simultaneously on purpose.
PostPosted: Sat Oct 26, 2013 7:49 am    Post subject: EXP 2 Bus workaround Reply with quote
Somewhat different hardware but indicative. With a 1.92 gear ratio and
a 3 bladed 72" non-tapered warp prop my ej22 windmills down to below 40
knots. However if I do intentionally stop it (difficult to do with a
best glide speed of about 65 knots), a 120 knot dive is insufficient to
get a restart. More interesting was that unlike many airplanes, my Rebel
has about the same glide ratio whether windmilling or stopped which
surprised me. Obviously I do not have one of the sprag clutch type
arrangements that have been so troublesome...
Ken
Fred Klein
PostPosted: Sat Oct 26, 2013 7:54 am    Post subject: EXP 2 Bus workaround Reply with quote
Good question Rick...and one I've asked myself many times. My answer has been that I'll chuck the EXP Bus when I reach the conclusion that doing so will solve more problems than it creates. I'm still a long way from that.
Your first question..."what is it buying you?"...is an even better question, and I regret that I was simply too ignorant to read between the lines of the marketing hype...I confess to have been dazzled by the EXP's obvious complexity (to what end?) and my belief that "I guess I need to buy one of these, cause I sure wouldn't want to trust myself to build one".
As I presently understand things, the EXP can serve as my main power distribution bus and provides circuits which can be used to power an engine bus (or Motive Power Bus, to use Bob's new term) and an endurance bus, both of which want to have alternate power feeds direct from the battery.
All this seems fine and doable without making circuitry changes within the EXP, something I'm loath to do, primarily because of my inexperience and unfamiliarity w/ things electronic.
I can only commend Bob for his patience with me,
Fred
PostPosted: Sat Oct 26, 2013 7:58 am    Post subject: EXP 2 Bus workaround Reply with quote
Let's concentrate on battery failures . . . and
the failure of components that hook that battery
to ground and the contactor stud.
What was the nature of failures internal to the
battery? What was the nature of failure for
any wires/connectors for which you have data?
Yes. Propellers have flown off the end of crankshafts,
wheels have departed their axles, elevator push-rods
have become disconnected. We read about and ponder these
events . . . did any one of these FEMA prompt recommendations
for dual engines, an extra landing gear strut and wheel
or perhaps splitting the elevator into two halves with
independent pushrods?
The rational response to such stories is to move
avoidance for root cause into prominent positions
for attention to detail. I've observed many
times in these writings that the greatest risk
to the airborne mission is the human element; a
risk for missing/ignoring critical fundamentals.
Can we deduce what attention to detail is needed
to make a battery as reliable as your prop bolts?
Fred Klein
PostPosted: Sat Oct 26, 2013 8:08 am    Post subject: EXP 2 Bus workaround Reply with quote
Bob...you asked:
I asked a pal flying a RAM Sube powered Europa the following questions:
In your bird, have you ever stopped your engine in flight?
.If so, did the prop stop or windmill?
If the prop stopped, how did you get it spinning again?
Can you spin your starter w/ the Master Switch off?
If not, would you like to be able to?
...and got this reply...not much help unfortunately.
Fred
Hi Fred - no I've never stopped it. I thought about flying to an aiport 40 miles north that has an 12000 ft runway and climb to 10000 ft at 6 AM when no traffic was around and turn it off but haven't done it yet.
I can turn everything off but the fuel pumps and ignition and the engine will run but I never thought of whether the starter
would work - duh!!
I'll have to check that and get back to you. I need to see if the trim works with everything turned off as well. I'm wondering if with the ac trimmed for cruise whether I would still have enough elevator for the landing flare.
XXXX
From: fklein(at)orcasonline.com (fklein(at)orcasonline.com)
Subject: a Europa query
Date: Fri, 25 Oct 2013 22:04:53 -0700
To: XXXX(at)hotmail.com (gcrowder2(at)hotmail.com)
XXXX
Sorry for all the questions...they are a consequence of an online conversation I'm having with Bob Nuckolls at AeroElectric-list...excerpt below:
Thanks once again for your help,
Fred
Fred Klein
PostPosted: Sat Oct 26, 2013 8:59 am    Post subject: EXP 2 Bus workaround Reply with quote
On Oct 26, 2013, at 8:49 AM, Ken wrote:
--> AeroElectric-List message posted by: Ken <klehman(at)albedo.net (klehman(at)albedo.net)>
Somewhat different hardware but indicative. With a 1.92 gear ratio and a 3 bladed 72" non-tapered warp prop my ej22 windmills down to below 40 knots. However if I do intentionally stop it (difficult to do with a best glide speed of about 65 knots), a 120 knot dive is insufficient to get a restart. More interesting was that unlike many airplanes, my Rebel has about the same glide ratio whether windmilling or stopped which surprised me. Obviously I do not have one of the sprag clutch type arrangements that have been so troublesome...
Ken...interesting...my PSRU ratio is 1.9 to 1.0 and I too do not have a sprag clutch...Fred
PostPosted: Sat Oct 26, 2013 9:10 am    Post subject: EXP 2 Bus workaround Reply with quote
Why would you want access to the
starter with the master switch off?
Under what conditions would you first
have the switch off and then find that
the engine has assumed a condition that
needs encouragement to get running again?
Assuming that the engine is at risk for
doing such a thing, what prevents you
from turning the master switch back on?
Page 4 of 6
