jbhart(at)onlyinternet.ne Guest
Posted: Mon Mar 06, 2006 5:02 am Post subject: To cut or not to cut? |
At 08:49 AM 3/5/06 -0800, you wrote:
| Quote: | As far as the ultralight in question, the owner was obviously wondering about this posibility prior to this discussion, why do you think he asked the question in the first place? This particular firestar is flown very heavy, and has been subjected to aerobatics (overloads), is very high time, pretty much the same scenario that caused another Firestars wing to fail... I just wonder how you can totally discount the possiblity that it could happen again.
Michael A. Bigelow
Michael,
Staying within the Kolb ranks, only two confirmed losses were due to
continued abuse. The plane in question has one documented loop or roll
which may or may not have abused the plane. I believe the Kolb FireFly is an
elegantly simple and robust design, and I picked it to build because I
considered it to be over designed. When you over power, over speed, and
overload there is no reason to expect that the plane will hold together. If
you want complete certainty about your aircraft, keep it in the hangar.
John,
Go fly the plane!
Jack B. Hart FF004
Winchester, IN
WhiskeyVictor36(at)aol.co Guest
Posted: Mon Mar 06, 2006 7:44 pm Post subject: To cut or not to cut? |
In a message dated 3/5/2006 7:57:09 P.M. Eastern Standard Time,
jdm(at)wideworld.net writes:
All you need is a radio to fly into class D airspace.
John M,
I don't have a radio.
Yet.
Maybe in the future
Bill Varnes
Original Kolb FireStar
Audubon NJ
Russ Kinne
Posted: Tue Mar 07, 2006 5:47 am Post subject: To cut or not to cut? |
Bill
I have a handheld you can borrow to get into controlled airspace;
I've used it when the main radio packed up. Not the greatest but it
works!
You c an also phone the tower & get a one-time clearance to enter,
using light signals -- I've always found them cooperative.
You're most welcome to try it --
Russ Kinne
On Mar 6, 2006, at 10:44 PM, WhiskeyVictor36(at)aol.com wrote:
John M,
Yet.
Maybe in the future
Bill Varnes
Audubon NJ
Posted: Tue Mar 07, 2006 7:38 pm Post subject: To cut or not to cut? |
In a message dated 3/7/2006 8:48:03 A.M. Eastern Standard Time,
kinnepix(at)earthlink.net writes:
Bill
works!
Hi Russ,
I thank you for the offer and advice. Regarding light signals, I'm somewhat
color blind and have difficulty with red and green. Even traffic signals
gave me trouble until I memorized that the top light is red and the lower is
green. Not sure how I would handle tower lights.
Bill Varnes
Audubon NJ
pj.ladd(at)btinternet.com Guest
Posted: Wed Mar 08, 2006 1:13 am Post subject: To cut or not to cut? |
I'm somewhat color blind and have difficulty with red and green. Even
traffic signals gave me trouble until I memorized that the top light is red
Hells bells Bill, ,
they let you drive a car as well?
Cheers
Pat
Russ Kinne
Posted: Wed Mar 08, 2006 12:08 pm Post subject: To cut or not to cut? |
Only where they drive on the right side!
On Mar 8, 2006, at 3:53 AM, pat ladd wrote:
Even
light is red
Hells bells Bill, ,
Cheers
Pat
