Tool Kit
Goto page Previous  1, 2, 3
patreilly43(at)hotmail.co
PostPosted: Wed Apr 22, 2009 6:40 am    Post subject: Tool Kit Reply with quote
Noel C If rib lacing cord can be used for dental floss C how about reversing that and using dental floss for rib lacing in a pinch?
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
[quote] From: noelloveys(at)yahoo.ca
Subject: RE: Tool Kit
Date: Tue C 21 Apr 2009 20:58:23 -0230
--> Kitfox-List message posted by: "Noel Loveys" <noelloveys(at)yahoo.ca>
Great idea. Wax chord could also be used to start a fire or floss your
teeth. Smile Seriously wax chord was used extensively in aircraft before the
advent of nylon tie wraps. I have a beef with the tie wraps and that is
when cropped if not rounded they will gash open hands reaching into an
engine compartment tugging on things to check they are solid.
Noel
nebchmp(at)suddenlink.net
PostPosted: Wed Apr 22, 2009 9:29 am    Post subject: Tool Kit Reply with quote
FWIW: I needed to make a solder repair on my two meter hand held in a
confined area. I bought one of the battery soldering irons and it
worked. This one is made by Weller, (BP645) 4.5 volts, 6 watts,
purchased at Lowe's.
Norm.
Float Flyr
PostPosted: Wed Apr 22, 2009 2:09 pm    Post subject: Tool Kit Reply with quote
It may be a little light for rib lacing but it would be more than enough to temporarily repair a small tear in a wing or fuse.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of patrick reilly
Sent: Wednesday, April 22, 2009 12:09 PM
To: kitfox matronics
Noel, If rib lacing cord can be used for dental floss, how about reversing that and using dental floss for rib lacing in a pinch?
Pat Reilly
Mod 3 582 Rebuild
Rockford, IL
> To: kitfox-list(at)matronics.com
> Date: Tue, 21 Apr 2009 20:58:23 -0230
> Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Wed Apr 22, 2009 2:38 pm    Post subject: Tool Kit Reply with quote
I've done soldering with a match in desperate situations.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Page 3 of 3
