Key Ignition Switch
Goto page Previous  1, 2, 3
Float Flyr
PostPosted: Sun May 15, 2011 7:23 pm    Post subject: Key Ignition Switch Reply with quote
That might be legal some places south of the 49th but be careful it's not
considered a booby trap in your jurisdiction.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Float Flyr
PostPosted: Sun May 15, 2011 7:46 pm    Post subject: Key Ignition Switch Reply with quote
A couple of years ago I was involved with the ground movement of a B737... We never did find the master... After several weeks we looked it up in the manual to try the APU. After sitting for over five years it started right up ... textbook style.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
stuart(at)stuarthutchison
PostPosted: Mon May 16, 2011 1:46 am    Post subject: Key Ignition Switch Reply with quote
G'day Guys,
Physical security locks are mandatory in Australia. I plan to have a canopy lock, but for added security, I'm installing one of Bob Newman's Smart Start modules (www.tcwtech.com). It uses a momentary switch to arm the start circuit for 1 minute - of course you can locate the momentary switch anywhwere you like so that it's counter-intuitive to find. I would recommend the optional air switch to arm the start at flying speeds, and there's also an option to connect the circuit to an interconnect switch elsewhere, so that start is disabled until other pre-conditions are met (for example closing the canopy).
Cheers, Stu
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
F1 Rocket VH-FLY http://www.mykitlog.com/RockFLY [url=about:www.teamrocketaircraft.com]www.teamrocketaircraft.com[/url]
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Mike Welch
Sent: Monday, May 16, 2011 4:02 AM
Subject: RE: Re: Key Ignition Switch
What do you think would be the cheapest YET most effective?
TIA for your thoughts.
Howard
Howard,
Here is what I would do, if I was worried about losing an airplane
or airplane parts; (cost...about $.50, if that!)
    ATTENTION!!!
If you can read this message, you have already activated
a motion detector & video recorder, and
    YOU ARE BEING TAPED!!
IF YOU ARE STILL IN THIS VICINITY WITHIN 3 MINUTES,
THE POLICE WILL BE NOTIFIED VIA A MODEM.
YOU HAVE 2 1/2 MINUTES LEFT BEFORE THE POLICE ARE
CALLED. GOOD BYE!!
You also have a small electronic box sitting inside the plane,
with a flashing RED LED. The box is only visible if you are standing
near the plane, even though it blinks 24/7....they think they
just set it off and are being recorded!! Nobody, and I mean NOBODY
is going to do a thing wrong when they think they are on camera!!
Mike Welch
Neal.George(at)hurlburt.a
PostPosted: Mon May 16, 2011 4:49 am    Post subject: Key Ignition Switch Reply with quote
Howard -
If a thief wants your airplane or something in it, he's going to take it. Short of armed and catching him in the act, there's precious little you can do to stop it. If you make it difficult, he'll just break stuff to get to what he wants. Some will do additional damage out of pure meanness.
If somebody wants my stuff bad enough to steal it, I'd just as soon they didn't tear up the airplane in the process. Good insurance at honest values is the answer to this one.
A canopy cover will discourage the ramp-walking snooper. Some airports require a prop lock, and it will show the insurance company and HAS/TSA/DEA that you tried to keep the airplane on the ground.
Neal
plevyakh
PostPosted: Mon May 16, 2011 7:13 am    Post subject: Re: Key Ignition Switch Reply with quote
Folks,
Thanks for all the great inputs. I'm going to keep it simple for now as you suggest and include the following:
1) Propeller chain lock
2) Throttle lock
3) Canopy cover and or cloth drape over the panel to keep the avionics hidden.
I did find a nice lightweight high DB alarm that would trip when the door is opened. It's a beam sensor device. This might be added as a winter project down the road.
Howard
Howard Plevyak
GlaStar / Cincinnati, Ohio
skywagon
PostPosted: Mon May 16, 2011 7:51 am    Post subject: Key Ignition Switch Reply with quote
From my brief view of the "thievery" issue, I think stolen airplanes are the
minor issue.
Thefts from the "panel" are the primary target of the traveling hit and run
crowd. The last hit at our airport was strictly for new, popular model
avionics....that would eventually show up on eBay, Craig's List, etc. We
are also located close to a freeway...not good as the thieves want a quick
exit after hitting an airport.
D
sarg314(at)gmail.com
PostPosted: Mon May 16, 2011 10:40 am    Post subject: Key Ignition Switch Reply with quote
I don't have an ignition switch in my 6A.  I ran the line from the master switch to a banana jack and continued it on from another banana jack next to it. A 2 pronged banana plug (see photo attached) plugs into both of them.  A wire across the screw terminals of the plug shorts the 2 prongs together.  So, that shorting plug is my "ignition key".  I have regular toggle switches for the master switch (a 3 position switch - off, battery, battery + alt) and two other separate toggles switches for the magneto and the electronic ignition. Simple and light.
The 2 pronged banana plug can be bought at any radio shack or electronic parts store.  With the plug removed the master switch is disabled.  There are these 2 innocuous banana jacks in the panel which are unlabeled.  I'm guessing most people looking at the panel wouldn't pay them any attention or guess what they do.  My electrical system is otherwise Bob K's venerable Z-11.
Tom Sargent
 Filesize:  3.31 KB
 Viewed:  10113 Time(s)
trigo(at)mail.telepac.pt
PostPosted: Mon May 16, 2011 2:14 pm    Post subject: Key Ignition Switch Reply with quote
Tom
So, the ideal thief for your airplane would be a guy who works for Radio Shack .... J just couldn’t resist
Carlos
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of thomas sargent
Sent: segunda-feira, 16 de Maio de 2011 19:37
Subject: Re: AeroElectric-List: Re: Key Ignition Switch
Tom Sargent
Float Flyr
PostPosted: Mon May 16, 2011 5:11 pm    Post subject: Key Ignition Switch Reply with quote
Scrap the sign and just put the LED in with a label that says “Modem Active”
The alternative is to actually install a camera, GPS and modem that’s active 24/7... that way you can keep tabs on your plane any time you want. A GPS enabled phone left in the cargo compartment or mounted behind the battery may be all you need.
Noel
Howard
Howard,
  ATTENTION!!!
CALLED. GOOD BYE!!
Mike Welch
href="http://www.matronics.com/Navigator?AeroElectric-List">http://www.matronics.com/Navigator?AeroElectric-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Fergus Kyle
PostPosted: Sat May 21, 2011 12:21 pm    Post subject: Key Ignition Switch Reply with quote
The guy beside me figures he has it all OK.
(1) he has a secret spot back behind the cockpit about ¾ of the way up the fuselage (where no magnetic field matters) where he slides his hand up) on mounting the wing. On his hand is secreted a magnetic ring. Inside sits a magnetic slide release which permits the door handle to open.
(2) He uses a racing car emergency cut-off switch (to close the battery circuit) which sits on the firewall.
      He cut a 1/2inch hole up in the corner of the instru panel which permits entry of a wooden rod that emulates the switch key.He figures nobody will have the nouse to work out the system, and all he needs is an 8” wooden rod and a magnetic ring,
I dunno
Ferg. [quote][b]
Page 3 of 3
