Ms Dixie update
Goto page Previous  1, 2, 3
Paul Petty
PostPosted: Tue Jun 05, 2007 1:07 pm    Post subject: Re: Ms Dixie update Reply with quote
Well gang Ms Dixie recived her registration as of today! Only problem is they listed TNK as the MFG and not me so after a phone call they (FAA) said no problem they would make the changes and issue a new registration and send it to me ASAP. I dont know about you guys/gals but once you get them on the phone they are a real pleasure to work with.
Next is moving her to KLUL and let the fun begin!
http://registry.faa.gov/aircraftinquiry/NNumSQL.asp?NNumbertxt=408CP
Paul Petty
Kolbra #12
Ms Dixie
912 UL 70" warp
PostPosted: Tue Jun 05, 2007 1:24 pm    Post subject: Ms Dixie update Reply with quote
Great news Paul!
You and Charley will be flying before you know it.
Good luck,
DO NOT ARCHIVE
Paul Petty
PostPosted: Thu Jun 07, 2007 10:14 am    Post subject: Re: Ms Dixie update Reply with quote
Gang,
I have allways been told the FAA takes forever to do anything. They made the change to the MFG in less than 2 days. Were good to go.
Paul Petty
Kolbra #12
Ms Dixie
912 UL 70" warp
Paul Petty
PostPosted: Mon Jun 11, 2007 10:44 am    Post subject: Re: Ms Dixie update Reply with quote
Ms Dixie gets her N-Number
 Filesize:  56.54 KB
 Viewed:  556 Time(s)
Paul Petty
Kolbra #12
Ms Dixie
912 UL 70" warp
Paul Petty
PostPosted: Thu Jun 14, 2007 11:18 am    Post subject: Re: Ms Dixie update Reply with quote
Well gang if all goes as planned Ms. Dixie will me moved to KLUL Hesler Nobel Field this saturday for Inspection and final tweaking and adjusting. Then some taxi testing sunday! What a fathers day treat ey? I will post photos and video for you all to enjoy if everything goes as planned. Our club is having a fly in and I guess most will be at Homers. Hope you all have a great flight and we hope to be joining you soon! Very Happy
Paul Petty
Kolbra #12
Ms Dixie
912 UL 70" warp
Michael Sharp
PostPosted: Thu Jun 14, 2007 11:38 am    Post subject: Ms Dixie update Reply with quote
Hootie Hoo!!!!!
Congrads!!!
Good Luck and Be Safe!
Paul Petty <paulpetty(at)myway.com> wrote:
[quote]--> Kolb-List message posted by: "Paul Petty"
Paul Petty
Kolbra #12
Ms Dixie
Wating for final inspection and cert.
Read this topic online [quote][b]
The air up there in the clouds is very pure and fine...And why shouldn't it be?-
--It is the same the angels breathe.
Mark Twain,
Roughing it' 1886
Mike
mgerman(at)celestica.com
PostPosted: Fri Jun 15, 2007 4:14 am    Post subject: Ms Dixie update Reply with quote
Hi Paul!!
You have done an outstanding job building your Kolbra! Only you know how much work it has been and in some cases more work then building from scratch. In my option you will have the nicest Kolbra built to date. It has been fun working with you and seeing the completion of the project. Cant wait to see it take flight.
Mark German
912-Kolbra
280-hrs.
Chisago City MN.
"Paul Petty" <paulpetty(at)myway.com>
Sent by: owner-kolb-list-server(at)matronics.com
06/14/2007 02:18 PM Please respond to
kolb-list(at)matronics.com
To
kolb-list(at)matronics.com cc
Subject
Re: Ms Dixie update
--> Kolb-List message posted by: "Paul Petty" <paulpetty(at)myway.com>
Paul Petty
Kolbra #12
Ms Dixie
http://forums.matronics.com/viewtopic.php?p=118460#118460
Paul Petty
PostPosted: Sun Jun 17, 2007 11:39 am    Post subject: Re: Ms Dixie update Reply with quote
Well gang got up at 4:00am and headed to KLUL to work on Ms Dixie in hopes of a first start up after a long time and low and behold at 11:30am with a shaking right hand I turned the key and yelled "CLEAR PROP". With the airplabe tied to the Z71 she came to life and to my releif she stopped when i turned her off! Then I un-tied her and went for my first ride under her own power. The 912 puured nicely and I found my first area of adjustment...the brakes. Glad to report no leaks or problems other than the south mississippi heat. It's like a tanning bed in there! the throttle is the next area of attention as it is super touchy. at no throtle the RPM's drop to 800 and moving the throttle a fraction she jumps to 1800. It's as if she wants to jump into the air. will spen the next few days tweaking and hope to find some improvement.
http://www.youtube.com/watch?v=RQf1WsKJSCI
let me know if the link works or not
regards
Paul Petty
Kolbra #12
Ms Dixie
912 UL 70" warp
Bob Dalton
PostPosted: Sun Jun 17, 2007 12:27 pm    Post subject: Ms Dixie update Reply with quote
Paul,
Video link worked fine, congrats on the startup and taxi!
Bob D.
Bob Dalton
Manteca, Ca.
wiserguy@comcast.net
Paul Petty
PostPosted: Sun Jun 17, 2007 1:49 pm    Post subject: Re: Ms Dixie update Reply with quote
Thanks Bob. got the other video uploaded.
http://www.youtube.com/profile?user=kolbra012
Paul Petty
Kolbra #12
Ms Dixie
912 UL 70" warp
DAquaNut(at)aol.com
PostPosted: Sun Jun 17, 2007 7:10 pm    Post subject: Ms Dixie update Reply with quote
In a message dated 6/17/2007 2:40:32 PM Central Standard Time, paulpetty(at)myway.com writes:
Paul,
Congrats on that first taxi! It probably does not sound exciting to the old timers, but    I only have 40 something hours on the Firefly and remember the excitement with my first taxi. It means your one step farther in the process of getting in the air ! Saver the moment and I anticipate that 1 st flight report. Appearently my 447 decarb turned out OK ,as I have put 3 or 4 hours on it since the decarb and all seems normal .
Be Safe,
Ed Diebel  Do not Archive
See what's free at http://www.aol.com. [quote][b]
Paul Petty
PostPosted: Thu Jun 21, 2007 7:00 pm    Post subject: Re: Ms Dixie update Reply with quote
Well gang went for second taxi test today and found myself more comphy with Ms Dixie. Brakes are better and noises are more fimilar to me now. Amazing how much noise transends from the tail wheel to the cabin. My throttle is one touchy SOB! I need to figure out a way to make it more manageable or just get used to it. kept RPM's above 1500 the whole time and she ran much better. First taxi test was fun second was even better as i went farther out on the ramp and the hold short area and watched a citation land and taxi by me. dialed the pitch back to 10 degrees and that seams to be better. DAR may be here saturday to do inspection and first flight may happen this weekend if things go well. I hope the bigger 6" tail wheel comes in tomorrow so i can get it mounted and see an improvement in ground handeling. Stay tuned.........
Paul Petty
Kolbra #12
Ms Dixie
912 UL 70" warp
Paul Petty
PostPosted: Thu Jun 28, 2007 10:27 am    Post subject: Re: Ms Dixie update Reply with quote
Gang,
Just got word that Ms Dixie is set to get her airworthyness inspection this Saturday at 9:00am.
Will keep you posted
do not archivie
Paul Petty
Kolbra #12
Ms Dixie
912 UL 70" warp
PostPosted: Thu Jun 28, 2007 11:06 am    Post subject: Ms Dixie update Reply with quote
| Paul Petty
Gang:
Is Paul excited??? Naw!!!!!!!!!!!!!!
Good luck Paul. I'll talk to Charlie H before he flies.
DO NOT ARCHIVE
jb92563
PostPosted: Thu Jun 28, 2007 11:22 am    Post subject: Re: Ms Dixie update Reply with quote
Does that mean you can fly this weekend or do you have to wait on paperwork?
Your work is so perfect & meticulous it is simply not possible that it won't get passed.....great job!
Best of Luck!
Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Paul Petty
PostPosted: Thu Jun 28, 2007 2:29 pm    Post subject: Re: Ms Dixie update Reply with quote
Thanks Ray and John....it's nut cucting time now! Im very excited to say the the less
Paul Petty
Kolbra #12
Ms Dixie
912 UL 70" warp
Paul Petty
PostPosted: Sat Jun 30, 2007 2:42 pm    Post subject: Re: Ms Dixie update Reply with quote
Ms. Dixie got her airworthy cert. (at) 1:00pm CST today. Airplane checked out 100% however paper work was not in order. I highly recomend to anyone useing a IA or DAR to request a form of "needed" documents WAY before hand. I had to go find a notary on a Saturday morning to whitness my signature on a paper that states I built the airplane. Not an easy thing to do in a small town but i got-her-done. Next was I had no airframe log book. A MUST in my case and with good luck we found a new un-used one! Most have posted that the check out lasted less than an hour.. mine started at 9:00am and finished at 2:30pm. This was mainly in part to 1. DAR was old flying buddy of Charley and 2 my lack of paperwork. Heck he spent more time drooling over the RV8 than he did checking out the Kolbra. Ken Reeves and Ms. Bobby came over for the event and we had a great visit. It was a long HOT 24 hr day to get her done but we are good to go. BTW Ms. Dixie weighed in at 590lbs Empty... this was a shocking discovery as i was thinking more along the lines of 700 lbs with all the mods. W&B revealed that she is out of CG with full fuel and a 175 pilot solo front seat but were not sold on the numbers given to us and will re check this over closely. Ben a long day and Im' going to shower and soak in the pool for an early start in the morning for a possible "First flight" some time after 08.00 we will see....
Paul Petty
Kolbra #12
Ms Dixie
912 UL 70" warp
Page 3 of 3
