Posted: Fri Jun 20, 2014 4:51 am Post subject: LED Ghosting |
At 07:49 PM 6/19/2014, you wrote:
FisherPaulA(at)johndeere. wrote:
> I'm confused by this thread. Back to the original issue - why is
it important that all of the LEDs in the annunciator panel have the
same brightness?
Valid question.
The master warning panel (I should probably refer to it as an
annunicator panel) also has indicators for when the fuel pump is on
and pitot heat is on (those indicators are amber where the low oil
pressure, door unsafe, etc. are red).
So you're flying along at night and you have the pitot heat or fuel
pump on. The LEDs are rather bright so you dim the indicators. Once
you dim those LEDs to a comfortable brightness, that low oil pressure
LED will not illuminate at all.
That's another concern that we wrestle with in the TC
side of the house . . . visibility in sunlight.
Most DIY annunciators flying in OBAM aircraft would not
been welcome on the panel of a TC aircraft. That's
one of the reasons that TC annunciators are relatively
much more expensive . . . and before LEDs . . . ran HOT
due to the utilization of at least TWO, 1W lamps per
feature. Light up very many slots at the same time and the
legacy incandescent annunciator panel can become quite
warm.
Two-lamps per slot was also a hedge against
lamp failure. The loss of one lamp in an
indicator slot would be noticed during pre-flight
tests but would not KILL the annunciator's ability
to warn.
I think the modern annunciators with more than
one LED are simply concerned with sunlight visibility.
Prospects for putting another L1011 full of people into
the Everglades for lack of a light bulb are pretty much
a thing of the past.
OBAM aviation annunciators achieve sun light
visibility by mounting under a glare shield that
prevents direct exposure to sun . . . or perhaps
it's not high on the builder's list of design goals.
Hopefully tomorrow I will be able to get the voltage readings
requested. I also got the MOSFET today so I'll give that a go as well.
Great!
At 03:15 PM 6/19/2014, you wrote:
<FisherPaulA(at)johndeere.com>
I'm confused by this thread. Back to the original issue - why is it
same brightness? Don't you just need to know if any particular one
is on or off? Aren't they used to indicate a problem? I would hope
that during most flights they would all be off. And if more than
one of them was on, I certainly wouldn't be worried about one being
brighter or dimmer than another - I'd be busy looking for a place to land!
I do appreciate the electronics discussion about the physics of
getting them to the same brightness. I just don't understand why
that is important in this use case.
It's a 'trickle down' from legacy design goals for
most sophisticated aircraft (read - has more than one
red light right next to another on the panel).
Jobs I've had working on 6-figure airplanes catered
to customers who expected such uniformity and a
regulatory agency that expected conformity. But
you're right, the absolute functionality of the
indicator is not diluted by a difference in
purposeful illumination.
The thread was launched when it was discovered that
an engine monitor's oil pressure warning output
presented some light-off leakage that would not
have affected an incandescent lamp's OFF state.
However, still enough to excite those maddingly
efficient LED into visible light output when
they were supposed to be dark . . . again
not so big a deal in daylight but irksome
at night.
The brightness thing didn't bubble up until it
was noticed that 'fixes' for the lamp-off-leakage
also appeared to influence brightness.
That didn't make sense from the perspective of
the electronics . . . but it won't become clear
without more detailed measurements of the various
conditions I posed in the 'grand experiment'
posting . . . which is where the quest for understanding
kind of fizzled.
donjohnston
Posted: Fri Jun 20, 2014 3:34 pm Post subject: Re: LED Ghosting |
Attached are the voltage drops for the LEDs and resistors. The engine analyzer alarm is a flashing warning so it was difficult getting a solid reading. If I missed something, let me know and I'll get it.
Don
LED circuit.pdf |
68.53 KB |
735 Time(s) |
ceengland7(at)gmail.com Guest
Posted: Fri Jun 20, 2014 5:04 pm Post subject: LED Ghosting |
Weren't the LEDs in series? If so, if one fails open, you lose both.
On Fri, Jun 20, 2014 at 7:49 AM, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)> wrote:
[quote]--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
--> AeroElectric-List message posted by: "donjohnston" <don(at)velocity-xl.com (don(at)velocity-xl.com)>
> I'm confused by this thread. Back to the original issue - why is it important that all of the LEDs in the annunciator panel have the same brightness?
Valid question.
The master warning panel (I should probably refer to it as an annunicator panel) also has indicators for when the fuel pump is on and pitot heat is on (those indicators are amber where the low oil pressure, door unsafe, etc. are red).
So you're flying along at night and you have the pitot heat or fuel pump on. The LEDs are rather bright so you dim the indicators. Once you dim those LEDs to a comfortable brightness, that low oil pressure LED will not illuminate at all.
warm.
to warn.
Hopefully tomorrow I will be able to get the voltage readings requested. I also got the MOSFET today so I'll give that a go as well.
Great!
ric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
MS -
e -
donjohnston
Posted: Fri Jun 20, 2014 5:05 pm Post subject: Re: LED Ghosting |
That one string that had different drops was bothering me.
I checked it again but on a different string and got the attached. I'm guessing that one of the LEDs in the first test is a little out of spec.
LED circuit 2.pdf |
69.08 KB |
677 Time(s) |
donjohnston
Posted: Fri Jun 20, 2014 5:43 pm Post subject: Re: LED Ghosting |
| ceengland7(at)gmail.com wrote: | | Weren't the LEDs in series? If so, if one fails open, you lose both. |
I think that assumes incandescent bulbs. The failure rate with LEDs isn't anywhere near what you have with incandescent bulbs.
henador_titzoff(at)yahoo. Guest
Posted: Fri Jun 20, 2014 6:23 pm Post subject: LED Ghosting |
Actually, he's correct, Don. Two LEDs in series will give you a failure rate of Pr1 + Pr2. The only reason I can think of to use two LEDs in series is to get twice the illumination while minimizing resistors. If you put two LEDs in parallel, each one has to have its own resistor to balance (control) the current flow through each one.
If they are in parallel and one LED fails, then at least you'll have half the original illumination to indicate a failed LED. If you accept Pr1 + Pr2 as your failure rate, then it's your choice.
Henador Titzoff
| Quote: | From: donjohnston <don(at)velocity-xl.com> To: aeroelectric-list(at)matronics.com Sent: Friday, June 20, 2014 9:43 PM Subject: Re: LED Ghosting
--> AeroElectric-List message posted by: "donjohnston" <don(at)velocity-xl.com (don(at)velocity-xl.com)>ceengland7(at)gmail.com wrote:> Weren't the LEDs in series? If so, if one fails open, you lose both. I think that assumes incandescent bulbs. The failure rate with LEDs isn't anywhere near what you have with incandescent bulbs.Read this topic online here:http://forums.matronics.com/viewtopic.php?p=425185#425185http://www.matronics.com/Navigator?AeroElectric-Listhttp://www.matro=
donjohnston
Posted: Sat Jun 21, 2014 3:42 am Post subject: Re: LED Ghosting |
| henador_titzoff(at)yahoo. wrote: | Actually, he's correct, Don. Two LEDs in series will give you a failure rate of Pr1 + Pr2. The only reason I can think of to use two LEDs in series is to get twice the illumination while minimizing resistors. If you put two LEDs in parallel, each one has to have its own resistor to balance (control) the current flow through each one.
Henador Titzoff
I'm using two LEDs for brightness and reducing the resistor. I am well aware that a failure of one LED will result in a failure of indication.
Thank you.
donjohnston
Posted: Sat Jun 21, 2014 4:37 am Post subject: Re: LED Ghosting |
Attached is my plan for implementing the MOSFET. I have a feeling (given the voltage at S is going to be pretty much non-existent) that the 12v connection to G is going to be needed.
MOSFET.pdf |
29.86 KB |
627 Time(s) |
Posted: Sat Jun 21, 2014 5:42 am Post subject: Re: LED Ghosting |
The the brightness problem will likely be solved by the MOSFET transistor as long as it does not drop much voltage. If it doesn't work out and it is desired not to use a relay, then another option is to make the other LED circuits drop the same same voltage as the Engine Analyzer Alarm solid state switch, which is 1.5 to 1.6 volts according to your voltage measurements. An easy way to drop that voltage is to add a red LED in series to the other annunciator circuits. Then each LED circuit will have the same voltage drop.
_________________ Joe Gores |
Posted: Sat Jun 21, 2014 6:08 am Post subject: Re: LED Ghosting |
The output of the Engine Analyzer Alarm should not be connected directly to positive voltage because it will be a short circuit. Connect a 10K resistor between the gate and source instead.
The dimmer output should be connected directly to the MOSFET source. The load (LEDs and resistor) should be connected between the drain and ground.
A zener diode (15 to 20 volts) could be connected between the gate and source to protect the MOSFET against voltage spikes.
Someone please correct me if I am wrong. I do not want to give bad advice.
sprocket(at)vx-aviation.c Guest
Posted: Sat Jun 21, 2014 6:24 am Post subject: LED Ghosting |
The inherent inversion of this circuit will turn the lamp on when the EMS
turns it off... not so good.
Vern
donjohnston
Posted: Sat Jun 21, 2014 6:51 am Post subject: Re: LED Ghosting |
| user9253 wrote: | The output of the Engine Analyzer Alarm should not be connected directly to positive voltage because it will be a short circuit. Connect a 10K resistor between the gate and source instead.
Someone please correct me if I am wrong. I do not want to give bad advice. |
I probably mis-interpreted the original suggestion. Thanks for the correction.
| user9253 wrote: | | If it doesn't work out and it is desired not to use a relay, then another option is to make the other LED circuits drop the same same voltage as the Engine Analyzer Alarm solid state switch, which is 1.5 to 1.6 volts according to your voltage measurements. An easy way to drop that voltage is to add a red LED in series to the other annunciator circuits. Then each LED circuit will have the same voltage drop. |
That was my original backup plan. I thought that there would be a better solution.
And this is on a PCB. I have a little flexibility (adding a resistor or two), but adding another LED wouldn't work.
Posted: Sat Jun 21, 2014 7:11 am Post subject: Re: LED Ghosting |
| Quote: | | this is on a PCB. I have a little flexibility (adding a resistor or two), but adding another LED wouldn't work. |
I did not mean to locate a red LED next to the other LEDs. I meant to add a red LED on the circuit board, out of sight. It can mounted as easily as a resistor. Red LEDs have about the same voltage drop as the Engine Analyzer Alarm, which is about 1.5 volts. With each LED circuit dropping the same voltage, they should have the same brightness, in theory anyway. I have never built this circuit.
edpav8r(at)yahoo.com Guest
Posted: Sat Jun 21, 2014 7:31 am Post subject: LED Ghosting |
Don & Joe,
I think this is a case of there being more than one way to skin a cat. Joe is just changing the MOSFET from a low-side to a high-side switch, which will work fine as well.
The gate zener isn't a bad idea (it will protect the gate against wild voltage excursions on the bus), but is probably unnecessary; this MOSFET will tolerate a 30V difference between gate and source. For the same reason, it's safe to use 12V as gate pull-up (through a resistor!) instead of the variable dimmer output. Again, pay your money and take your choice.
Definitely heed Joe's advice re *not* tying the gate directly to 12V. This would probably not end well for your engine analyzer's alarm circuit!
I've attached a diagram of my suggestion. Let me know if it doesn't come through.
Eric
On Jun 21, 2014, at 7:08 AM, "user9253" <fransew(at)gmail.com (fransew(at)gmail.com)> wrote:
| Quote: | The output of the Engine Analyzer Alarm should not be connected directly to positive voltage because it will be a short circuit. Connect a 10K resistor between the gate and source instead.
Joe Gores
Oil_Press_Alarm_Ckt.pdf |
5.16 KB |
569 Time(s) |
Posted: Sat Jun 21, 2014 10:08 am Post subject: Re: LED Ghosting |
To turn on a P-channel MOSFET, a negative voltage must be applied to the gate with respect to the source. If the load is connected between the source and positive supply, then the source is positive when the MOSFET is off. But as soon as the MOSFET starts to conduct, the source will then become negative and the gate is no longer negative in respect to the source. The MOSFET will then shut off, (if it ever actually turned on)
Here is a website that shows how N-Channel and P-Channel MOSFETs are wired. http://electronics.stackexchange.com/questions/3599/basic-p-type-mosfet-question
donjohnston
kleh(at)dialupatcost.ca Guest
Posted: Sat Jun 21, 2014 11:17 am Post subject: LED Ghosting |
If Radio Shack still sells the paperback comic style books by Forrest
Mimms III, there is a great go to book for simple circuits "Getting
Started in Electronics" cat.No. 276-5003. My copy was $3.59 years ago
and as an occasional hobbyist I often refer to it when starting a new
project. Highly recommended for understanding and wiring this circuit.
Ken
On 21/06/2014 2:31 PM, donjohnston wrote:
Unfortunately, I am way outside my element. Not quite sure how to wire this sucker now.
raymondj(at)frontiernet.n Guest
Posted: Sat Jun 21, 2014 12:14 pm Post subject: LED Ghosting |
Just finished reading it, I second the recommendation.
Raymond Julian
Kettle River, MN
The things we admire in men, kindness and generosity, openness, honesty,
understanding and feeling are the concomitants of failure in our system.
And those traits we detest, sharpness, greed, acquisitiveness, meanness,
egotism and self-interest are the traits of success. And while men
admire the quality of the first they love the produce of the second.
-John Steinbeck, novelist, Nobel laureate (1902-1968)
On 06/21/2014 02:13 PM, Ken wrote:
Ken
Posted: Sat Jun 21, 2014 12:40 pm Post subject: LED Ghosting |
Gents,
Sorry, I was apparently groggy this morning and had N and P-channel devices mixed up in my head. Joe is absolutely correct; please ignore my earlier diagram. I'm not at my computer and won't be for several days, so I can't make a new one. I'll try to explain it in words...
1. Connect dimmer output directly to MOSFET source.
2. At MOSFET drain, install current limiting resistor and LEDs in series, with the last LED connected to ground.
3. Install a pull-up resistor of 10-100k between MOSFET gate and source.
4. Connect engine analyzer alarm output to MOSFET gate.
So, two connections at source: dimmer output and pull-up resistor. One connection at drain: resistor and LED string. Two connections at gate: pull-up resistor and alarm output.
Hope that's understandable. Best I can do standing in an airport terminal waiting to board...
Cheers, and sincere apologies for causing so much confusion! Thank you, Joe. Good to have smart guys QC-ing everything on here.
Eric
On Jun 21, 2014, at 11:09 AM, "user9253" <fransew(at)gmail.com> wrote:
| Quote: | To turn on a P-channel MOSFET, a negative voltage must be applied to the gate with respect to the source. If the load is connected between the source and positive supply, then the source is positive when the MOSFET is off. But as soon as the MOSFET starts to conduct, the source will then become negative and the gate is no longer negative in respect to the source. The MOSFET will then shut off, (if it ever actually turned on)
Joe Gores
