Fuel Flow Transducer Move
Goto page Previous  1, 2
jump2(at)sbcglobal.net
PostPosted: Thu Sep 24, 2009 11:24 pm    Post subject: Fuel Flow Transducer Move Reply with quote
That big old red hose goes to, you guessed it, the fuel pump on another engine I changed on a super Decath this year. There must be a reason for these things.
So I might think about putting a good cooling hose to help out on cooling fuel.
Patrick Thyssen
--- On Thu, 9/24/09, Patrick Thyssen <jump2(at)sbcglobal.net> wrote:
Subject: RE: Re: Fuel Flow Transducer Move
Date: Thursday, September 24, 2009, 10:17 PM
One thing I have just thought about and correct me if I'm wrong. From the fuel pump to the fuel pressure sending unit is up hill or above the fuel pump. This being said if you get air in your hoses going to your pressure transducer from being hot [vapor] then you could have a problem as to what it is reporting.
By having a compression of air instead of solid liquid.
Lets hear from the engineers.
Patrick Thyssen
Engine pickled again!!! for new instrument panel
 Oh how I love OP
--- On Thu, 9/24/09, McGann, Ron <Ron.McGann(at)thalesgroup.com.au> wrote:
From: McGann, Ron <Ron.McGann(at)thalesgroup.com.au>
Date: Thursday, September 24, 2009, 5:28 PM
--> RV10-List message posted by: "McGann, Ron" <Ron.McGann(at)thalesgroup.com.au>
Only 40 hours but same experience as Marcus. Only irregluarity comes
when the boost pump is engaged but the totaliser function always appears
to reflect remaining fuel to within a gallon or so.
Ron McGann
Head of Engineering
Security Solutions & Services
Aerospace
Tel: +61 2 9562 3530 | Mob: +61 (0) 466 655 393 | Fax: +61 2 9562 2100
 Filesize:  1.59 MB
 Viewed:  6893 Time(s)
PostPosted: Thu Sep 24, 2009 11:36 pm    Post subject: Fuel Flow Transducer Move Reply with quote
Here is another picture of a fuel pump on M7-235 Maule I changed earlier this year. big red hose for airconditioning of fuel pump.
Patrick Thyssen
Subject: RE: RV10-List: Re: Fuel Flow Transducer Move
Patrick Thyssen
Oh how I love OP
Ron McGann
Head of Engineering
Aerospace
 Filesize:  2.09 MB
partner14
PostPosted: Fri Sep 25, 2009 4:13 am    Post subject: Fuel Flow Transducer Move Reply with quote
Ditto.
Don McDonald
Date: Thursday, September 24, 2009, 9:49 AM
--> RV10-List message posted by: "Rene Felker" <rene(at)felker.com (rene(at)felker.com)>
I left mine in the standard position. I see very minor fluctuations....I do
not think it is a problem.
Rene' Felker
RV-10 N423CF Flying
801-721-6080
Don A. McDonald
40636
wcurtis(at)nerv10.com
PostPosted: Fri Sep 25, 2009 5:27 am    Post subject: Fuel Flow Transducer Move Reply with quote
Patrick,
Which statement(s) do you stand by?
-Reading a 12 year old publication from JPI which documents the installation of a Flowscan transducer, NOT an EI red cube transducer?
-Not using sealant on NPT fittings? ---really? why do you and JPI suggest not using sealant on NPT fittings?
-Use of aluminum fittings on the transducer?  You do realize that the EI red cube transducer is made of aluminum, right?
Because I said I did not read the JPI manual, does not mean I did not read the EI or AFS installation manuals which are MUCH more updated.  Why don't YOU take a look at the EI installation manual.  You will find no such admonishment on using aluminum or 90 degree fittings.  In fact, on page 5 you will see 45 degree and 90 degree fittings as approved for installation with the red cube.  Here is a link to the EI fuel flow installation instructions.
http://buy-ei.com/Information/II%20-%20FP-5.pdf
William
http://wcurtis.nerv10.com
On Thu, Sep 24, 2009 at 10:40 PM, Patrick Thyssen <jump2(at)sbcglobal.net (jump2(at)sbcglobal.net)> wrote:
[quote]  I'LL STAND BY MY STATEMENT WITH THE ADDED INSERT, EI MAKE INSTALLATION MANUALS ALSO. THEY REFERENCE AC43-13 ALSO. YOUR LOSS FOR NOT READING EVERYTHING YOU CAN. YOU WOULD LEARN A LOT MORE.
 PATRICK THYSSEN
--- On Thu, 9/24/09, William Curtis <wcurtis(at)nerv10.com (wcurtis(at)nerv10.com)> wrote:
From: William Curtis <wcurtis(at)nerv10.com (wcurtis(at)nerv10.com)>
Subject: Re: Re: Fuel Flow Transducer Move
Date: Thursday, September 24, 2009, 3:10 PM
Guess you did not read the caption above the photo regarding the aluminum fitting.  NPT fittings benefit from sealant, AN fittings do not.  The inlet to the flow transducer is NPT.  As far as the 90 degree fitting out from the transducer, well that's what I have now on the Cardinal and it works just fine.  The instrument I have in the Cardinal is Electronics International, the OEM for the "red cube" transducer so no, I never read nor plan to read the JPI manual.
William
http://wcurtis.nerv10.com/
On Thu, Sep 24, 2009 at 2:47 PM, Patrick Thyssen <jump2(at)sbcglobal.net> wrote:
Question, Why the teflon tape or pipe sealent? Why aluminum fitting into the transducer?
JP instruments and I suggest never ever use that stuff on the transducer. And it would be a lot better if you had a straight out fitting from the transducer. Not the ninety. Good book to read Is the JPI installation manual. I think it''s the second page where it says, read this first.
But that just my opinion and we all have one.
 Patrick Thyssen
But then I too made a mistake and bought OP Equiptment And now I'm fixing that.
Dual 430w and garmin G500. Now I know they will work.
Date: Thursday, September 24, 2009, 11:56 AM
I think the general consensus is that is works fine in the standard location (tunnel) if you can accept some variability in flow indications when the electric fuel pump is on.  With that being said, mine sits BEFORE the flow divider on top of the air box in the picture below.  It is not flying yet but in my Cardinal it is AFTER the mechanical fuel pump BEFORE the servo and very stable.
http://wcurtis.nerv10.com/90Electrical/EL2g.html
William
On Thu, Sep 24, 2009 at 12:05 PM, Nick Leonard <nick(at)nleonard.com> wrote:
--> RV10-List message posted by: "Nick Leonard" <nick(at)nleonard.com>
As an informal survey for the rest of us, it would be interesting to get feedback from those that have left it where Van's originally suggested.  Are any of you having any trouble with the transducer in that location?
How many people have moved the unit because of inaccurate readings or other problems?
Nick Leonard
RV-10 (40015) Finish
http://forums.matronics.com/viewtopic.php?p=264706#264706
t Un/Subscription,
www.matronics.com/Navigator?RV10-List" target="_blank">http://www.matronics.com/Navigator?RV10-List
Matt Dralle, List Admin.
http://www.matronics.com/Navigator?RV10-Lisk" href="http://forums.matronics.com">http://forums.matronics.com
gt; [/url]
get="_blank">[url=http://www.matronics.com/Navigator?RV10-List]http://www.matronics.com/Navigator?RV10-Listttp://forums.matronics.com
msausen
PostPosted: Fri Sep 25, 2009 7:10 am    Post subject: Fuel Flow Transducer Move Reply with quote
You can get a similar cooling shroud for the pump on the 360/540 series from here….
http://www.aircraftspruce.com/catalog/eppages/fuelpumps.php
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Patrick Thyssen
Sent: Friday, September 25, 2009 2:35 AM
Patrick Thyssen
Patrick Thyssen
Oh how I love OP
Ron McGann
Head of Engineering
Aerospace
Tim Olson
PostPosted: Fri Sep 25, 2009 8:34 am    Post subject: Fuel Flow Transducer Move Reply with quote
I've got one of those. Haven't installed it yet, but I have it.
Some day if I get real bored or ambitious, I'll put it on
and report back. Maybe years from now. I know if I ever pull
the engine I'll install it, but not sure if I will otherwise.
Tim Olson - RV-10 N104CD
RV Builder (Michael Sausen) wrote:
[quote] You can get a similar cooling shroud for the pump on the 360/540 series
from here….
Michael
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Patrick Thyssen
*Sent:* Friday, September 25, 2009 2:35 AM
*To:* rv10-list(at)matronics.com
*Subject:* RE: Re: Fuel Flow Transducer Move
Patrick Thyssen
Patrick Thyssen
Oh how I love OP
--- On *Thu, 9/24/09, McGann, Ron /<Ron.McGann(at)thalesgroup.com.au>/* wrote:
Ron McGann
Head of Engineering
Aerospace
PostPosted: Sat Sep 26, 2009 6:39 pm    Post subject: Fuel Flow Transducer Move Reply with quote
Tim,
Thats not exactly right. when you have fuel or liquid mix with vapor or air,pass by a volume of air you will see a change in pressure due to the compression of the air. That's why you see fluxuation in pressure gauges.
If you worked in the oil and gas business you see this all the time in pipelines. If you look at a trouble shooting manual for this, one of the reasons you see fluxuation in gauges due to vapor in the line and one of the first thing it tells you is to get the air out.
So what I was getting at is the gas(vapor) is getting into the line going to the gauge so as other vapor mixed with fuel passes by your gauge line it changes press due to compression of the vapor.
Patrick Thyssen
still learning
Date: Thursday, September 24, 2009, 11:41 PM
--> RV10-List message posted by: Tim Olson <[url=/mc/compose?to=Tim(at)myrv10.com]Tim(at)myrv10.com[/url]>
Pressure is pressure, it's just the compressibility that is
different. If the vapor were at 50psi, it would push
down on the fuel at 50psi, and up on the fuel pressure
sender at 50psi, and the fuel would transfer that pressure
to the engine at 50psi.  Doesn't matter if it's vapor, or
what is in the line...it's just a diaphragm that is
displaying pressure. Think of a manometer..it's using
air and liquid to show air pressure, but inside the
manometer is both air and liquid. It's all the same when
it's pushing out against something else. If you have a
pot of steaming water and you plug it, the steam will
build up pressure, and if you puncture the bottom of
the pot, the water will come out at whatever pressure
the steam is at.
So no, it shouldn't have an effect on the pressure reading.
Patrick Thyssen wrote:
[quote] One thing I have just thought about and correct me if I'm wrong. From the fuel pump to the fuel pressure sending unit is up hill or above the fuel pump. This being said if you get air in your hoses going to your pressure transducer from being hot [vapor] then you could have a problem as to what it is reporting.
Patrick Thyssen
Oh how I love OP
--- On *Thu, 9/24/09, McGann, Ron /<[url=/mc/compose?to=Ron.McGann(at)thalesgroup.com.au]Ron.McGann(at)thalesgroup.com.au[/url]>/* wrote:
From: McGann, Ron <[url=/mc/compose?to=Ron.McGann(at)thalesgroup.com.au]Ron.McGann(at)thalesgroup.com.au[/url]>
To: [url=/mc/compose?to=rv10-list(at)matronics.com]rv10-list(at)matronics.com[/url]
Ron McGann
Head of Engineering
  Aerospace
Kelly McMullen
PostPosted: Sat Sep 26, 2009 7:07 pm    Post subject: Fuel Flow Transducer Move Reply with quote
There are only two ways to get vapor. Either the line is hot enough to
vaporize fuel...only going to happen at low power, or if you have a
leak and are sucking air into the line. If the line is sealed, at high
power you will not have any fluctuations because the flow is
sufficient to keep the lines cool. The line from the spider to the
fuel pressure sending unit is sealed, and it will make little
difference whether it contains air or fuel, other than speed of
response.
On Sat, Sep 26, 2009 at 10:29 PM, Patrick Thyssen <jump2(at)sbcglobal.net> wrote:
Tim,
Patrick Thyssen
still learning
the steam is at.
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
Tim Olson
PostPosted: Sat Sep 26, 2009 7:14 pm    Post subject: Fuel Flow Transducer Move Reply with quote
Sure, but when the air is compressing and expanding, the pressure of the liquid is changing too....it's not staying steady. So if the gas expands and causes a pressure rise, the fuel pressure will go up too. The vapor may cause the gauge to move up and down but the fuel pressure is changing then too.
Tim
On Sep 26, 2009, at 9:29 PM, Patrick Thyssen <jump2(at)sbcglobal.net (jump2(at)sbcglobal.net)> wrote:
[quote]Tim,
Patrick Thyssen
still learning
--- On Thu, 9/24/09, Tim Olson <Tim(at)MyRV10.com (Tim(at)MyRV10.com)> wrote:
From: Tim Olson <Tim(at)MyRV10.com (Tim(at)MyRV10.com)>
To: [url=mailto:rv10-list(at)matronics.com]rv10-list(at)matronics.com (rv10-list(at)matronics.com)[/url]
--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
the steam is at.
Patrick Thyssen
Oh how I love OP
--- On *Thu, 9/24/09, McGann, Ron /<Ron.McGann(at)thalesgroup.com.au (Ron.McGann(at)thalesgroup.com.au)>/* wrote:
From: McGann, Ron <Ron.McGann(at)thalesgroup.com.au (Ron.McGann(at)thalesgroup.com.au)>
Ron McGann
Head of Engineering
Aerospace
PostPosted: Sun Sep 27, 2009 5:15 am    Post subject: Fuel Flow Transducer Move Reply with quote
Tim,
Yes but it at different rates. you have the factor that the fluid is moving out to the injector giving relief ever so slightly as the vapor hits a open area bigger then it was in, allowing it to expand then having to compress again as per fluid takes less time to compress.
So my conclusion is , get air out of the lines. Everyone who has fluxuation in their pressure gauges should check for air in their lines to their transducers.
Patrick Thyssen
To: "rv10-list(at)matronics.com" <rv10-list(at)matronics.com>
Date: Saturday, September 26, 2009, 10:09 PM
Tim
On Sep 26, 2009, at 9:29 PM, Patrick Thyssen <[url=/mc/compose?to=jump2(at)sbcglobal.net]jump2(at)sbcglobal.net[/url]> wrote:
[quote]Tim,
Patrick Thyssen
still learning
--- On Thu, 9/24/09, Tim Olson <[url=/mc/compose?to=Tim(at)MyRV10.com]Tim(at)MyRV10.com[/url]> wrote:
From: Tim Olson <[url=/mc/compose?to=Tim(at)MyRV10.com]Tim(at)MyRV10.com[/url]>
the steam is at.
Patrick Thyssen
Oh how I love OP
Ron McGann
Head of Engineering
 Aerospace
Kelly McMullen
PostPosted: Sun Sep 27, 2009 7:44 am    Post subject: Fuel Flow Transducer Move Reply with quote
Totally unnecessary. You aren't going to detect the fraction of a second difference. The only place air makes a difference is in the lines to/from the fuel servo and injectors. Unless you have a leak, will only be there during startup/taxi from a hot start. The fluctuations at the transducer have nothing to do with whether the line to the spyder has air or liquid. You are confusing pulsation in the fuel FLOW gauge with a pressure pulsation in the fuel pressure, which is very unlikely. Flow pulsations have to do with the fuel pump and placement of the transducer and virtually nothing to do with pressure.
On Sun, Sep 27, 2009 at 9:02 AM, Patrick Thyssen <jump2(at)sbcglobal.net (jump2(at)sbcglobal.net)> wrote:
[quote] Tim,
Patrick Thyssen
To: "rv10-list(at)matronics.com (rv10-list(at)matronics.com)" <rv10-list(at)matronics.com (rv10-list(at)matronics.com)>
Tim
On Sep 26, 2009, at 9:29 PM, Patrick Thyssen <jump2(at)sbcglobal.net> wrote:
[quote] Tim,
Patrick Thyssen
still learning
To: [/url][url=http://mc/compose?to=rv10-list(at)matronics.com]rv10-list(at)matronics.com
--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com>
the steam is at.
Patrick Thyssen
  Oh how I love OP
>     To: rv10-list(at)matronics.com
     Ron McGann
     Head of Engineering
     Aerospace
[quote]     --
Kelly McMullen
KCHD
PostPosted: Sun Sep 27, 2009 8:55 am    Post subject: Fuel Flow Transducer Move Reply with quote
This is my last Question, Where is your fuel pressure coming off. Is it the spider or the fuel pump? I believe most are coming from their fuel pump on the rv10.
Patrick Thyssen
Date: Sunday, September 27, 2009, 10:42 AM
On Sun, Sep 27, 2009 at 9:02 AM, Patrick Thyssen <[url=/mc/compose?to=jump2(at)sbcglobal.net]jump2(at)sbcglobal.net[/url]> wrote:
[quote] Tim,
Patrick Thyssen
Subject: Re: RV10-List: Re: Fuel Flow Transducer Move
To: "rv10-list(at)matronics.com (rv10-list(at)matronics.com)>
Tim
[quote] Tim,
Patrick Thyssen
still learning
the steam is at.
Patrick Thyssen
Oh how I love OP
Ron McGann
Head of Engineering
  Aerospace
[quote] --
PostPosted: Sun Sep 27, 2009 9:44 am    Post subject: Fuel Flow Transducer Move Reply with quote
Correction, I'm not talking about your fuel flow transducer I'm talking about fuel pressure transducer. The line from pump runs uphill and vapor does not travel down hill in a closed end line.
Patrick Thyssen
Date: Sunday, September 27, 2009, 11:50 AM
Patrick Thyssen
On Sun, Sep 27, 2009 at 9:02 AM, Patrick Thyssen <jump2(at)sbcglobal.net> wrote:
[quote] Tim,
Patrick Thyssen
Tim
[quote] Tim,
Patrick Thyssen
still learning
the steam is at.
Patrick Thyssen
Oh how I love OP
Ron McGann
Head of Engineering
Aerospace
[quote] --
PostPosted: Sun Sep 27, 2009 10:13 am    Post subject: Fuel Flow Transducer Move Reply with quote
On the RV-10, the standard location for the fuel pressure indication is from the output side of the engine driven pump.  In other aircraft, such as my C177RG, the fuel pressure indication is taken off the spider.
William
On Sun, Sep 27, 2009 at 12:50 PM, Patrick Thyssen <jump2(at)sbcglobal.net (jump2(at)sbcglobal.net)> wrote:
[quote] This is my last Question, Where is your fuel pressure coming off. Is it the spider or the fuel pump? I believe most are coming from their fuel pump on the rv10.
Patrick Thyssen
--- On Sun, 9/27/09, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
From: Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)>
[quote] Tim,
Patrick Thyssen
Tim
[quote] Tim,
Patrick Thyssen
still learning
the steam is at.
Patrick Thyssen
  Oh how I love OP
     Ron McGann
     Head of Engineering
[quote]     Aerospace
Kelly McMullen
PostPosted: Sun Sep 27, 2009 11:55 am    Post subject: Fuel Flow Transducer Move Reply with quote
Neither one, actually. Comes off of the fuel servo right behind the
inlet connection, so it is the pressure the servo sees.
Any air in the line would tend to dampen pulsations, not cause them.
On Sun, Sep 27, 2009 at 12:50 PM, Patrick Thyssen <jump2(at)sbcglobal.net> wrote:
Patrick Thyssen
Kelly McMullen
KCHD
Page 2 of 2
