jkreidler
Joined: 13 Feb 2008 Posts: 151 Location: Sheboygan Falls WI
Posted: Mon Aug 17, 2009 9:15 am Post subject: Re: Fuel Flow variations |
We have the 'bulb' from Matt installed in the tunnel. Unfortunately it has not eliminated variations with the boost pump turned on and off. There is room for it, no pictures available though, sorry.
We are at the very same point you are Deems, in fact we are probably fighting the same battles. I would give strong consideration before increasing the volume of fuel of air any more than absolutely needed in the tunnel. Any increase might invite the fuel to get warmer, and increase the chance of vapor issues. I say this because the tunnel is fairly warm, and with fuel boiling at ~125 degrees F, you can see the tunnel heat may be enough to create vapor already in the tunnel, long before it gets on top of the engine. Juts my 2 cents....
What is your spread while trying to lean? While performing the 'lean' test we nearly shut down the engine, not comfortable at all. Next step is to swap out the high and low injectors to see if we can get closer, or at least consistent. I do know the engine starts to run rough below 13.4 GPH at 65%, we need to do better than that!
Jason Kreidler
Deems Davis
Posted: Mon Aug 17, 2009 9:24 am Post subject: Fuel Flow variations |
Linn As I understand the purpose of balancing injectors is to match fuel
flow to EGTs. so that each cylinder is ba;anced at close to the same
temps and fuel flows. Attached is the document I received from D. Rivera
(at) airflow performance regarding his recommended process for balancing
injectors. It required both EGT and GPH data.
Deems Davis N519PJ
http://deemsrv10.com/index.html
Linn Walters wrote:
I may be wrong here, but I don't think you get any valuable info from
fuel flow when trying to match injectors. The data point is EGT
...... which you work towards balancing the readings.
What info do you get from fuel flow in this scenario?
Linn
Nozzle_Tuning_Data.doc |
25 KB |
383 Time(s) |
rv10builder(at)verizon.ne Guest
Posted: Mon Aug 17, 2009 9:37 am Post subject: Fuel Flow variations |
The space issue is me Deems- getting the tube from the pump to the sensor is
about 5-6 inches but the adaptors take a good 1 inch from that so if I
needed to put a "t" in there for the bulb I would have no space for all the
adaptors and such to work- it would be very difficult anyway. Certainly not
worth that effort. If I needed to do it, which I wont, I would simply move
the whole sensor to the front per the numerous feedback to that
effectiveness.
Pascal
Sent: Monday, August 17, 2009 9:32 AM
Subject: Re: Fuel Flow variations
Thanks to all for their responses on this topic.
What's driving me on this, is that I want to balance my injectors so I can
begin to play with LOP, and I'd like to have a more stable measurement
when collecting the data for the injectors. Thanks to the link on Matt's
bulb. I've got an email into him with some questions. Has anyone had any
experience with this? I'm just wondering if this is one of those thing
that should work i theory, but..... ? Also someone mentioned a lack of
space to install. I've asked Matt for dimensions. If it works this might
be the easiest 'fix'. We'll see,
Deems Davis N519PJ
bcondrey
Posted: Mon Aug 17, 2009 9:39 am Post subject: Fuel Flow variations |
More info on the subject - here's the GAMI lean test.
http://www.gami.com/gamijectors/leantest.php
Bob
N442PM
Posted: Mon Aug 17, 2009 9:45 am Post subject: Fuel Flow variations |
OK, I understand ..... the delta fuel flow rate gives Airflow
Performance an idea of how much to change the injector size. They can
also do that with just the EGT spread, but I guess that would be the
second best way. <GR>
When I get to that point, I'll be going down the same road ..... but I
need to know where to move the sensor to while it's relatively accessible!
Linn
Deems Davis wrote:
| Quote: | Linn As I understand the purpose of balancing injectors is to match fuel
Deems Davis N519PJ
> Linn
Tim Olson
Posted: Mon Aug 17, 2009 10:14 am Post subject: Fuel Flow variations |
You need to know how far apart in flow the injectors are when you peak
each one. I'M about ready to put out a blurb on that one after I'm
back from vacation.
Tim
On Aug 17, 2009, at 9:55 AM, Linn Walters <pitts_pilot(at)bellsouth.net>
wrote:
from fuel flow when trying to match injectors. The data point is
EGT ...... which you work towards balancing the readings.
Linn
> so I can begin to play with LOP, and I'd like to have a more stable
> measurement when collecting the data for the injectors. Thanks to
> the link on Matt's bulb. I've got an email into him with some
> questions. Has anyone had any experience with this? I'm just
> wondering if this is one of those thing that should work i theory,
> but..... ? Also someone mentioned a lack of space to install. I've
> asked Matt for dimensions. If it works this might be the easiest
> 'fix'. We'll see,
> Deems Davis N519PJ
Ron.McGann(at)thalesgroup Guest
Posted: Mon Aug 17, 2009 2:42 pm Post subject: Fuel Flow variations |
Watching this thread with GREAT interest.
I have consistently higher CHT on Cylinder #2 compared to the rest (when
running rich), with consequentially greater EGT. I have trimmed the fwd
air dam, but it makes little difference. Once running lean of peak, CHT
#2 is lower than the rest. Suggests to me that I have a restriction in
either the line or nozzle to the #2 cylinder. I am a philistine in all
things related to the engine. How do you go about adjusting or changing
the nozzles? Is this something an engine shop should be looking at??
Cheers
Ron
VH-XRM
speckter(at)comcast.net Guest
Posted: Mon Aug 17, 2009 3:20 pm Post subject: Fuel Flow variations |
It is very easy to get a little crud in the injector nozzles. Disconnect
the fuel line from #2 injector and turn on the fuel pump with the throttle
partly in to flush out the line. Remove the injector from the cylinder and
carefully disassemble the unit to clean it with and air line. It is very
difficult to actually see the crud in an injector, but after cleaning they
work much better.
Gary Specketer
dlm46007(at)cox.net Guest
I called Lycon to confirm my expectations of normal. I asked what should we
expect for EGT range and CHT range for any given power setting. Assuming
relatively new manufactured engine with new cylinders (not overhauled ,
welded, oversized, etc) one can expect the EGT range of 75 F and the CHT
range should be 50 F. Each change of MP will may cause a different cylinder
to have the peak temperature. Cylinders manufactured prior to say 2000 will
probably repaired and the repairs will change the temperature and pressure
characteristics. The implication of this is that if your EGTs or CHTs for a
given stabilzed power setting fall outside of these norms then , perhaps,
additional investigation is warranted, if not you may be chasing problems
that don't exist.
RobHickman(at)aol.com Guest
Posted: Mon Aug 17, 2009 4:08 pm Post subject: Fuel Flow variations |
In both my RV-4 and RV-10 I ended up moving the flow transducer to the line between the Fuel Servo and distribution block on the top of the engine. This location has completely eliminated any difference in displayed fuel flow when the boost pump is on or off. This is also the location that most certified aircraft have you install the transducer.
You want all the cylinders to peak at exactly the same fuel flow.
Rob Hickman
N402RH RV-10
ricksked(at)embarqmail.co Guest
Bob Turner
Posted: Mon Aug 17, 2009 5:21 pm Post subject: Re: Fuel Flow variations |
Ron, Have you tried the coke bottle test?
Pull the injectors off the cylinders, direct their output to individual bottles. Turn on the boost pump, fill the bottles half full or so. If #2's bottle is not up to the same level as the others, there's a restriction somewhere.
_________________ Bob Turner
RV-10 QB |
Posted: Mon Aug 17, 2009 5:52 pm Post subject: Fuel Flow variations |
Awesome - thanks for the responses!
Thanks for this one Bob - I'll give it a try on the weekend!
Ron
VH-XRM in Oz
Kelly McMullen
Posted: Mon Aug 17, 2009 6:14 pm Post subject: Fuel Flow variations |
I hear that some guy named Cox kind of messed with it. Lucky it doesn't have Horizon painted on the side.
On Mon, Aug 17, 2009 at 5:20 PM, Rick Sked <ricksked(at)embarqmail.com (ricksked(at)embarqmail.com)> wrote:
Mine is in the stock location and for whatever reason it's constant and steady....Rob I meant to ask you, I love your paint scheme....Did you get that from the US postal service??
Rick Sked
N246RS
A&P/IA, EAA Tech Counselor
KCHD |
robhickman(at)aol.com Guest
Posted: Mon Aug 17, 2009 8:12 pm Post subject: Fuel Flow variations |
We are still trying to figure out where the painter came up with the scheme, Â he does drink a lot of Coors Light. Â We will have to see if the mountains show up when it gets cold.
Rob Hickman
N402RH Â RV-10
partner14
Joined: 12 Jan 2008 Posts: 540 Location: Granbury Texas
Posted: Mon Aug 17, 2009 10:22 pm Post subject: Fuel Flow variations |
Apparently I missed this one,,,, where's a pic of Rob's 10..... Rob if you're tuned in,,,, are you going to be in Independence next week for the flyin? We're going to try and make it.
Don
--- On Mon, 8/17/09, robhickman(at)aol.com <robhickman(at)aol.com> wrote:
From: robhickman(at)aol.com <robhickman(at)aol.com>
Date: Monday, August 17, 2009, 9:09 PM
We are still trying to figure out where the painter came up with the scheme, he does drink a lot of Coors Light. We will have to see if the mountains show up when it gets cold.
Rob Hickman
N402RH RV-10
_________________ Don A. McDonald
40636 |
