Automotive blade fuses?
Goto page Previous  1, 2
peterlaurence6(at)gmail.c
PostPosted: Tue Jul 14, 2009 9:36 am    Post subject: Automotive blade fuses? Reply with quote
Bob,
The reason I asked this question was that a friend just installed an EFIS made by MGL. They recommend a slow blow fuse .
I thought this was odd. Any ideas. My next inquiry will be with MGL.
Peter Laurence
Sent: Tuesday, July 14, 2009 12:37 PM
Subject: RE: AeroElectric-List: Automotive blade fuses?
At 10:44 AM 7/14/2009, you wrote:
--> AeroElectric-List message posted by: "plaurence" <peterlaurence6(at)gmail.com>
Is there such a thing as a slo blow ATO fuse?
No. When you need slow-blow characteristics
it's usually associated with hi-inrush and
or wildly variable current demands. Pitot
heaters, hydraulic pumps, etc come to mind.
For this we recommend MANL style current
limiters like . . .
These have very long time constants.
( -Thomas Paine 1776- )
 Filesize:  40.79 KB
 Viewed:  9490 Time(s)
frank.hinde(at)hp.com
PostPosted: Tue Jul 14, 2009 9:55 am    Post subject: Automotive blade fuses? Reply with quote
I don't know of anyone who put in anything other than the standard ATO blade fuse in with an EFIS..My guess is MGL was speaking generically. I would suggest going the next size up on th cable and installed the rated fuse, you can always increase the fuse rating after if necessary..But I really doubt and EFIS would have a hi enough in-rush current to blow a standard fuse at the correct steady state rating.
Frank
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of plaurence
Sent: Tuesday, July 14, 2009 10:29 AM
Bob,
Peter Laurence
Subject: RE: Automotive blade fuses?
  limiters like . . .
[img]cid:814044917(at)14072009-1E25[/img]
 Filesize:  40.79 KB
rmitch1(at)hughes.net
PostPosted: Tue Jul 14, 2009 12:13 pm    Post subject: Automotive blade fuses? Reply with quote
Take a look at the RV-12, esp. the E-LSA version. It is all fuses (no substitution allowed under E-LSA protocol, but, they use a type that lights up when blown. How does that work?
Bob Mitchell
Lancair 320
Sent: Tuesday, July 14, 2009 09:37
limiters like . . .
 Filesize:  40.79 KB
 Viewed:  9489 Time(s)
PostPosted: Tue Jul 14, 2009 12:47 pm    Post subject: Automotive blade fuses? Reply with quote
Led strapped across the terminals...When it is NOT blown the LED is bypassed by the fuse..When it blows current flows thru the led to the fault..Its a micro-amps so not enough current to heat the wire but enough to light the led..Which essentially acts like a big resistor.
Frank
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Robert Mitchell
Sent: Tuesday, July 14, 2009 1:10 PM
Bob Mitchell
Lancair 320
  limiters like . . .
[img]cid:080413120(at)14072009-1E2C[/img]
 Filesize:  40.79 KB
 Viewed:  9488 Time(s)
PostPosted: Tue Jul 14, 2009 7:12 pm    Post subject: Automotive blade fuses? Reply with quote
At 12:29 PM 7/14/2009, you wrote:
Bob,
Hmmmm . . . can't imagine why they would ask for
one. Haven't had occasion to call one out in a new
design for about 30 years. These are pretty much
dim memories of another time. In glass 1/4 x 1-1/4
fuses these are the MDL series. I've got a drawer
full of various sizes that I'm NOT moving to the
new shop in M.L.
etienne.phillips(at)gmail
PostPosted: Wed Jul 15, 2009 2:13 am    Post subject: Automotive blade fuses? Reply with quote
Hi Justin
They are available locally (as in Port Elizabeth) from Autozone... Not sure where abouts you are, but autozone is a chain store of sorts, so you may find them all over the country!
Etienne
2009/7/14 heisan <justin(at)expertron.co.za (justin(at)expertron.co.za)>
[quote]--> AeroElectric-List message posted by: "heisan" <justin(at)expertron.co.za (justin(at)expertron.co.za)>
Thanks everybody.
When I asked around here, everybody uses glass fuses or breakers.  Two A&Ps I chatted to said blade fuses were a bad idea (basically because it is difficult to make the pretty!
Nice to know that they will work, and are safe to use.
Does anybody know of an on-line shop that sells decent blade fuse holders?  Options here are few and far between.
Justin
http://forums.matronics.com/viewtopic.php?p=252936#252936
h as List Un/Subscription,
www.matronics.com/Navigator?AeroElectric-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
Matt Dralle, List Admin.
longg(at)pjm.com
PostPosted: Wed Jul 15, 2009 5:41 am    Post subject: Automotive blade fuses? Reply with quote
I’ve also seen these at Pep Boys if you’re on the east coast.
Glenn
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Etienne Phillips
Sent: Wednesday, July 15, 2009 6:10 AM
Subject: Re: Re: Automotive blade fuses?
Hi Justin
Etienne
Thanks everybody.
Justin
heisan
PostPosted: Wed Jul 15, 2009 11:17 am    Post subject: Re: Automotive blade fuses? Reply with quote
Thanks for all the info.
I will try AutoZone locally on Friday. If that doesn't work, I will order from one of the on-line shops.
You guys in the USA really have it all!
Justin
sarg314(at)gmail.com
PostPosted: Wed Jul 15, 2009 11:40 am    Post subject: Automotive blade fuses? Reply with quote
Autozone has them, but only in values used commonly in cars.  For your plane you will need a lot of small values - 1 or 2 or 3 amps.  I doubt you'll find those at autozone or checker.  B&C Specialty has them.
On Wed, Jul 15, 2009 at 12:17 PM, heisan <justin(at)expertron.co.za (justin(at)expertron.co.za)> wrote:
Justin
Tom Sargent
PostPosted: Wed Jul 15, 2009 12:20 pm    Post subject: Automotive blade fuses? Reply with quote
Hi all
When I suggested Autozone, I was referring to Autozone South Africa, not AutoZone USA. As Justin is a fellow Dark-Continent (Africa for those who are not familiar with the expression) dweller, I can appreciate the lack of local availability of certain seemingly easily obtainable aviation bits and pieces, unless you're happy spending 8-10 times the items value in shipping.
I'm pretty sure the smaller values are available, and certainly any cable fault will be able to pop a 5A fuse... If you want it to blow at a lower value than that, then you'll probably find those fuses to be a bit harder to find. But there's no reason you have to import the fuse holder from the opposite side of the planet just because that's where the fuses will eventually need to come from.
Etienne
Smile
On 15 Jul 2009, at 9:38 PM, thomas sargent wrote:
[quote]Autozone has them, but only in values used commonly in cars. For your plane you will need a lot of small values - 1 or 2 or 3 amps. I doubt you'll find those at autozone or checker. B&C Specialty has them.
Justin
Tom Sargent
BobsV35B(at)aol.com
PostPosted: Wed Jul 15, 2009 2:14 pm    Post subject: Automotive blade fuses? Reply with quote
Good Evening Sarge,
Do we really need fuses of that low an amperage?
Seems to me that what we need to protect are the wires. Unless you have awfully small diameter wires, five amp should be as small as you need. Five amp will protect a number twenty-two wire. That is as small as I ever use!
Happy Skies,
Old Bob
In a message dated 7/15/2009 2:42:17 P.M. Central Daylight Time, sarg314(at)gmail.com writes:
Can love help you live longer? Find out now.
PostPosted: Wed Jul 15, 2009 3:23 pm    Post subject: Automotive blade fuses? Reply with quote
Well, yes, protecting the wire is the main task of the fuse.  But If I have a device that I know should only use a fraction of an amp (my avionics cooling fan for example) and it starts drawing 2 amps, there's probably something seriously wrong with it.  It will be toast long before the #22 wire (or a 5 amp fuse) ever burns up.  The little thing could melt itself on 2 measly amps.  So I put a 2 amp fuse on it.  That still protects the wire and will keep the smoke level down in the cockpit.  The fan is probably dead either way.
On Wed, Jul 15, 2009 at 3:11 PM, <BobsV35B(at)aol.com (BobsV35B(at)aol.com)> wrote:
Good Evening Sarge,
Happy Skies,
Old Bob
In a message dated 7/15/2009 2:42:17 P.M. Central Daylight Time, sarg314(at)gmail.com (sarg314(at)gmail.com) writes:
Tom Sargent
Page 2 of 2
