A.F.RUPP(at)att.net Guest
Posted: Tue Dec 23, 2008 11:05 am Post subject: XL wing concerns |
All;,
I don't normally say anything but seems to me we are not thinking through this.
Look at your plans, does what you are saying make sense? If I do this what happens over there.
What Sabrina is saying is if you drop the rear attach point down with out changing the uprights you are preloading the rivets on the spar cap and preloading the mid spar at the uprights just to get the nose down. Talk about zippers. Setting the flap upstop a little short and rigging in aileron droop to the flaps or changing the incidence on the horizontal stabilizer as Sabrina did will get the nose down without any stress on the airframe. It may slow you down but, depends what your desires are. Deviate from the engineer's design and you have built in a different airplane, don't call it his.
Notice how Sabrina always goes back to the plans. That is CH's design.
When you change the tension on your control cables you are rigging your controls I have heard some say they had "x" tension on this cable but the balance had something else. If you have different tension on the cables to a control you have a resistance on those cables or they would be the same unless you have rig pins in.
NTSB investigations always have "interested parties" as part of an investigation. That is where they get their expertise from. I would assume any foreign investigation would be the same.
Al Rupp
601XL Corvair power
Almost done
In Aircraft maintenance since 1944, mostly airline
-------------- Original message from "Sabrina" <chicago2paris(at)msn.com>: --------------
"The only significant change that I am aware of is that they have changed the angle of incidence of the wing by lowering the rear attachment point, but no structural change there." End Quote.
CZAW did this 2" down--2 degree decalage change by TWISTING the main spars rather than re-setting the main carry through spar... Can the LAA find any static testing of this new twisted main spar anywhere in CZAW's books?
I am sure the FAA and NTSB recognize this and that is why they contacted CZAW owners here in the U.S. The 650 changes the main spar set to match the new rear spar angle.
When your LAA, through a former Zenith dealer, takes the time to repeatedly contact a 15 year old girl in the U.S. about the addition of SS A5 rivets on the inboard ailerons aft hinge portion attach points and requests more information each time, it means only one thing, they are very thorough. I applaud the
LAA. They don't believe for one minute that this was ONLY significant change
CZAW made. The AMD XLi and the Sabrina roll out at 850 pounds empty. As the
Germans recently pointed out, how in the world do you EU CZAW owners get your
aircraft to come in at the required EU weights? I have been sent photos
showing .016 skin thicknesses on some CZAW aircraft kits where Zenith plans spec
.025 Are there static tests of the .016 CZAW aircraft anywhere to be had?
Martin Pohl
Joined: 30 Jan 2006 Posts: 118 Location: CH-8645 Jona SG, Switzerland
Martin Pohl
z601(at)anemicaardvark.co Guest
Posted: Tue Dec 23, 2008 12:37 pm Post subject: XL wing concerns |
On Tuesday 23 December 2008 09:13, Sabrina wrote:
<snip>
| Quote: | When your LAA, through a former Zenith dealer, takes the time to repeatedly
I applaud the LAA. They don't believe for one minute that this was ONLY
significant change CZAW made. The AMD XLi and the Sabrina roll out at 850
pounds empty. As the Germans recently pointed out, how in the world do
you EU CZAW owners get your aircraft to come in at the required EU weights?
I have been sent photos showing .016 skin thicknesses on some CZAW
aircraft kits where Zenith plans spec .025 Are there static tests of the
<snip>
This is, I believe, a good and valid question. Another question one might ask
is: "has any dynamic testing been done?"
The failures we read of appear to have occurred under dynamic, not static,
conditions. The aircraft were flying, not sitting in a hangar with snadbags on
the wing.
Flutter, if indeed this is what has happened, can be the result
of resonance, which is a dynamic condition. I would like to see the results of
relevant structural dynamic testing, as well as static structural testing.
I don't believe that we, as individuals, have enough information than to do
more than beat around the fringe of the situation. Only the FAA, similar
national organizations, and Zenith have enough information to draw firm
conclusions. I await their thinking on the subject.
Those who can, do. Those who can't, sue.
Jim B. Belcher
Retired aerospace technical manager
BS, MS Physics, math, Computer Science
A&P/IA
Instrument Rated Pilot
General Radio Telephone Certificate
planecrazydld(at)yahoo.co Guest
Posted: Tue Dec 23, 2008 3:42 pm Post subject: XL wing concerns |
Did I miss an attachment?
David L. Downey
Harleysville (SE) PA, USA
--- On Tue, 12/23/08, Sabrina <chicago2paris(at)msn.com> wrote:
[quote]From: Sabrina <chicago2paris(at)msn.com>
Subject: Re: XL wing concerns
Date: Tuesday, December 23, 2008, 3:22 PM
[quote]--> Zenith601-List message posted by: "Sabrina"
Thank you for the PDF Martin... I am so happy to see that CH's name is
not on it. I misspoke about the firewall set, the 80 on your plans is the
bottom angle.
Read this topic online [quote][b]
rans6andrew
Posted: Wed Dec 24, 2008 3:56 am Post subject: Re: XL wing concerns |
does anyone know if the 650 uses the same wing/spar/fuselage structure as the 601XL?
Andrew - usual details 601ul etc.
_________________ A good way through building a 601UL with 912UL.
Still flying Rans S6 with 503. |
David X
Joined: 10 Jan 2006 Posts: 154 Location: Princeton, NJ, USA
Posted: Thu Jan 01, 2009 11:50 am Post subject: Re: XL wing concerns |
The lady doth protest too much.
Paul, are you a spokesman for ZAC, I wonder?
_________________ Zodiac 601 XL - CZAW Built - Rotax 912S
DO NOT ARCHIVE |
David X
Posted: Thu Jan 01, 2009 2:01 pm Post subject: Re: XL wing concerns |
Sabrina, the aircraft was built as per ZAC drawings in order to qualify as LSA class.
How would one know if any of the parts below were "changed"? Please clarify what it is you want to know.
| Sabrina wrote: | David,
Which CZAW version do you have?
Is your rear spar attach lowered?
Is your center spar modified per the CZAW plans shown above?
What is the thickness of your rear side skins?
Not protesting, just gathering information... :o)
Same question to you as Martin... David: Are any of these items changed as well on your version of the CZAW 601XL? 6B-5-1, 6B5-4, 6B5-6, 6B-5-2, 6B-18-1, 6B-18-3, 6W-1-1,6W-1-2, 6B-11-2
Player Queen:
Both here and hence pursue me lasting strife,
If once I be a widow, ever I be a wife!
Player King:
'Tis deeply sworn. Sweet, leave me here a while,
My spirits grow dull, and fain I would beguile
The tedious day with sleep.
Player Queen:
Sleep rock thy brain,
And never come mischance between us twain!
Hamlet:
Madam, how like you this play?
Queen:
The lady doth protest too much, methinks.
Hamlet Act 3, scene 2, 222–230 |
DO NOT ARCHIVE |
David X
Posted: Thu Jan 01, 2009 2:36 pm Post subject: Re: XL wing concerns |
I see that you are referring to the rear spar and attach points (6b5-1,2,4,6), the center arm rest (6b18-1), the seat belt attach points (6b18-3), flap rib (6w1-1), flap skin (6w1-2) and forward side skins (6b11-2). (see attached)
What specifically information are you looking for?
| Sabrina wrote: | | David: Are any of these items changed as well on your version of the CZAW 601XL? 6B-5-1, 6B5-4, 6B5-6, 6B-5-2, 6B-18-1, 6B-18-3, 6W-1-1,6W-1-2, 6B-11-2 |
42.02 KB |
912 Time(s) |
48.23 KB |
859 Time(s) |
51.43 KB |
843 Time(s) |
39.4 KB |
888 Time(s) |
DO NOT ARCHIVE |
psm(at)att.net Guest
Posted: Thu Jan 01, 2009 2:43 pm Post subject: XL wing concerns |
Oh No!
Not the DREADED DROOPY Fortunes!
Paul
At 02:03 PM 1/1/2009, you wrote:
I find my Zenith doth depend upon
A most auspicious star, whose influence
If now I court not, but omit, my fortunes
Will ever after droop. Here cease more questions.
(Tempest I.ii.217-220)
David X
Posted: Thu Jan 01, 2009 2:44 pm Post subject: Re: XL wing concerns |
If you are pursuing something pertinent to possible design differences with CZAW and ZAC plans ... by all means do not cease asking questions. I have a set of designs that go with the plane and I can send pictures, perform measurements etc.
No question in this regard is unimportant.
| Sabrina wrote: | I find my Zenith doth depend upon
(Tempest I.ii.217-220) |
DO NOT ARCHIVE |
ronpollock(at)gmail.com Guest
Posted: Fri Jan 02, 2009 1:28 pm Post subject: XL wing concerns |
As someone monitoring this discussion because of an interest in plans
building a 601 or equiv, I'd appreciate any opinions relative to my
position. Especially whether the 650 is susceptible to the same
issues. What would you do if you were just thinking of getting
started.
Thanks, Ron in L.A.
pdn8r(at)yahoo.com Guest
Posted: Fri Jan 02, 2009 2:48 pm Post subject: XL wing concerns |
I'm comfortable with my choice and would not hesitate to do it again.
Bill Pagan EAA Tech Counselor #4395
601XL QBK/Corvair/N565BW (RES)
--- On Fri, 1/2/09, Ron Pollock <ronpollock(at)gmail.com> wrote:
Subject: Re: Re: XL wing concerns
Date: Friday, January 2, 2009, 4:27 PM
-----Inline Attachment Follows-----
ter_turn(at)yahoo.com Guest
Ron Lendon
Joined: 10 Jan 2006 Posts: 685 Location: Clinton Twp., MI
Posted: Fri Jan 02, 2009 7:49 pm Post subject: Re: XL wing concerns |
| ronpollock(at)gmail.com wrote: | As someone monitoring this discussion because of an interest in plans
started.
Thanks, Ron in L.A. |
If you are a pilot, fly one. I did and bought the plans on the way home from the airport. With plans building you need to put some time in almost every day so plan your workspace.
_________________ Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
https://sites.google.com/site/corvairenginedata/ |
Posted: Fri Jan 02, 2009 8:23 pm Post subject: XL wing concerns |
Thanks Ron. I'm plans building a 701 now so know the drill. Just took a liking to the 601 and ran into a bunch of controversy I'm trying to sort out. Add to that the new model and trying to sort that out. Guess my real question was whether some here, if starting now, would build from 650 plans. I've gotten feedback that they are almost mix & match.
I wasn't asking if anyone had regrets or would go non-Zenair. But I'm happy to hear those happy with their 601s as from my position a little extra confidence is required to start on.
Ron in L.A.
Ron Lendon
Posted: Sat Jan 03, 2009 6:46 pm Post subject: Re: XL wing concerns |
| ronpollock(at)gmail.com wrote: | Thanks Ron. I'm plans building a 701 now so know the drill. Just took a liking to the 601 and ran into a bunch of controversy I'm trying to sort out. Add to that the new model and trying to sort that out. Guess my real question was whether some here, if starting now, would build from 650 plans. I've gotten feedback that they are almost mix & match.
Ron in L.A.
Ron,
The XL is a well designed structure. Quite strong in my opinion and I have a bit of experience in destroying structures, it was part of my job at Chrysler Engineering back in the 70's.
The feeling I get from talking to the Heintz's is it, the 650, is just slight changes from the several models they build worldwide to reduce the component count and make a better plane. Either XL or 650 are pretty much the same from what I see.
Much of the XL controversy sounds like our American press, full of supposition, conjecture, and opinion. As far as any consistent contributing factors there appears to be none currently.
CH 601 XLB
N601LT - Flying
Darryl Legg
Joined: 08 Nov 2007 Posts: 18 Location: Darwin, Australia
Posted: Sat Jan 10, 2009 3:22 am Post subject: Re: XL wing concerns |
why is it that I can't read Sabrina's posts? Have tried IE and Mozilla browsers. weird.
Darryl
leinad
Joined: 19 Sep 2006 Posts: 283 Location: Central Virginia
Posted: Sat Jan 10, 2009 6:19 am Post subject: Blank Posts |
Darryl,
I have the same problem with Sabrina's and occasionally other posts that are blank. I emailed Matt Dralle about it once but didn't get any reply. I'm reading these posts from the web forum, and not via email. Once in a while Sabrina posts something that I can read, but 95% of her posts are blank. It's obvious others are reading them because they post replies to her's.
Dan Dempsey
| Darryl Legg wrote: | why is it that I can't read Sabrina's posts? Have tried IE and Mozilla browsers. weird.
Darryl
_________________ Scratch building XL with Corvair Engine |
Darryl Legg
