Posted: Wed Dec 17, 2008 7:04 am Post subject: Overhead console |
Charcoal Zolatone and I have Stein's LEDs in six location on the overhead and that is what the buttons are for.
The nice thing about Zolatone is that it looks great and it saves time in prep because you don't need to make the fiberglass sooooo smooth. Seem lines blend in. I also made this removable with ten screws that anchor into brass screw receivers. It covers the screws on the fuse that hold down the hinge C makes a little cleaner look.
JOhn
Subject: RE: Overhead console
Date: Wed C 17 Dec 2008 04:07:59 -0800
.ExternalClass .EC_hmmessage P {padding-right:0px;padding-left:0px;padding-bottom:0px;padding-top:0px;} .ExternalClass BODY.EC_hmmessage {font-size:10pt;font-family:Verdana;} John C
Looks great!
What did you cover it with and what are the red buttons for?
Phil
From: John Gonzalez [mailto:indigoonlatigo(at)msn.com]
Sent: Wednesday C December 17 C 2008 12:57 AM
To: RV 10 group
And the final product...foam and fiberglass is fun!!!
JOhn G. 409 Do Not Archive
| Quote: | From: toaster73(at)embarqmail.com
Subject: Re: Overhead console
Date: Tue C 16 Dec 2008 20:22:52 -0500
Just to reiterate "you can" do this yourself . If you can do all the
fiberglass work on the 10 you can make a console. I used blue foam and
molded the console in place C glassed it in place and then released it to get
the blue foam out C finally epoxied back on for good. Just takes time and the
will to do it.
-Chris Lucas
#40072
tronics.com/contribution
/www.matronics.com/Navigator?RV10-List
.com
toaster73(at)embarqmail.c Guest
Posted: Wed Dec 17, 2008 2:35 pm Post subject: Overhead console |
Beautiful work!
-Chris
Phil.Perry(at)netapp.com Guest
Posted: Thu Dec 18, 2008 2:33 pm Post subject: Overhead console |
Is Zolatone a roll on??
Sent: Wednesday, December 17, 2008 9:04 AM
To: RV 10 group
The nice thing about Zolatone is that it looks great and it saves time in prep because you don't need to make the fiberglass sooooo smooth. Seem lines blend in. I also made this removable with ten screws that anchor into brass screw receivers. It covers the screws on the fuse that hold down the hinge, makes a little cleaner look.
JOhn
Date: Wed, 17 Dec 2008 04:07:59 -0800
.ExternalClass .EC_hmmessage P { PADDING-RIGHT: 0px; PADDING-LEFT: 0px; PADDING-BOTTOM: 0px; PADDING-TOP: 0px } .ExternalClass BODY.EC_hmmessage { FONT-SIZE: 10pt; FONT-FAMILY: Verdana } John,
Looks great!
Phil
Sent: Wednesday, December 17, 2008 12:57 AM
To: RV 10 group
Date: Tue, 16 Dec 2008 20:22:52 -0500
molded the console in place, glassed it in place and then released it to get
the blue foam out, finally epoxied back on for good. Just takes time and the
will to do it.
-Chris Lucas
#40072
.com
href="http://www.matronics.com/contribution">http://www.matronics.com/chref="http://www.matronics.com/Navigator?RV10-List">http://www.matronics.com/Navigator?RV10-List
Posted: Thu Dec 18, 2008 3:03 pm Post subject: Overhead console |
You spray it on with a spray gun with a very large tip. Their web site spells out which guns and tips work.
The reason is that it is very thick material with seperated texture peices than get stuck in guns with narrower tips.
Fiberglass substrates require no primer C but the alluminum and the ferrous metal require a specail primer for the Zolatone. It is not the most refined looking materail C but its simplicity expresses a different look. Best way to discribe it is no frills look C like the difference between a tranatlantic racing sailboat vs. a cruiser for luxury. It works for me.
Date: Thu C 18 Dec 2008 14:30:15 -0800
.ExternalClass .EC_hmmessage P {padding-right:0px;padding-left:0px;padding-bottom:0px;padding-top:0px;} .ExternalClass BODY.EC_hmmessage {font-size:10pt;font-family:Verdana;} Is Zolatone a roll on??
Sent: Wednesday C December 17 C 2008 9:04 AM
To: RV 10 group
JOhn
Looks great!
Phil
To: RV 10 group
will to do it.
-Chris Lucas
#40072
.com
ronics.com
ricksked(at)embarqmail.co Guest
Posted: Thu Dec 18, 2008 6:23 pm Post subject: Overhead console |
I guess it needs a bit tip...2.0 to 2.3 mm....that's a hose!! I'm really tempted to try this stuff..it looks great. John, do you order direct or do you have to use a distributer?
Rick S.
40185
msausen
Joined: 25 Oct 2007 Posts: 559 Location: Appleton, WI USA
Posted: Fri Dec 19, 2008 8:03 am Post subject: Overhead console |
 A lot of the plastic, scratch built, airplane guys have used this stuff as an interior treatment. It does a great job at covering up minor imperfections and holds up very well. I haven’t seen it used where it looks bad either. I considered using it on the exposed areas but there really aren’t many left once Abby get’s done with the interior. I also wanted a little extra sound dampening on the interior which is why I’m using a headliner.
 If I ever get around to building that OpenEZ I’ll probably Zolatone the interior.
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Rick Sked
Sent: Thursday, December 18, 2008 8:23 PM
Subject: Re: RV10-List: Overhead console
Rick S.
40185
Posted: Fri Dec 19, 2008 8:34 am Post subject: Overhead console |
I went thru Aircraft spruce C but look at the Zolatone web site C because the primer which Aircraft spruce sells I believe is for ferrous metals and the product number is different than the primer specified by Zolatone for use with Aluminum. Non the less...what I used seems to be working fine. I just cleaned the inside of the quick build fue with denature alcohol and left that van's primer in place.
For $10 you can order the color guide so you can choose which colors you want. I really only like two colors...but they have so many different colors to choose from C one can even make the inside look like those red diner booth chairs...why anyone would want that is beyond me but to each their own.
Date: Thu C 18 Dec 2008 21:23:02 -0500
.ExternalClass {font-family:'Times New Roman';font-size:12pt;color:#000000;} I guess it needs a bit tip...2.0 to 2.3 mm....that's a hose!! I'm really tempted to try this stuff..it looks great. John C do you order direct or do you have to use a distributer?
Rick S.
40185
wayne.e(at)grandecom.net Guest
Posted: Sat Dec 20, 2008 5:02 am Post subject: Overhead console |
Just curios because I see this once in awhile. What causes messages,like Michaels below, to go whacky like his did? Sometimes I see these and they are so long it seems like it goes on forever. Not aviation question but hey what the heck :>}
Wayne Edgerton N602WT flying
Time: 08:03:34 AM PST US From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net (rvbuilder(at)sausen.net)> Subject: Overhead console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msausen
Posted: Sat Dec 20, 2008 6:38 am Post subject: Overhead console |
Hmm, most of my messages go out in HTML format from my email program which is fairly common. It looks like stuff is reading correctly into the Matronics forums so I don’t think it’s anything on Matt’s side. (http://forums.matronics.com/viewtopic.php?t=52963&start=20 If I had to guess, somewhere along the way something in the message is triggering a translation at your ISP or email reader that is causing the format to change into something unreadable. What are you using for email reader? Looks like you are using the Windows Mail client that comes in Vista. Also if your ISP has webmail, log into there and see if it is scrambled.
Michael
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Wayne Edgerton
Sent: Saturday, December 20, 2008 7:00 AM
[quote]=========[b]
Kellym
Posted: Sat Dec 20, 2008 6:53 am Post subject: Overhead console |
I see the same with Thunderbird. I suspect a formating bit gets dropped along the way. Also with Gmail. So apparently it happens in the processing of the listserve after a copy goes on the forum.
RV Builder (Michael Sausen) wrote: [quote] <![endif]--> <![endif]-->
Hmm, most of my messages go out in HTML format from my email program which is fairly common. It looks like stuff is reading correctly into the Matronics forums so I don’t think it’s anything on Matt’s side. ([url=http://forums.matronics.com/viewtopic.php?t=52963&start ]http://forums.matronics.com/viewtopic.php?t=52963&start [/url] If I had to guess, somewhere along the way something in the message is triggering a translation at your ISP or email reader that is causing the format to change into something unreadable. What are you using for email reader? Looks like you are using the Windows Mail client that comes in Vista. Also if your ISP has webmail, log into there and see if it is scrambled.
Michael
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Wayne Edgerton
| Quote: | =========
| [b]
KCHD |
robin1(at)mrmoisture.com Guest
Posted: Sat Dec 20, 2008 4:40 pm Post subject: Overhead console |
Kelly,
When I drink Thunderbird everything looks like that to me.
Robin
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Kelly McMullen
Sent: Saturday, December 20, 2008 6:51 AM
[quote] [b]
Kelly McMullen
Posted: Sat Dec 20, 2008 6:21 pm Post subject: Overhead console |
Some of us don't stoop to the liquid, preferring only the software program.
On Sat, Dec 20, 2008 at 5:39 PM, Robin Marks <robin1(at)mrmoisture.com> wrote:
| Quote: | Kelly,
Robin
A&P/IA, EAA Tech Counselor
KCHD |
