SB work
Goto page Previous  1, 2
pitts_pilot(at)bellsouth.
PostPosted: Mon Jul 14, 2008 1:21 pm    Post subject: SB work Reply with quote
For me, the easiest part was drilling out the rivets .... I have the
tool that fits over the shop head to center the drill. I use my
automatic center punch to snap the head off and then use it to punch the
tail through.
Linn ..... love my tools
Tim Olson wrote:
Yes, that's the best method that I've ever been told in the
past also. I personally use a flat ended punch to snap
them off, although some people use the flat end of a drill
bit. It works well, because you're just snapping the head
of the rivet off. You can do it with a smaller sized bit,
too. It's been suggested before that people buy a #31 and
#41 bit, because then you can drill ever so slightly
undersized to the hole, so you don't hit the surrounding
metal if you're off center. Not much difference, but it's
nice. At OSH it might be worth poking around with the
vendors to get those bits.
pascal wrote:
> This is probably common knowledge
> http://home.earthlink.net/~gilalex/Rivet/ but when I did this SB I
> used this method. I was quite surprised that there wasn't one rivet
> in the complete process I messed up.. first for me!!
> I actually have a better looking shelf now than I did before
> starting.. There were 3-4 rivets I looked at and thought there were
> awful, that are now much better looking.
> Pascal
> *From:* Robert Wright <mailto:flywrights(at)yahoo.com>
> *Sent:* Monday, July 14, 2008 9:33 AM
> *To:* rv10-list(at)matronics.com <mailto:rv10-list(at)matronics.com>
> *Subject:* Re: SB work
> Nah, It took me more time to leave the shelf on because I'm better (I
> think) at manuevering in small places than drilling out so many
> rivets without elongation.
> Rob
n212pj(at)gmail.com
PostPosted: Mon Jul 14, 2008 1:45 pm    Post subject: SB work Reply with quote
What tool that fits over the shop head?
John J
PostPosted: Mon Jul 14, 2008 1:57 pm    Post subject: SB work Reply with quote
Good question John!!! My dsyslexic brain in action ..... make that
'manufactured head'!!!
Soory about that. .... It would be a good tool to have, though!!!
Linn
[quote] John J
Page 2 of 2
