Evening Flight
Goto page Previous  1, 2
Richard Pike
PostPosted: Wed Mar 08, 2006 7:35 pm    Post subject: Evening Flight Reply with quote
You got me to thinking about some of the Rotax 2 stroke failures I have
had, I went and looked it up, I have about 1200 hours in front of
various Rotax 2-cycles, and none of them involved what we typically
think of as 2 cycle specific problems. For what it's worth, here they are-
First Rotax was a 277 in a Maxair Hummer, had a spark plug failure from
using Amsoil and leaded gas, it made little lead balls appear between
the spark plug electrodes. (And also because of high EGT's, but back in
1983, Rotax allowed higher normal EGT's than they do currently) A
2-cycle issue? Maybe. A Rotax issue - bad specs for EGT values? Maybe. I
replaced the needle jet and jet needle to lower the temps, no more
problems. An Amsoil/leaded gas issue? Maybe.
Then I had two failures of my secondary ignition system as I developed a
dual ignition for the 277, part of the teething process, my bad, not the
engine's fault. Successful forced landing each time. Not a 2-cycle
issue, not a Rotax issue.
Happened to look back one day just in time to see the K&N filter
loosening itself off the carb, but retained by a safety wiring retainer.
Was over a landfill, landed, reattached it and flew home. Not a 2-cycle
Then I had a starter rewind spring fail, let the pull cord flop inside
the fan housing, tore the fan to shreds, but the engine kept running,
and I flew to an airport 5 miles away, removed the fan housing, and flew
home, free air. Not a 2-cycle issue, but possibly a Rotax issue. All
this with the 277 over about 13 years and 750 hours. Maintenance during
this time was points, plugs, gaskets, one new set of rings, and one
leaky crankshaft seal.
Then I had a 503 in the Anglin J-6 for about 6 months, no problems.
Replaced the 503 with a 532, bought it used from a dealer in Oklahoma.
After about 150 hours, the crank broke one day at startup, disassembly
revealed a ball-peen hammer mark on one of the journals, apparently the
former owner had some trouble with reassembly following some
maintenance... ((at)#$%& MORON!) Replaced the crank, that engine is still
doing OK with it's current owner. Not a 2-cycle issue, not a Rotax issue.
Built the MKIII, stuck a low time 532 in it, no problems until the trip
to Oshkosh, had replaced the points as pre-trip preventive maintenance
with a set from Airstar Discount Sales, apparently they sell "Rotax
looking" points, because I had to adjust them in route to get back home,
no other problems on the trip. Not a 2-cycle issue, not a Rotax issue.
A year later, the curlicue exhaust pipe on the side mount exhaust split
in flight, but didn't separate off/go through the prop. Relocated the
exhaust with a Quicksilver style exhaust to back below and under the
gearbox, no problems since. Not a 2-cycle issue, but certainly a Rotax
issue.
A year later, the brass gear on the crank that drives the water
pump/rotary valve slipped a bit (it is pressed in place) and the rotary
intake valve timing changed on climbout, but the engine would still
maintain 5200 rpm, flew 3 miles back to the field and landed. Not a
2-cycle issue, but certainly a Rotax issue.
Replaced the 532 with a zero time 582. ($2800 with a new B box)
Unfortunately, the oil reservoir that I purchased (1.5 gallon Murray
lawnmower gas tank) had a spiderweb/cocoon tucked back up into a corner
that didn't come loose when I filled the tank with gas and sloshed it,
but when it finally did come loose, it blocked off the oil feed line and
starved the engine for oil. No oil = piston seizure, had an uneventful
landing, and had to go to first oversize on the bore. No related
problems since. Not a 2-cycle issue, not a Rotax issue.
Replaced the main jets for a reason I've forgotten, one was an older
used jet, it backed itself out of the carburetor and dropped down into
the float bowl on takeoff, successful off field landing. (Aside from
putting green cow poo spots on my cream colored Stits) Not a 2-cycle
My opinion is that Rotax was (maybe?) responsible for the lead-balled
spark plug, (or maybe it was Amsoil's fault?) & the broken starter
recoil spring in the 277, the split exhaust in the 532 exhaust pipe,
(however that is apparently a problem that only affects the curlicue
sections of the side mount pipes) and the slipped gear on the 532 crank.
None of those caused an engine stoppage, in each event the engine kept
running and I was able to fly to an airstrip and land.
Obviously others have not been so fortunate, but I am satisfied that
Rotax 2 cycle engines are not as bad as some would make them out to be.
I baby my 582, I get 65 mph at 5100 rpm, the plugs burn clean, the rings
stay free, the carbon is nil, and it burns 3.5 gph. Still not as good as
a four stroke, but close enough for me. The 532 burned a bit less gas,
but didn't run as smoothly, it had flat spots and "chased the pipe." If
I want to go 85 mph, I run 5900 rpm and burn 5 gph. 2-stroke
reliability? I am satisfied that they are good enough. But I also think
that if I had an 80 HP 4 cycle Rotax, I would probably like it better.
Richard Pike
MKIII N420P (420ldPoops)
DAquaNut(at)aol.com wrote:
In a message dated 3/8/2006 7:17:08 A.M. Central Standard Time,
etzim62(at)earthlink.net writes:
Having said that,,,,,,,,,,,
A good operator always knows that everything mechanical is subject to
failure and is prepared to deal with it.
Eugene,
Are you suggesting that a majority of Rotax failures come as a result of
improper maintenance, Not paying attention to warning signs or sounds,
improper oil mix ratio, which would fall into the category of pilot ERROR? I had a
Kawasaki 440 that served me well for 117 hours till I sold the plane. Never
quit once. I never heard of one quitting! I heard of Cayunas quitting a few
times. There were not many Rotaxes around in 82 so I didn't hear much about
them! I understand without proper care and maintenance no engine will
last long, but I do know 2-cycles are less forgiving and more prone to seizure
than a 4-stroke. Maybe this list has made me paranoid. I know I was worried
about bending an axle because of all the talk on the list. So far I have made
28 landings and have not bent a gear yet. Im sure my time will come , but I
hope my fear of the Rotax is like my fear was of bending a leg.
Ed (Firefly # 62)
do not archieve
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
DAquaNut(at)aol.com
PostPosted: Wed Mar 08, 2006 8:53 pm    Post subject: Evening Flight Reply with quote
In a message dated 3/8/2006 6:38:57 P.M. Central Standard Time,
If a Rotax engine is running too lean with a stock setup, changing
the needles and jets is almost always merely camouflaging and
temporarily covering up another often more serious problem.
I am with you. I moved my needle clip one notch when my exhaust temps were
high in the mid-range, but it was not until I put more pitch in the prop that
the numbers got in the ball park. I think it was John H. that suggested that.
I also heard that the EGT would go even lower as the air temperature goes
up. I for one feel the manufacture knows his product better than I do so I
will follow their suggestions. So far so good
Ed
DAquaNut(at)AOL.COM
PostPosted: Wed Mar 08, 2006 9:16 pm    Post subject: Evening Flight Reply with quote
In a message dated 3/8/2006 9:36:23 P.M. Central Standard Time,
richard(at)bcchapel.org writes:
Richard Pike
Thanks for taking the time to share this info. I will be a little less on
edge when I fly
Ed
Page 2 of 2
