jdm(at)wideworld.net Guest
Posted: Fri Mar 03, 2006 8:53 am Post subject: To cut or not to cut? |
| Quote: | Jerb and all,
The Original 5-rib wing Firestar had a gross weight limit of 535 lbs.
Does it state this on the plans? My plane is 388 wet and I'm 215 on a good
day. That's 603. Now add 25 for a BRS and I'm at 628. That's well over
535. I was starting to feel better about all this but I just got that sick
feeling back in my stomach. Guess I better skip lunch today! I also need to
put a picture of my plane on my refrigerator to deter me from opening it
more than I should!
Will adding 25 extra pounds by adding a BRS justify adding the extra weight?
Or will this be the straw that broke the camel's back? At least I will have
a chute assuming of course all goes well with the deployment and subsequent
landing.
JetPilot
Posted: Fri Mar 03, 2006 9:26 am Post subject: Re: To cut or not to cut? |
There is no need to go to 7 ribs to streingthen your wing. Moving and adding ribs might get complicated You can just:
1. Replace the old ribs with new ones
2. Add angle aluminum to the rib leading and trailing edges as Mr. Hauck Suggested.
This way you get a super strong wing with no redesign needed My MK-III has the same rib streingthing I suggested here, if you would like to see how it is done I will send you some pictures.
The more I think about this the more I think you should streingthen that wing and here is why. The wing has LOTS of hours on it, and as Mr. Hauck said fatigue adds up over time, you have no idea how close it is to its limit. The plane has a history of aerobatics, only God knows how much and how often, but the wing has obviously seen more hard use than it was designed for. You are also at a very heavy weight for the 5 rib Firestar, do you see all these factors starting to add up ? It would bother me...
When the other Kolb Firestar wing finally failed, it was in straight and level flight, no abnormal loads were being placed on it at the time . I would not suggest that everyone rip thier wings apart, as its well proven that Kolb's are strong and will handle loads that are beyond thier design limits... But your Firestar sounds like it has been down the same road as the Firestar that did finally fail Your wing has held up to almost a thousand hours of heavy weights and aerobatics, it might be close to its limit.
Michael A. Bigelow
Kolb MK-III Xtra, 912-S |
WillUribe(at)aol.com Guest
Posted: Fri Mar 03, 2006 10:20 am Post subject: To cut or not to cut? |
John,
Your 5-rib FireStar has already surpassed the designed limitation due to the
use of the 503 and now your thinking of adding more weight. IMHO you should
be thinking of going back to the Kolb recommended engine for your model
FireStar. That is if your FireStar has not already suffered fatigue, cracks or
warping. If you really want or need the 503 then you should go with the Kolb
recommended 7-rib FireStar.
I remember reading in the builders manual to be very careful not to leave
any scratches on the wing spar when installing the ribs. Now people are saying
it is OK to drill new holes and not worry about the old ones just cover them
with a rivet. I would think that is worse but then what do I know.
Will Uribe
El Paso, TX
FireStar II N4GU
http://home.elp.rr.com/airplane/
In a message dated 3/3/2006 9:55:53 A.M. Mountain Standard Time,
jdm(at)wideworld.net writes:
more than I should!
landing.
Kirk Smith
Posted: Fri Mar 03, 2006 10:37 am Post subject: To cut or not to cut? |
| Quote: | day. That's 603. Now add 25 for a BRS and I'm at 628. That's well
over
and you have an engine that is larger than the plane was designed for.
Posted: Fri Mar 03, 2006 10:55 am Post subject: To cut or not to cut? |
due to the
| Will Uribe
Will/Gang:
Without a doubt, your post is the most intelligent one I have read so
far on this thread.
I remember getting ready to build my original FS. Wanted to put a 447
on it, but Homer would not sell me one with the kit. I took the 377
and traded it off to Gerry Olenik for a 447. Just prior to losing my
FS, Homer and I had talked about a 503 for it. I had plans to
circumnavigate the border of CONUS summer of 1990. I had pretty well
worn out the two 447's I kept to keep my FS going so I could make air
shows and fly ins. Not to say anything bad about two strokes and get
that crap started again, but as much as I flew, back then, that is
what it took to keep me somewhat operational at all times. I kept a
447 built on the bench to put in the FS when the need arised. It
always arose a day or two prior to planned departure.
I get the impression some of you think if somebody on the Kolb List
says it is ok to go fly your airplane, then you should relax, go fly,
enjoy, and never consider the circumstances until it comes that
critical time we never want to experience.
I have heard some say, "All I did was hard pull ups on take off."
That won't hurt my Kolb. May not, but one can perform loop in an
original FS pulling far less G's that the individual who likes to pull
up hard and feel those G's. In fact, it is easier to to a nice
symetrical loop with half power than it is will full power. That is
because we suffer from the high mounted pusher configuration.
Performing an inside loop with full power sort of nullifies a lot of
that power trying to overcome the thrust line.
Another thing. If you have never tried to replace a rib on a Kolb,
then you are in for a rude awakening. After the rivets are drilled
out of the main spar gusset, you will find that deep scratches will
occur as soon as you try to slide that bugger off the main spar. Back
in the old days before I learned how to stretch a main spar gusset, we
had a hell of a time trying to get some of those ribs in place on the
main spar tube. Not to mention the many holes that will now be unused
when the ribs are relocated.
I mentioned in a previous post that I would pull the fabric, reinforce
all lateral bracing of the leading edge of the wing, which is a
whopping .028" wall 1.5" tube. Then I would reinforce top and bottom
of all 5 main ribs with 3/4 and 1/2 in aluminum angle. While I was in
there, I would reinforce the bow tip at the 45 and 90 deg points with
1/2" tubing tied together with aluminum web to keep the 1/2 tubes in
column. Then I would cover up the wing, paint it, and go fly without
the contant nagging reminder that I might have a couple wings that are
not as strong as they should be.
I can not tell anyone else how to build or how to fly. I won't do
that. Sure, it is easy to tell someone else to go fly, have fun, your
over loaded, over powered antique ultralight is fine and dandy, safe
to fly. Course you ain't sitting in the pilots seat either.
I loved my FS and hated to see it go. However, I learned a hell of a
lot from that little airplane, and even more from the accident. I'd
love to build another one if I had the kit and the time to build, fly,
and enjoy. If I did, I would build the wing as I decribed above. All
5 ribs worth. If I changed my mind and built a 7 main rib wing, I
would still use my mod to strengthen the ribs, bracing of the leading
edge, and the bow tip. Sure, the normal per plans built wing is fine
if flown as intended. Shucks, I would have a hard time lolly gagging
around like an old school marm in the air in a fresh, strong, hauck
modified original FS. I am sure it would not take long to have that
little sucker flying just like it did nearly 20 years ago.
Take care,
_________________ John Hauck
Titus, Alabama |
Posted: Fri Mar 03, 2006 11:16 am Post subject: To cut or not to cut? |
Michael,
As I recall the accident, the leading edge wing failure on an early
FireStar happened when trying to recover from a hammer head stall. There were
abnormal loads being placed on it at the time of failure.
Will Uribe
El Paso, TX
FireStar II N4GU
flht99reh(at)netzero.net Guest
Posted: Fri Mar 03, 2006 3:11 pm Post subject: To cut or not to cut? |
John, I have both the KX drawing and the KHP drawing. I assume (fool that I
am) that the technique you used to slide the ribs without scratching is to
insert a thin piece of clean edged aluminum sheet the diameter approximate
of the spar, circumferentially (of course open at one end to wrap around the
spar). This then would be slid in very carefully from the opposite side of
the rib flange. Am I correct? I also noted spaced centered between the newly
located ribs a lower false rib (5 required). This really appears to be a
massive undertaking by anyone's standards. It would be one thing to do from
scratch (new wings), but wow what a project. I pray I never have to tear
into mine.
And John, if you have reason to come to Ohio at some point, you can play
with my 503 powered Fire star KXP.
Near overwhelmed Ralph in Ohio
WhiskeyVictor36(at)aol.co Guest
Posted: Fri Mar 03, 2006 7:23 pm Post subject: To cut or not to cut? |
In a message dated 3/3/2006 11:06:25 A.M. Eastern Standard Time,
ul15rhb(at)juno.com writes:
Ralph/John Murr/All,
Speaking of the original 1985 design model FireStar with 5 ribs and a Rotax
377 engine. I bought a kit from Homer on June 30, 1989 and have the plans
and builders manual.
I have never seen the gross weight stated in print on any of the
documentation I have, but on page 50 of the builders manual I quote, "The VNE of the
FireStar in calm air is 75 MPH. As the air gets turbulent, reduce your speed
accordingly. This airplane has a light wing loading. Stresses go way up if it
is fully loaded and the air gets rough".
I have replaced the 377 engine (at 425 hrs) with a 447, added the 1-1/8 inch
gear legs, brakes, 3/4 canopy, baggage board behind the seat and have a
second chance chute above my head between the wings. Instrumentation is ASI,
EGT, CHT, RPM, compass and ALT. Otherwise it is stock with a 5 gal. fuel tank.
Empty wt. (as an UL) is somewhat fat at about 280 lbs. With full fuel (5
gal. X 6 lb. p/gal.) of 30 lbs., plus my 140 lbs., my gross is at 450 lbs. On
occasion, when I go on a long X-country, I carry 4 more gals. of fuel in two
cans as baggage, adding another 24 lbs., for a gross of 474 lbs. Probably
more, as I didn't include weight for a small tool kit, tie down ropes, fuel
transfer hose, camera, cell phone, wallet full of $$ and other pocket items.
I am a very conservative flyer and do worry about overstressing the plane in
rough air, so I always slow down for a more comfortable ride for me.
John M, you will have to make your own decision on what to do. Modifying
the wing as John H suggested will add strength, but it also adds weight.
Calculate your gross weight carefully. Because of your personal body weight, you
might be better off with a two place Kolb. By the way, I've been to
Smoketown's breakfast fly-in several times in my Kolb. Weather permitting I will see
you there this year.
Bill Varnes
Original Kolb FireStar
Audubon NJ
Posted: Fri Mar 03, 2006 8:06 pm Post subject: To cut or not to cut? |
My gross weight is 600. I guess I'm just too fat for my fat plane! There is
no way I can loose 65 pounds. guess I need a bigger plane!
I'm sure the plane would be ok for someone around 172 pounds. I could lose
the starter and battery and save 25 pounds. That gets it down to 535.
Anybody out there interested in a Firestar? If you look on Frapper you can
see its picture. I live in south central PA and fly out of S37. I also
have an enclosed trailer on Barnstormers.com that it fits in. I just got a
hanger so I'm selling the trailer. I can sell it as a package deal? There is
nothing wrong with the plane that I know of. I just need a bigger plane to
haul me around safer!
John Murr
Posted: Fri Mar 03, 2006 9:02 pm Post subject: To cut or not to cut? |
He John,
Your FireStar sure does have a nice paint job.
http://tinyurl.com/egchl
Will Uribe
El Paso, TX
FireStar II N4GU
Kirk Smith
Posted: Sat Mar 04, 2006 5:03 am Post subject: Re: To cut or not to cut? |
The Kolb Firestar has been in production since 1985. In 1990 some styling changes were introduced resulting in the KX series. The KXP is the KX with a stronger wing to accommodate the more powerful Rotax 503. The KXP has 7 ribs per wing vs 5 for the KX and original firestar, as mentioned previously. What I have not seen mentioned on this topic is that the KXP also has a stronger drag strut arrangement than the KX.
36.97 KB |
659 Time(s) |
Eugene Zimmerman
Posted: Sat Mar 04, 2006 5:47 am Post subject: To cut or not to cut? |
On Mar 3, 2006, at 11:04 PM, John Murr wrote:
| Quote: | Anybody out there interested in a Firestar?
Hi John,
By now you know that what you actually have there is a wolf in
sheep's clothing.
How much do you want for that dangerous over-stressed Kolb death
trap? $3500.00?
Only joking of course!
You have a perfectly good plane.
I've seen it fly numerous times by it's former owner and I think you
are being influenced to part with a jewel.
I've flown a five rib Firestar with much higher gross weights than
yours for many years.
Fly with common sense and slowdown in rowdy air and you and your
plane will be fine.
If you do decide to sell that show quality beauty, it is worth a
premium.
Gene Zimmerman
planecrazzzy Guest
Posted: Sat Mar 04, 2006 6:25 am Post subject: Re: To cut or not to cut? |
Hi,
I was looking over your plane ( Nice Job ) but I saw something kind of disturbing ( to me ) it looks like you have your Pitot tube on the Left "lift Strut".....What "I" thought was scary ...it looks like two holes were drilled into it to run the tubing on the inside.... I hope looking at those holes is on your preflight checklist...
Gotta Fly...
Mike in MN
PS What SIZE are the tires you have ....I'll probly get something like those when I change mine...( cost ? )
Richard Pike
Posted: Sat Mar 04, 2006 7:19 am Post subject: To cut or not to cut? |
Maybe I'm missing something here (always a good chance of that) but
isn't gross weight also a function of maximum G loading at a given
stress factor?
Let's assume (and this is strictly an assumption) that Homer designed
the Firestar for a +4.4 G load at 535 pounds, (which would be reasonable
under Part 103) but now you have added weight, your Firestar weighs 628
pounds at takeoff. Then in order to fly safely, you must reduce the
maneuvering speed (and maximum speed) accordingly so that your new
weight at any speed will not cause any higher G loading in any situation
than the designer originally planned for.
For a detailed explanation, check out this page here
http://www.ushga.org/article08.asp
To keep it super-simple, if your airplane stalls at (let's say) 35, and
you get caught in turbulence, as long as you keep your airspeed below
45, it is almost impossible to pull even 2 G's, because the wing will
stall first. Think about some of the turbulence you have flown in - if
you fly at your normal cruising speed and hit a booming thermal or a
rotor along a ridge top, you feel an appreciable and usually abrupt G load.
But if you slow that puppy down 15 - 20 mph and hit that same
turbulence, the airplane just sort of wallows around, and although it
feels sloppy, - and probably is, - it is obviously not being worked over
or abused by the vulgar air. At 15 mph over stall speed, we are almost
fool proof in the situations we normally fly our little airplanes in.
(Not that some fool can't figure out how to exceed the limits...)
But in practical terms, that is the difference between bending the
airplane or not.
At 628 pounds with a BRS, I would not be afraid to fly it, - but I would
do the math, come up with some conservative and realistic V numbers,
(calibrate your airspeed indicator accurately) not hot dog or play Mr.
high-speed-flyby-pull-up, avoid flying in serious turbulence, (and slow
down to an appropriate Va speed when it showed up unexpectedly) and then
enjoy the airplane.
Richard Pike
MKIII N420P (420ldPoops)
John Murr wrote:
<snip>
John Murr
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
rsanoa
Joined: 10 Jan 2006 Posts: 71 Location: Bell Buckle,TN
Posted: Sat Mar 04, 2006 7:56 am Post subject: To cut or not to cut? |
I believe Richard is correct. If this old brain is in gear, I believe I was told that as your gross weight goes up, so does your stall speed and you can't normally damage anything when the wing stalls, whether it's 25 mph or 50 mph. As Richard so clearly points out, set a maneuvering speed and stay with it in rough air. I know I'm repeating what Richard said but his analysis is important for all of us to remember. Of course the joker in the deck is the fact that many will "fly hard" regardless.
stress factor?
airplane or not.
enjoy the airplane.
Richard Pike
John Murr wrote:
John Murr
Use Photomail to share photos without annoying attachments.
_________________ Ray S.Anderson |
Posted: Sat Mar 04, 2006 8:39 am Post subject: To cut or not to cut? |
Ok so using the equation my stall speed (IAS) is 35 at 4.47 g's that puts Va
at 74 and Vne at 85. That sounds about right. If I slow down to 50 my max
g load could only be 2.04.
I didn't see gross weight in the equation, but I assume it is a factor of
stall speed. The higher the gross weight, the higher the stall speed.
Conclusion: If I fly no faster than 74 in smooth air and no faster than 50
in all other types of air. I should be fine.
Also I looked and the 503 DCDI is only 13 pounds heavier than the 447, so
having a 503 shouldn't make a difference to the loading on the wing as long
as I stay in the Va parameters above. It's nice to have the 503 for short
fields. I climb out at about 60 until 800 AGL then throttle back. I could
climb a little steeper to get it down to 50.
Kirk Smith
Posted: Sat Mar 04, 2006 9:20 am Post subject: To cut or not to cut? |
| Quote: | Ok so using the equation my stall speed (IAS) is 35 at 4.47 g's that puts
Va
| Quote: | at 74 and Vne at 85. That sounds about right. If I slow down to 50 my
max
| Quote: | g load could only be 2.04.
35 at what weight? What is the stall speed at 625lbs? I bet it's closer to
50.
Posted: Sat Mar 04, 2006 9:34 am Post subject: To cut or not to cut? |
At current gross weight of 603 it is 35 IAS. (tested at altitude using GPS
and it is real close)
Kirk Smith
Posted: Sat Mar 04, 2006 10:17 am Post subject: To cut or not to cut? |
I do have inspection holes but it's very hard to see very small hair-line
cracks.
Another thing I could do is have someone on this list about my weight do a
few loops, hammerheads, and fly it around at 100 mph mid-day in the summer
and see what happens? Volunteers should bring their own cute. I don't want
to pay the repacking fee on mine!
