Tdawson(at)avidyne.com Guest
Posted: Wed Jan 11, 2006 10:09 am Post subject: Negative Battery Cable Connection |
We had certain mission avionics that were driving us to 24 volts. Most
avionics these days, however, will run at either 12 or 24. You can get
power converters to go either way, but those are generally cheaper to go
from 24 to 12 then the other way around.
It was a pain in the rear to try and hunt down good 24 volt contactors,
especially for the starter contactor. Van's only sells 12 volt models.
But the one we did eventually get is wicked cool.
Plus it's fun to be different!
TDT
40025
Tim(at)MyRV10.com Guest
Posted: Wed Jan 11, 2006 10:32 am Post subject: Negative Battery Cable Connection |
Hmm...you sure got that one down... <all in good fun>
dO nOT aRCHIVe
rick.conti(at)boeing.com Guest
Posted: Wed Jan 11, 2006 10:50 am Post subject: Negative Battery Cable Connection |
Before I answer, why 2 batteries? I bought one 24 volt battery.
Gregg's (of Blue Mountain Avionics fame) document Wiring for Smart
people makes a good case for 24 volts and he convinced me. My oil
pressure gauge is part of my EFIS, therefore the EFIS must be up and
running when I start the engine. There is too much draw for a 12 volt
system when the starter is cranking and could very likely cause the EFIS
to shut off or reboot. I need to see oil pressure immediately. This is
also true for other avionics that are on when cranking the engine.
While we're on the subject, I installed a flush mounted door in the rear
bulkhead adjacent to the baggage door. Behind the door is the external
power plug connected to a solenoid with a diode. The diode and solenoid
prevent voltage from getting to the battery if the cables are connected
incorrectly.
Thank You
Rick Conti
office: 703-414-6141
cell: 571-215-6134
Posted: Wed Jan 11, 2006 10:58 am Post subject: Negative Battery Cable Connection |
Odyssey doesn't make a 24 volt battery that I know of and that's what we
wanted to use. Plus one can do a scheme like replace one of the
batteries every year (or two), to maintain a rotating constantly "new"
battery. (I think that idea came from Aero-Electric.)
Good point on the engine info display. Depends somewhat on your EFIS
and it's tolerance for voltage drops, too.
Got any pictures of your external power arrangement? Sounds nice.
TDT
40025
Posted: Wed Jan 11, 2006 11:19 am Post subject: Negative Battery Cable Connection |
I'll take a few pictures tonight and post them on Jeremy's web site.
www.jharris.net
Go to aviation then RV-10.
Jeremy is helping with my 10 and to date has done all of the work on the
panel.
Pictures to be taken: External power receptacle set up
Power board location on panel
Tray in tail for servos and ELT
Anyone interested in the defrost system?
Is Odyssey an especially good battery?
Thank You
Rick Conti
cell: 571-215-6134
LarryRosen(at)comcast.net Guest
Posted: Wed Jan 11, 2006 11:31 am Post subject: Negative Battery Cable Connection |
Tim
Where up front are you mounting the batteries? What type of battery?
Larry Rosen
| Quote: | YES!! At least one other person using 24 volts! Hooray for us!
Like others, we have two Odyssey batteries, but they are wired in
series . . .
(Plus two little ones up front that are also in series . . .)
TDT
40025
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Conti, Rick
*Sent:* Wednesday, January 11, 2006 10:45 AM
*To:* rv10-list(at)matronics.com
*Subject:* RE: Negative Battery Cable Connection
The board is mounted on a wood base w/stand-offs on the right side of
the panel. Sorry, no photos. I am using a 24v system. The board is the
newer version.
If you order CH Products control grips, you will NOT need the model
with the relays in the control grip. The relays are available on the
power board.
*/Thank You/*
*/Rick Conti/*
*/o/**/ffice: 703-414-6141/*
*/ cell: 571-215-6134/*
*From:* John Cleary [mailto:johncleary(at)mangertonnsw.com]
*Sent:* Wednesday, January 11, 2006 10:27 AM
Rick,
I am interested in using this board also. Where did you decide to
mount it? Do you have any photos? Are you able to share your wiring
diagram? What voltage system did you go for?
Thank you,
John Cleary
*Sent:* Saturday, 7 January 2006 2:09 AM
I decided not to use the airframe as a return. Since all parts are
primed and the riveted “connection” is a painted surface to an
unpainted surface, electrically, it’s not a good connection. I bought
the power board from Blue Mountain and both battery cables run forward
to the board.
*/Thank You/*
*/Rick Conti/*
*From:* Mike Kraus [mailto:n223rv(at)wolflakeairport.net]
*Sent:* Thursday, January 05, 2006 9:41 PM
*Subject:* Negative Battery Cable Connection
Where is everyone connecting the negative battery cable on the -10? I
thought about running it up to one of the bolts that bolt the front
longeron to the rear longeron just aft of the baggage area. I was
hoping to attach it to a longeron that runs to the firewall like in
the Harmon Rocket, but there is not one that runs that far do to the
door cut outs on each side.
-Mike
bob.condrey(at)baesystems Guest
Posted: Wed Jan 11, 2006 11:32 am Post subject: Negative Battery Cable Connection |
I'm interested in seeing the defrost system!
Bob #40105
Posted: Wed Jan 11, 2006 11:37 am Post subject: Negative Battery Cable Connection |
They are little ones from B&C Specialty, 7 aH, I believe. They are
going to sit on a little tray that will be on the cabin side of the
firewall, up high. The Aux Battery Master contactor and the Crosstie
contactor will probably sit next to them. Still working that out . . .
TDT
40025
Posted: Wed Jan 11, 2006 11:47 am Post subject: Negative Battery Cable Connection |
Roger that.
Thank You
Rick Conti
cell: 571-215-6134
Posted: Wed Jan 11, 2006 12:53 pm Post subject: Negative Battery Cable Connection |
When I wired up my sailplane I had the choice of either 12 or 24. My Becker
250W transponder gave me the option of either voltage, but the person in the
field who I consulted told me that the 24v system would allow the
transponder to function more efficiently. I don't know what this means,
whether it could mean better penetration strength or was it simply a
resistence issue in going from the batteries to the unit and not the unit to
the antenae. I don't remember the mathmatical formulas for voltage, amps
resistence
Maybe I was misinformed, but it works fine.
John 40409
| Quote: | From: "Kelly McMullen" <kellym(at)aviating.com>
Reply-To: rv10-list(at)matronics.com
Subject: RE: Negative Battery Cable Connection
Date: Wed, 11 Jan 2006 10:10:38 -0700 (MST)
I'm curious what the perceived benefits of 24volts are. On a small plane,
I don't see a significant wt. advantage. Most 24V accessories I perceive
to be more expensive..maybe I'm wrong. Just trying to understand why I
should consider 24V.
> Like others, we have two Odyssey batteries, but they are wired in series
> TDT
> 40025
johncleary(at)mangertonns Guest
Posted: Wed Jan 11, 2006 2:49 pm Post subject: Negative Battery Cable Connection |
Rick,
Are you planning to use one of the Blue Mountains EFIS?
I agree wholeheartedly with you on the 24 volt explanation in 'Wiring for
Smart People'. For anybody who hasn't read it, it is downloadable free from
the Blue Mountains web site at the following link.
http://www.bluemountainavionics.com/download.php#appnotes
John Cleary
schmoboy(at)cox.net Guest
Posted: Wed Jan 11, 2006 3:16 pm Post subject: Negative Battery Cable Connection |
Not to fuel any fire, but here's some comments regarding Greg's writing...
<http://www.aeroelectric.com/articles/richter/richter.html>
-Sean #40303
John Cleary wrote:
Rick,
John Cleary
dmasys(at)cox.net Guest
Posted: Wed Jan 11, 2006 4:01 pm Post subject: Negative Battery Cable Connection |
| Quote: | From: "Conti, Rick" <rick.conti(at)boeing.com>
| Quote: | Is Odyssey an especially good battery?
I have an Odyssey PC680 in my RV-7A, now just over two years old (and another new one on the bench awaiting a swap at next oil change).
The Odyssey is indeed a very good battery, primarily because of small size, sealed design and a very low internal resistance that gives it the 680 amp cranking capacity that gives it the name.
It is basically a motorcycle battery and there are other cheaper batteries with the same form factor, but you have to read the small print to see that the cheaper ones have higher internal resistance, thus generate fewer amps and the possibility of internal heat during high current operations.
It is called out in Van's FWF plans for the -7 and is a good design choice on their part.
-Dan Masys
RV-7A flying
RV-10 tailcone mostly done
dlm46007(at)cox.net Guest
Posted: Wed Jan 11, 2006 4:16 pm Post subject: Negative Battery Cable Connection |
why do you swap every two years? The design life of the battery for the
military is over 10 years and the service life is considered to be 5-8
years.
Posted: Wed Jan 11, 2006 5:16 pm Post subject: Negative Battery Cable Connection |
| Quote: | From: "David McNeill" <dlm46007(at)cox.net>
Date: 2006/01/11 Wed PM 07:15:14 EST
Subject: Re: RE: Negative Battery Cable Connection
| Quote: | why do you swap every two years? The design life of the battery for the military is over 10 years and the service life is considered to be 5-8 years.
Wasn't actually planning on every two years necessarily, though I appreciate my post made it seem that way. The older PC680 (only battery the -7A has ever had) is going to become the bench test battery for the RV-10, so the -7 is the beneficiary of the swap.
The smarter way to do this is Aeroelectric's timing setup annually that puts a load on the battery till its dead and measures time under load. The dumber, 'cheap insurance' way is just to swap it out before it has a chance to become even a potential problem.
-Dan Masys
Posted: Wed Jan 11, 2006 5:30 pm Post subject: Negative Battery Cable Connection |
BTW the link is http://www.enersysreservepower.com/ody b.asp?brandID=5.
check the specs. I am using the 925 in my wife's car to avoid the every two
year replacement in the AZ sun. Have a 925 as backup in the Glastar and a
680 on the firewall for starting. The 10 will have two 680 each capable of
starting.
Posted: Wed Jan 11, 2006 5:46 pm Post subject: Negative Battery Cable Connection |
NO I DON'T OWN ANY STOCK but
You are here: EnerSys Home > Reserve Power > Odyssey Batteries
Odyssey Drycell T Batteries
a.. GUARANTEED LONGER SERVICE LIFE With a twelve year military grade
design life and a six-to-ten year service life, ODYSSEY® saves you time and
money because you do not have to replace the battery as often. ODYSSEY® has
the powersport exclusive 2-year full warranty against factory defects or
three full years in automotive, commercial and heavy-duty marine.
b.. SUPERIOR CRANKING AND FAST CHARGE CAPABILITY The 5 second
cranking power of ODYSSEY® batteries is double to triple that of equally
sized conventional batteries, even when the temperature is as low as -40°C.
Also, with simple constant voltage charging (14.2-15V) (alternator or
independent charger), there is no limitation on the in rush current, so the
user is assured of fast charge recovery.
c.. MOUNTING FLEXIBILITY The ODYSSEY® battery may be installed
on its sides at any angle without sacrificing any performance attributes.
There is no fear of any acid spillage as ODYSSEY® recycles the internal gas
during operation or charging.
d.. SUPERIOR VIBRATION RESISTANCE ODYSSEY® batteries are of
military grade and have endured rigorous tests that demonstrate their
overall ruggedness and exceptional tolerance of mechanical abuse.
e.. READY OUT OF THE BOX ODYSSEY® batteries are shipped fully
charged. If ODYSSEY'S® voltage is 12.65V or greater simply install the
battery in your vehicle and you are ready to go! If below 12.65V, boost
charge following the instructions in the ODYSSEY® Owner's Manual.
f.. WORRY-FREE SHIPPING The sealed design of the ODYSSEY®
battery eliminates the need for a acid vent tube; eliminating the fear of
acid burns or damage to expensive chrome or paint. Owing to the DrycellT
design, the US Department of Transportation (USDOT) has classified the
ODYSSEY® battery as a dry battery, so it may be shipped worry-free by
UPS/Federal Express or by air as non-spillable.
g.. LONGER STORAGE LIFE Unlike conventional batteries that
need to be recharged every six to twelve weeks the ODYSSEY® battery, when
fully charged, can be stored for up to 2 years at 25°C (77°F). Simply
recharge and ODYSSEY® is returned to full power. At lower temperatures,
storage times will be even longer.
h.. DEEP DISCHARGE RECOVERY Should ODYSSEY® become deeply
discharged, simply recharge following instructions in the ODYSSEY® Owners
Manual.
There is a also a pdf that explains the development of the
product
43 Bytes |
21100 Time(s) |
Posted: Wed Jan 11, 2006 5:47 pm Post subject: Negative Battery Cable Connection |
Yeah, let's not re-hash old debates here . . .
TDT
Posted: Wed Jan 11, 2006 5:54 pm Post subject: Negative Battery Cable Connection |
Those Odyssey 680s are about $80 - 85 if I remember - cheap insurance to swap one every couple of years . . .
Give the used one to a motorcycle-driving friend . . .
TDT
40025
rv10builder(at)bellsouth. Guest
Posted: Wed Jan 11, 2006 7:55 pm Post subject: Negative Battery Cable Connection |
Hey folks,
I'm usually quiet, but I gotta chime in on this one. I am a telecom
engineer, and one of my responsibilities is to maintain several large DC
power plants (-48V, 2K - 6K amps). My plants utilize flooded cells,
while those of my coworkers utilize VRLA's. The main difference in our
routines of monitoring and testing batteries is they are constantly
replacing them (while I am not). The same folks that manufacture
batteries for my company also make those that fit in experimental
airplanes. If you intend to use a "sealed" battery in your ship like I
do, you are welcome to mine following my annual. I intend to include
the $85 in the annual budget for battery replacement.
Brian
[quote]Those Odyssey 680s are about $80 - 85 if I remember - cheap insurance to swap one every couple of years . . .
TDT
40025
