Posted: Sun Jun 24, 2007 3:22 pm Post subject: Tailplane flutter |
Carl
The torque tube is chrome plated 4130 I believe, stainless isn't strong
enough.
You may have spotted the weakest link in the chain, if the TP9 & 12 had
more bearing area the slop problem might go away. Wouldn't be much
weight penalty either.
OTH clamp bolting as Nigel Graham did years ago might be the best answer.
Graham
Carl Pattinson wrote:
| Quote: | There is a slight misunderstanding regarding where the wear in the
"torque tube assembly" occurrs. The torque tube itself is a hardened
(possibly crome moly) steel.
Having just implemented Mod 62 we found that there was no noticeable
wear in the torque tube itself. All the wear occurred in the TP9 and
TP12 components as these do not appear to be hardened steel (or as hard
as the torque tube itself).
air.guerner(at)wanadoo.fr Guest
Posted: Mon Jun 25, 2007 12:08 am Post subject: Tailplane flutter |
Hi Graham,<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Sorry I missed your clamp solution. Anyway, I went the taper pin way. Easy to do and very effective.
Remi
From: "R.C.Harrison" <ptag.dev(at)tiscali.co.uk (ptag.dev(at)tiscali.co.uk)>
Subject: RE: Europa-List: Tailplane flutter
Hi! Remi
You forgot my torque tube clamps as a permanent fix for no slop ever.
Bob Harrison G-PTAG
Robt.C.Harrison
nigel_graham(at)btconnect Guest
Posted: Mon Jun 25, 2007 2:42 am Post subject: Tailplane flutter |
Hi Graham,
FYI - I am working with Ian Rickard at the moment to document exactly what I
did and present this to the PFA.
To enlighten those of you not familiar with this mod:
A long time ago I identified the inherent shortfall with the TP14 method of
securing the drive arms to the torque tube. Merely replacing these pins with
oversized pins would not in my opinion, cure the problem - only delay the
next re-occurrence once play developed.
I developed a simple arrangement (KISS technology) that positively clamps
the drive arms (TP9 and TP12) onto the torque tube by replacing all four
TP14 pins with 1/4" x 2.125" AN bolts.
To support the torque tube and prevent it distorting, 15mm wide
cross-drilled discs are inserted into TP4 at each of the four stations.
To spread the clamping load over a larger surface, "saddle blocks" (profiled
to mate with the OD of TP9 and TP12) are fitted under the bolt head and
castellated nut.
The beauty of clamping is that it introduces a torque damper into the drive
system - eliminating the shock "chattering" that wears the standard TP14
pins and elongates the holes - and it can be retrofitted to tubes with worn
holes.
Nigel (The other one) Graham
Posted: Mon Jun 25, 2007 3:06 am Post subject: Tailplane flutter |
Nigel
Hi! sorry to hear about your motor bike incident, get better soon.
Your mod is probably the neatest one and good engineering practice. I
will be surprised if PFA don't like it, not invented here syndrome seems
unlikely in this case. {{
Graham
Nigel Graham wrote:
Hi Graham,
willie.harrison(at)tinyon Guest
Posted: Mon Jun 25, 2007 3:08 am Post subject: Tailplane flutter |
Nigel,
Would there be any problem with doing this with 3/8 bolts on an
aircraft which had Mod 62 already done to it?
This is such an appealing idea I think.
Willie
On 25 Jun 2007, at 11:29, Nigel Graham wrote:
<nigel_graham(at)btconnect.com>
Hi Graham,
exactly what I
method of
pins with
delay the
clamps
four
stations.
blocks" (profiled
and
castellated nut.
the drive
TP14
with worn
holes.
kheindl(at)msn.com Guest
Posted: Mon Jun 25, 2007 3:30 am Post subject: Tailplane flutter |
Hi Nigel,
My main concern with this mod would be the insertion of the (predrilled)
15mm discs into a tube with anti-corrosion paint on the inside. Would there
be a suitable reamer to get it absolutely smooth, also to remove any burr
from the enlarged holes. Then how do you aim to position the discs so that
all the holes line up ? Maybe a threaded hole in the centre for attaching a
long rod temporarily just for the lineup ?
Karl
[quote]From: "Nigel Graham" <nigel_graham(at)btconnect.com>
Reply-To: europa-list(at)matronics.com
To: <europa-list(at)matronics.com>
Subject: RE: Tailplane flutter
Date: Mon, 25 Jun 2007 11:29:20 +0100
Hi Graham,
I
with
(profiled
castellated nut.
holes.
Posted: Mon Jun 25, 2007 3:52 am Post subject: Tailplane flutter |
Willie,
I can think of no reason why not.
The only point you need to check is the bolt head to rear bulkhead
clearance. The circumference of the TP9 and TP12 is only about 16mm away
from this bulkhead - so the total assembly thickness is a limiting factor
and I'm not sure how deep a 3/8" bolt head is.
If this did prove to be a problem, small 1/4" to 3/8" step-down spigots
would solve the problem and allow you to use 1/4" bolts.
Posted: Mon Jun 25, 2007 5:01 am Post subject: Tailplane flutter |
Hi Karl,
You're clearly thinking this through!
My description was only an abstract to give an idea of the concept.
The detailed proposals handle preparation insertion and bonding.
Here is a description for those of you with an enquiring mind - I will not
take offence if the rest of you skip this!
TP4 has to be de-greased and de-burred inside prior to insertion. The discs
have a scribe line on one side to indicate the orientation of the cross
drill (facilitating alignment). You were on the money with regard to the
insertion tool. A 6.0mm threaded bar (with two lock nuts) screws into a
central hole in the disc. This allows the discs to be inserted into TP4 and
rotated into correct alignment - two from one side and two from the other.
The discs have a shallow groove centrally around the circumference. Once in
position, bearing grade anaerobic adhesive (Loctite) is introduced through
one of the TP4 holes and the discs rotated to distribute the adhesive. This
ensures concentricity and accommodates any small variance of inside
diameter.
An AN4 bolt can be temporally inserted to locate the disc in the correct
position and the thread bar removed. In this way, all four discs are placed
and bonded. The 6mm holes also serve to cross vent the tube and provide a
method (via spray tube) of introducing the anti-corrosion treatment of your
choice (ACF50, WD40, Shell "Ensis" fluid, granny's beef dripping) into TP4.
Once bonded, the tail can be re-assembled. The bolts have to be inserted
from the rear to guarantee clearance with the rear bulkhead. This will
involve rotating the TP4 assy up through 90 degrees to allow the bolts to be
inserted from underneath. (The counter balance arm needs to be removed
first). It does have the advantage that the castellated nuts and split pins
can be inserted from the front of TP4 and not tucked behind as in the TP14
assembly instructions.
Hope this answers some of you (good) questions.
wdaniell(at)etb.net.co Guest
Posted: Mon Jun 25, 2007 8:32 am Post subject: Tailplane flutter |
Hey bob can we talk off line so I can get a set
Will
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of R.C.Harrison
Sent: Sunday, June 24, 2007 09:31
Hi! Remi
Bob Harrison G-PTAG
Robt.C.Harrison
Posted: Mon Jun 25, 2007 11:51 am Post subject: Tailplane flutter |
Hi Nigel
Yes, thank you for the additional detail. Bt you still don't say HOW the TP4
is to be cleaned out. And you say that the mass balance arm has to be
disconnected. That means having to crawl into the tail section and
performing all kinds of difficult tasks. My balance arm is very tight and
that was easy to do with the top off. I don't really want to touch it. I am
also not rushing into mod 70.
And as Mark and others have remarked: we don't really know anything about
the accident. Except, that a wing landed on the road, the main fuselage in a
field, that at least one tailplane came off initially, and a pip pin was
bent 90 degrees. Obviously something started the chain of events from the
tail somewhere. There may or may not have been any flutter. I guess we'll
find out a bit more in a week or so.
I like the idea of doing away with the mass balance arm, and weighting the
tailplanes internally, at least for new kits.
Karl
Date: Mon, 25 Jun 2007 13:59:25 +0100
Hi Karl,
diameter.
be
Posted: Mon Jun 25, 2007 2:42 pm Post subject: Tailplane flutter |
Remi
the clamp solution was Nigel Graham's not mine, but I do like it. I'm
pleased your solution works too, my reservations about taper pins are
about the risk of distorting the cross tube and causing binding in the
bearings
regards
Graham
Rémi Guerner wrote:
[quote] Hi Graham,
Remi
<mailto:ptag.dev(at)tiscali.co.uk>>
Hi! Remi
Bob Harrison G-PTAG
Robt.C.Harrison
Posted: Mon Jun 25, 2007 2:49 pm Post subject: Tailplane flutter |
Don't think so Willie but I could be mistaken, only downside I can think
of is a slight weight penalty.
Graham
William Harrison wrote:
<willie.harrison(at)tinyonline.co.uk>
Nigel,
Willie
fklein(at)orcasonline.com Guest
Posted: Mon Jun 25, 2007 7:59 pm Post subject: Tailplane flutter |
Nigel...very sweet (KISS) solution...one question: Why castellated nuts
rather than nylocs?
Also.. What material(s) did you use for your "discs" and "saddles"?
Fred
On Monday, June 25, 2007, at 03:29 AM, Nigel Graham wrote:
| Quote: | To support the torque tube and prevent it distorting, 15mm wide
(profiled
castellated nut.
believed to be clean.
carl(at)flyers.freeserve. Guest
Posted: Mon Jun 25, 2007 11:54 pm Post subject: Tailplane Flutter |
For what its worth, I believe the cause of this accident has nothing to do
with "wear" in the tailplane assemblies. I base my "theory" on the simple
fact that many Europas have flown many flying hours with no reported
evidence of tailplane flutter.
Wear and tear is a fact of engineering life and the current Mod 62 seems to
be as good a design as any. Reports from the field suggest that with Mod 62
done properly, subsequent wear is minimal. Undoubtedly there are
potentially better designs out there - hindsight is a wonderful thing.
My other concern is that changing a reasonably good design could move the
problem elsewhere - how much damage is being done by builders kneeling in
the back end of their fuselages - the push/ pull tube is very vunerable and
simply cant be removed.
It seems more likely IMHO that there was a failure was due to the separation
of one of the tailplanes for reasons which have already been discussed.
Tailplane flutter may well have occurred when the tailplane disengaged the
drive pins but this would not be attributable wear in the system. The PFA's
current interest in the design of the pip pin recesses would lend weight to
this possibility.
Till we have the full findings of the AIIB we shouldnt be redesigning the
aeroplane based on such limited evidence (I know the PFA have asked for our
feedback on this).
I would hope that before changing the design the PFA or Europa will conduct
a survey amongst the current Europa fleet to establish if wear in the torque
assembly (post Mod62) is a genuine problem or a myth. My understanding is
that such a survey has not as yet been done - either by tha PFA or by the
factory, though no doubt the recent sales figures of Mod 62 kits will give
them a better idea.
Carl Pattinson
G-LABS
Posted: Tue Jun 26, 2007 12:35 am Post subject: Tailplane flutter |
Hi Fred.
The castellated nut is a standard AN part and was chosen because the split
pins can be inspected visually at any time.
Nylocks would work perfectly - but there is no guarantee that somebody would
not re-use them and you cannot gauge the integrity by looking at them.
I specified zinc passivated mild steel for both on the grounds that the
coefficient of expansion is about the same as the TP4 and the risk of
galvanic action is reduced.
The truth is that you could probably make the discs out of an anodised alloy
with no ill effects - and save weight into the bargain.
Nigel
Posted: Tue Jun 26, 2007 1:04 am Post subject: Tailplane Flutter |
Carl
Having flown around, at least for a short while, in a Europa with 1"
of slop at the stab trailing edges (* see also below), without any
sign of flutter, I tend to agree that slop of itself might not be a
DIRECT cause of flutter in a Europa tailplane. However, could it
have been an INDIRECT cause: would you not agree that increasing
"wear" in the TP12/TP4 joint could lead to a TP6 failure (via undue
torsional loads going through the pip pin)? Having said that, I am
aware that we are speculating about really happened and why, although
some very strong hints are emerging already (PFA's invitation to us
to propose anti-wear joint designs, and the focus on the pip pin recess)
* In my case, the slop was not due to wear but due to bad manufacture
(he aircraft had total time of 12 hours when I bought it). If you can
believe the paperwork, it had also been tested to Vne on two
occasions in the previous 12 months when most or all of the 1" slop
was present. Makes you think.
Willie
On 26 Jun 2007, at 08:53, Carl Pattinson wrote:
<carl(at)flyers.freeserve.co.uk>
nothing to do with "wear" in the tailplane assemblies. I base my
"theory" on the simple fact that many Europas have flown many
flying hours with no reported evidence of tailplane flutter.
seems to be as good a design as any. Reports from the field
suggest that with Mod 62 done properly, subsequent wear is
minimal. Undoubtedly there are potentially better designs out
move the problem elsewhere - how much damage is being done by
builders kneeling in the back end of their fuselages - the push/
pull tube is very vunerable and simply cant be removed.
separation of one of the tailplanes for reasons which have already
been discussed. Tailplane flutter may well have occurred when the
tailplane disengaged the drive pins but this would not be
attributable wear in the system. The PFA's current interest in the
design of the pip pin recesses would lend weight to this possibility.
redesigning the aeroplane based on such limited evidence (I know
the PFA have asked for our feedback on this).
conduct a survey amongst the current Europa fleet to establish if
wear in the torque assembly (post Mod62) is a genuine problem or a
myth. My understanding is that such a survey has not as yet been
done - either by tha PFA or by the factory, though no doubt the
recent sales figures of Mod 62 kits will give them a better idea.
Carl Pattinson
G-LABS
Posted: Tue Jun 26, 2007 2:09 am Post subject: Tailplane Flutter |
Im not saying we shouldnt be concerned about the amount of slop in the
tailplanes. The PFA's current limit of 1/2 inch would seem to be reasonable.
We checked ours last week - as soon as we recieved the PFA bulletins and
found 3/8" movement between the tailplanes and a total of 5/8" movement when
the counterbalance arm was locked against the top fuselage stop and both
tailplanes moved up and down (hope that makes sense). Note - the second
measurement is not a requirement of the original 1999 PFA bulletin though it
goes on to say that no play is acceptable between TP04 an TP09.
We promptly installed Mod 62 and have concluded that the original 1/4" pins
had probably always been a loose fit - either due to poor manufacture or
installation. Unfortunately 13 years ago when we were building the aircraft
we didnt understand the implications of loose fitting pins.
The aircraft had its annual in March and we did the dive to 150kts twice -
once with Andy Draper at the controls and once with me. Im sure if anything
had been amiss Andy would have noticed. We also did a series of stalls and
incipient spins and again no problems were found.
One point I would mention is that there is no official Annual Inspection
checklist for the Europa fuselage (as far as I am aware) and I believe this
issue should be addressed. The current regime relies on the owner and
inspectors vigilance in noticing defects and potential problems. Some
inspectors will have more experience with Europa related issues and others
less so.
And before anyone jumps to conclusions, I should make it clear that Andy
Draper did not conduct the annual inspection - only the test flight. The
annual inspection was none the less a thorough one.
So the business of tailplane flutter is a bit of a mystery.
