builder test flying his own creation?
Goto page Previous  1, 2
mikenjulie.parkin(at)btop
PostPosted: Mon Jun 11, 2007 9:11 pm    Post subject: builder test flying his own creation? Reply with quote
Tom,
I don't have the solution to your problem. Having just lost 2 friends in a Europa crash, I just want you and everyone in your position to fully understand the risks.
It may be that in the end you have no choice but to go it alone, in which case I wish you all the best. There are plenty of experienced monowheel pilots on this forum that can give you advice.
regards,
Mike.
karelvranken(at)hotmail.c
PostPosted: Tue Jun 12, 2007 9:51 am    Post subject: builder test flying his own creation? Reply with quote
Mike and all,
Where are the instructors to explain why the Europa is different and difficult to land especially on hard runways with cross wind? We until now hear only warnings. I hope there will come a discussion why it so different even for a taildragger.
Karel Vranken, #447 Mono XS 912ULS Airmaster CS, only 37 hours on F-PKRL, first flight by myself with 3800 hours half of wich on taildragger.
garrys(at)tampabay.rr.com
PostPosted: Tue Jun 12, 2007 10:56 am    Post subject: builder test flying his own creation? Reply with quote
To get a handle on the concept of landing a monowheel, I suggest taking a bowling ball and laying a sheet of plywood 4' X 4' on top of the bowling ball. Then try to stand up on the plywood. The physics are identical.
Garry Stout
Trigear
gregoryf.flyboy(at)comcas
PostPosted: Tue Jun 12, 2007 11:36 am    Post subject: builder test flying his own creation? Reply with quote
Except the wheel will allow movement in one axis, while the bowling ball allows movement in two axis. If you are thinking that the big moment arm of the tail section hanging out in a high wind could create the twist on the wheel in the other axis, then the physics would indeed, be a bit closer to the bowling ball. However, the monowheel still ties the plane down on the ground laterally.
I don’t think I would want to try the bowling ball experiment. I am not sure I would be able to do it. I would definitely need to take lessons on how to ‘land’ that one!
Greg Fuchs
Tri-gear (A050)
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Garry
Sent: Tuesday, June 12, 2007 11:57 AM
Subject: Re: builder test flying his own creation?
Garry Stout
Trigear
nielskock(at)get2net.dk
PostPosted: Wed Jun 13, 2007 7:36 am    Post subject: builder test flying his own creation? Reply with quote
In principle you are right, Graham.
I am sure that you will agree with me, however, that a pilot not being able
to detect
even some small deficiency in flight-behaviour of his mount is not ready to
go solo
in the first place, even in a Cessna, let alone a home-built - which proves
your point,
by the way.
All the best,
Niels
PostPosted: Wed Jun 13, 2007 8:32 am    Post subject: builder test flying his own creation? Reply with quote
Karel,
I may be wrong, but one reason might be the elasticity of the outrigger legs.
A standard 2-wheeler taildragger need not be more direction-stable than the
monowheel, but the slightest turn of the latter will flex the outer outrigger, thereby, I think,
increasing the force of the turn, making it more difficult to correct it.
And the way to correct a such a turn, as we all know, is by short, rapid taps on the
opposite rudder pedal, and not, as may be the natural reflex, keeping your foot down on
the pedal, until the whole contraption enters a turn in the opposite direction which you will never
get out of, until the lowered wing-tip scrapes the surface and the precious propeller
blades emit sounds of destruction.
Niels ---
m.j.gregory(at)talk21.com
PostPosted: Wed Jun 13, 2007 10:24 am    Post subject: builder test flying his own creation? Reply with quote
Hello Karel,
While it will not provide a complete answer to your question, I believe a number of points made in the attached article on handling the monowheel Europa may help to explain some of the reasons why the aircraft is different and how its handling should be approached.
This article was prepared for Europa Flyer No 37, June-August 2003, but I'm happy to provide it here as helpful safety material to everyone on the List, not just those who are members of the Europa Club.
While the UK PFA coaching scheme is available only to members of the PFA, the concept of qualified instructors providing coaching at reasonable cost on homebuilt aircraft is universally applicable – the difficulty of obtaining a suitable aircraft can usually be overcome by making an appeal on the List.
Best regards
Mike Gregory
Europa Club Safety Officer
safety(at)europaclub.org.uk (safety(at)europaclub.org.uk)
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of karelvranken
Sent: 12 June 2007 18:58
Mike and all,
HANDLING_THE_MONOWHEEL_EUROPA.doc
 Filename:  HANDLING_THE_MONOWHEEL_EUROPA.doc
 Filesize:  38 KB
 Downloaded:  7578 Time(s)
PostPosted: Wed Jun 13, 2007 1:35 pm    Post subject: builder test flying his own creation? Reply with quote
Niels,
Maybe you are wright. I have to read your explanation five times more trying to understand what you realy mean. I also think there is more than the outriggers in question with a groundloop.
Karel Vranken # 447 F-PKRL (I forgot to mention that I also have some 2500 hours of gliding experience)
asarangan(at)YAHOO.COM
PostPosted: Wed Jun 13, 2007 1:38 pm    Post subject: builder test flying his own creation? Reply with quote
This is a fantastic writeup. Thanks for posting it.
--- Mike Gregory <m.j.gregory(at)talk21.com> wrote:
[quote] Hello Karel,
believe a
monowheel
different
but I'm
the List,
PFA,
cost
on homebuilt aircraft is universally applicable - the difficulty of
appeal on
the List.
Best regards
Mike Gregory
_____
karelvranken
Mike and all,
until now
different
F-PKRL,
PostPosted: Wed Jun 13, 2007 2:30 pm    Post subject: builder test flying his own creation? Reply with quote
Mike,
Thank you for the reminder. And thanks again to John Brownlow. Special attention must be given to the few words about keeping the rudder neutral by touch down. This is not evident by serious cross winds. Also keeping the speed as low as 55 kts over the figures is important. Than, as I observed many times, the tailwheel is touching first. This means that the direction and corrections come from both rudder and tailwheel. An instant earlier you are correcting direction only by rudder and airflow. I think the difficulty in the learning process is to apply the correct dose at the correct moment.
My two cents...
Karel Vranken, # 447 F-PKRL, still scrupulous to keep it straight.
rparigor(at)suffolk.lib.n
PostPosted: Wed Jun 13, 2007 5:16 pm    Post subject: builder test flying his own creation? Reply with quote
Reading Andys comment Europa Flyer No 37:
"With the wheel in contact with the ground any yaw resulting in a
direction change will cause a roll in the opposite direction, therefore
the opposite aileron input will be needed compared to that in flight.
Better to concentrate on maintaining directional control."
I don't quite understand what he is saying about roll.
I understand directional control is paramount.
If left yaw begins, "Right now" correction is needed with right rudder.
Is he saying that although right rudder will be needed to correct left
yaw, a bit of left aileron (opposite aileron compared to rudder input) is
needed to level wings?
Ron Parigoris
gcrowder2
PostPosted: Wed Jun 13, 2007 11:18 pm    Post subject: builder test flying his own creation? Reply with quote
Hi Ron - it is common in all the taildraggers I've flown that application of the ailerons
on the ground will result in a yaw in the opposite direction. This effect is more
dramatic on some, less on others but is very typical. Not unique to the monowheel.
I was taught that when entering a ground loop situation, always hold the ailerons
fully in the direction of the yaw and this will prevent or minimize the potential ground
loop. I really don't think the mono is any better or worse than any other TD in this
regard.
    Glenn
Date: Thu, 14 Jun 2007 01:12:15 +0000
Subject: RE: builder test flying his own creation?
--> Europa-List message posted by: <rparigor(at)suffolk.lib.ny.us>
Ron Parigoris
&gt====================
Make every IM count. Download Windows Live Messenger and join the i’m Initiative now. It’s free.  Make it count! [quote][b]
gcrowder2
regard.
    Glenn
Ron Parigoris
Play free games, earn tickets, get cool prizes! Join Live Search Club.   Join Live Search Club!
josok-e(at)ukolo.fi
PostPosted: Wed Jun 13, 2007 11:21 pm    Post subject: builder test flying his own creation? Reply with quote
Ah, that's one i found out while taxiing.
In my words then: For instance in a left turn, the plane rocks over to the
right, leaning hard on the outrigger.
With the aileron the noise on the tarmac is less, and the fuse stays
better upright.
Jos Okhuijsen
http://www.europaowners.org/kit600
pjeffers(at)talktalk.net
PostPosted: Thu Jun 14, 2007 12:35 am    Post subject: builder test flying his own creation? Reply with quote
Ron,
What Andy is saying is that it is important, neigh essential, that the wings
are kept level when the aircraft is on the ground. Remember that all other
conventional tail draggers are kept this way by the u/carriage and in
general only ground loop when pilots do not correct yaw with rudder. The
Europa is different because it will roll as it yaws. Most pilots are not
used to using aileron during ground rolls prior to lift of and after
touchdown.
If the Europa develops a yaw to the right say, it will, if you do nothing
about it, roll over onto the left outrigger. Due to the high centre of
gravity of the loaded aircraft, as the yaw increases the rolling effect
toward the left outrigger increases. Very soon after this the left wingtip
touches the ground and the rest is history (many times demonstrated)
To prevent a dangerous yawing excursion developing it is necessary firstly
to keep the wings parallel to the ground. Hence as a yaw to the right
becomes apparent, although you are going to apply left rudder to correct the
yaw, you will also need right aileron for a while to pick up the down going
wing. IE as Andy says, use the controls in the opposite sense to that in
flight.
Only if the wings can be kept reasonably level at all times will ground
looping be avoided.
The greatest cause of a yaw developing in the first instance is touching
down with the tail wheel offset from straight. If you do, it immediately
throws in a significant yawing force which is not easy to correct. Kicking
off drift and then centering the rudder immediately prior to ground contact
is therefore essential. The greater the crosswind the greater the drift
that needs to be removed and the greater likelihood of not getting it quite
right. Hence the cross wind limits I would recommend for early flights of
not more than 7kts from the left and 10kts from the right(Rotax912/914
powered aircraft). I would also apply the same limits to the take off.
Looking well ahead in the flare to some point slightly to the left of the
runway centre line will help to reduce the tendency to align the cowling
centre with the runway centre line.
I submit these comments as a Europa pilot of some 850hrs Mono and 350 hrs
Trigear. I have also sat with and converted many other Europa owner/pilots
in my capacity as PFA CRI. Oh yes and by the way I have ground looped a
Europa myself. A long time ago but I have vivid memories.
Pete Jeffers
PostPosted: Thu Jun 14, 2007 2:32 am    Post subject: builder test flying his own creation? Reply with quote
Peter,
Clear and comprehensif. I only will ad that grass is more forgiving than
hard runways hence a tip for beginners.
Thank you,
Karel Vranken, # 447 F-PKRL.
fklein(at)orcasonline.com
PostPosted: Thu Jun 14, 2007 6:27 am    Post subject: builder test flying his own creation? Reply with quote
Peter...thank you for your very clear and succinct post...it is a
keeper for my file on landing technique!
Fred
A194
On Thursday, June 14, 2007, at 01:26 AM, Peter Jeffers wrote:
<pjeffers(at)talktalk.net>
Ron,
wings
other
The
not
touchdown.
nothing
wingtip
firstly
correct the
going
in
flight.
looping be avoided.
touching
immediately
Kicking
contact
drift
quite
flights of
the
cowling
hrs
owner/pilots
a
Pete Jeffers
PostPosted: Thu Jun 14, 2007 11:39 am    Post subject: builder test flying his own creation? Reply with quote
Oh, and here I thought I was very lucid, Karel!
And yes, there are several more factors than the flexibility of the outriggers, but I am still of the opinion, that this an important part.
Of course, if the legs couldn't flex under load, they would break instead.
Niels
grahamsingleton(at)btinte
PostPosted: Thu Jun 14, 2007 3:27 pm    Post subject: builder test flying his own creation? Reply with quote
Lucky Man! Wish I had as much time airborn without an engine.
Graham
karelvranken wrote:
Niels,
PostPosted: Fri Jun 15, 2007 1:58 am    Post subject: builder test flying his own creation? Reply with quote
Karel,
Of course that is so true and is indeed a tip for beginners (and others)
Pete
Page 2 of 2
