klwerner(at)comcast.net Guest
Posted: Wed Jun 06, 2007 8:20 am Post subject: Breather run into exhaust |
Do any of you race-engine guru's out there have any idea of how much of a vacuum one can create this way? Just curious as to the suction effect of the exhaust venturi...
[quote] ----- Original
Message -----
To: rv-list(at)matronics.com (rv-list(at)matronics.com)
Sent: Monday, June 04, 2007 9:27 PM
Subject: Re: Breather run into exhaust
there is positive pressure in the crank case if you can neutralize that pressure the internal rotating parts will spin free ... resulting in free horse power. the exhaust can create a lot of suction and actually suck oil from the crank case ... be careful.
on a pumped up / modified I0-360 with a 4 into 1 exhaust i used a stainless 1/2 in tube welded into the collector at 45 degree angle ... plus ... a metered 'pill' to get the correct vacuum pressure. i monitored oil consumption changing the orifice size until oil consumption was normal. the house power increase was the most notable of all previous mods.
yes ... a poor mans smoke system but no more oil on the belly ... do it! lots of acro guys do ...
mike
See what's free at AOL.com.
href="http://www.matronics.com/Navigator?RV-List">http://www.matronics.com/Navigator?RV-List
| [b]
Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Wed Jun 06, 2007 10:54 pm Post subject: Breather run into exhaust |
In a message dated 6/6/2007 11:15:46 AM Central Daylight Time, klwerner(at)comcast.net writes:
| Quote: | | Why do you have an oil separator if you don't reuse the oil in the first place. What is the purpose of separating the oily air mix and then discard both onto the exhaust pipe??? I'd remove the weight of the useless contraption... |
Re-using the oil is not the issue, which many say is a bad idea as it routes nasty stuff back into the sump- keeping the "dirty side" less so is. Better (IMHO) to collect as much blow-by crud that might normally blow out onto yer belly and discard it with the old oil at oil change time. See:
http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=5172
Click on >>Next Entry>> for next 3 entries and on fotos for bigger view. Here's the "proof in da puddin' ":
http://websites.expercraft.com/n51pw/index.php?q=log_entry&log_id=5261
Just an option, but this has really worked out quite nicely after 415+ hours operation on my plane. Cheap, simple, effective...
From The PossumWorks in TN,
Mark
_________________ From The PossumWorks... |
Posted: Thu Jun 07, 2007 7:03 am Post subject: Breather run into exhaust |
Hi Mark,
I fully agree with you for not putting the crud back into the engine after separating it. Your case is different though, as you accumulate the crud until the next oilchange and then drain it.
But in Jeff's case he ran the vent tube AND the smaller drain tube onto the exhaust to burn off everything that came out of the breather. So my thought was why bother using a separator if both end up on the hot exhaust anyway. I'd just run a tube onto the exhaust and be done with it by burning both.
Konrad
shempdowling2(at)earthlin Guest
Posted: Thu Jun 07, 2007 12:20 pm Post subject: Breather run into exhaust |
I agree with you Konrad. I havent flown since I removed the return line
to the oil filler neck and I will now place the return into a small
glass jar just to see what come's out.
Thanks for the no brainer.
Jeff Shemp Dowling
Konrad L. Werner wrote:
[quote] Hi Mark,
Konrad
Mark Phillips in TN
Posted: Thu Jun 07, 2007 2:12 pm Post subject: Breather run into exhaust |
In a message dated 6/7/2007 10:05:37 AM Central Daylight Time, klwerner(at)comcast.net writes:
| Quote: | | So my thought was why bother using a separator if both end up on the hot exhaust anyway. I'd just run a tube onto the exhaust and be done with it by burning both. |
100% agreed, just offering an option- good to hear from ya Konrad!
Take care & do not archive
Mark
