Posted: Tue Dec 19, 2006 1:44 pm Post subject: Tapping flap pushrod |
Thanks......
pcondon(at)mitre.org Guest
Posted: Wed Dec 20, 2006 6:49 am Post subject: Tapping flap pushrod |
Another approach is to use threaded rod and insert the threaded rod
portion thru the aluminum tube with jam nuts at both ends for
structural rigidity. Exchange the rod end bearings from male ends to
female ends and you have a completed flap rod. Used Stainless thread
all from McMaster/Carr, lubed up the thread-all and jammed nutted it
closed.
The reason for this approach was the mess of threading the hollow
aluminum rod, as per Vans plans. I cut a few open (long ways) with a
dremmel and was surprised of the crappy threading that was internal to
the aluminum tubing. I am much happier with this threaded rod solution.
When completed you can't tell any difference visually between the
threaded hollow rod
Oldsfolks(at)aol.com Guest
Posted: Fri Dec 22, 2006 7:13 am Post subject: Tapping flap pushrod |
Just go to NAPA store and get "Rapid Tap - for Aluminum" and your threads will come out very well ; mine did , several times.
Bob Olds
RV-4
Charleston,Arkansas
