transponder antenna placement
Goto page Previous  1, 2
bob.kaufmann(at)cox.net
PostPosted: Tue Nov 28, 2006 4:23 am    Post subject: transponder antenna placement Reply with quote
Darn, there goes the though of the cheap vasectomy, so I could put more
money into the instrument panel. I was hoping for double duty so to speak.
LOL. Do not archive.
Bob K
Mounting antennas
wayne.e(at)grandecom.net
PostPosted: Tue Nov 28, 2006 4:46 am    Post subject: transponder antenna placement Reply with quote
Chris,
For whatever it's worth I put the transponder in the tunnel as far forward as I could right up next to the firewall and I put the Ryan on the pilots side next to the tunnel forward of the landing gear, so as not to be obstructed. I didn't want another antenna to close to the Ryan if possible.
Wayne Edgerton #40336
MChase(at)gdatp.com
PostPosted: Wed Nov 29, 2006 4:46 am    Post subject: transponder antenna placement Reply with quote
Guys,
Sort of a late post, but I am a former TomCat guy and you would be shocked to hear the number of guys from my community that ended up with testicular cancer. The Navy wasn't really doing any tests or gathering statistics that the number of guys who ended with issues really seemed to stand out at least in my age group. I don't have any proof but sitting with the world's most powerful air intercept radar between your legs seems to have some impact.
On a more building related note can anyone help me out with lighting. I am working on my empennage kit and have been told by others not to order my light kit due to bulb aging but it seems I should be running conduit now? Can anyone tell me were to run it and what they used?
Michael Chase
General Dynamics Armament and Technical Products
802-657-6029 Office
802-922-5930 Cell
mchase(at)gdatp.com
This e-mail message (including attachments, if any) is for the sole use of the intended recipient(s) and may contain information that is private, confidential, or exempt from disclosure. Any unauthorized review, use, copying, printing, disclosure, retention, or distribution is strictly prohibited. If you are not the intended recipient, please contact the sender by reply to this e-mail, and delete all copies without disclosing this message to others. Thank you.
[img]cid:1__=0ABBF8A6DFD6D9A98f9e8a93df9386(at)gdatp.com[/img]"John Gonzalez" <indigoonlatigo(at)msn.com>
[img]cid:2__=0ABBF8A6DFD6D9A98f9e8a93df9386(at)gdatp.com[/img]
cc:
Subject: RE: Re: transponder antenna placement
--> RV10-List message posted by: "John Gonzalez" <indigoonlatigo(at)msn.com>
Under the seat however, the moicrowaves would be going through several
layers of metal to find your privates, unless your a low hanger.
DO not archive
>From: "RV Builder (Michael Sausen)" <rvbuilder(at)sausen.net>
>Reply-To: rv10-list(at)matronics.com
>To: <rv10-list(at)matronics.com>
>Date: Mon, 27 Nov 2006 14:59:20 -0600
>--> RV10-List message posted by: "RV Builder (Michael Sausen)"
>Sounds like a good episode of Mythbusters. Adam can put his nads in a
>microwave and Jamie can sit on a transponder antenna while being
>regularly interrogated or pushing ident. ROFLMAO!
>Seriously though, I don't think anyone has ever done a serious study on
>this. In reality any potential health issues are probably pretty small.
>You probably get more rads from the solar radiation at 15,000 feet than
>from the transponder. I still wouldn't put it right under my seat
>though. The biggest issue in placement is keeping the antenna lead as
>short as possible.
>Michael Sausen
>-10 #352 fuselage
 Filesize:  105 Bytes
 Viewed:  1605 Time(s)
 Filesize:  45 Bytes
 Viewed:  1608 Time(s)
 Filesize:  1.23 KB
Rick S.
PostPosted: Wed Nov 29, 2006 6:32 am    Post subject: transponder antenna placement Reply with quote
Michael,
I used snap bushings to route from the tail forward then conduit from the battery area forward. You could use smaller diameter diameter conduit than the 3/4" available from Van's but it would be OK as long as the holes weren't opened too much through the bulkheads, actually you could just zip tie the conduit to the bulkheads. The only wires from back there are the tail light, strobe, elevator trim and VOR antenna if you are using one in the tail. The tail light & strobe wires combo exits the last bulkhead through a 3/16's hole and enters the bottom fairing using a molex connector on the strobe and a simple spade connector on the bulb.
Rick S.
40185
Rick S.
RV-10
40185
Page 2 of 2
