Water Drain
Goto page Previous  1, 2
budyerly@msn.com
PostPosted: Fri May 14, 2021 3:49 pm    Post subject: Water Drain Reply with quote
Oh, knock it off guys.
Everyone has opinions, likes, wants and prejudices. My feelings don’t get hurt and neither should anyone else’s. However, as in kindergarten, I was taught to stay in line, be nice, keep your hands to yourself and wait your turn until it is your turn.
I, like some others, just aren’t always good at it. We may have strayed from the teaching of our past and one must try to get what he/she/person/comrade wants or needs, and we don’t want to get it without offending or misleading someone.
Opinions/wants/prejudices are like butt holes, everyone has one, just keep it clean and don’t abuse anyone else’s.  Techniques are just that, someone’s technique, not a procedure. Let’s keep being cheerleaders for one another. Criticizing should be constructive and taken without offense. Persistently pursue the optimum aircraft for you, and all the 20,000 compromises one makes building an aircraft, not persistently press your opinions on to others as the only way.
I try to speak my piece, and Griffo and I should have gone off line as we (well I) wandered around the plumbing issues of the Europa just clogging up the forum. My apologies for dragging it out.
Best Regards,
Bud Yerly
From: owner-europa-list-server(at)matronics.com <owner-europa-list-server(at)matronics.com> On Behalf Of William Daniell
Sent: Friday, May 14, 2021 5:47 PM
Subject: Re: Re: Water Drain
Bud is enormously helpful to all of us and very generous with his time and I very much respect his advice. He is the most experienced among us having built many aircraft and guided many builders through the process, myself included. Without the encouragement of the forum and especially Bud I would not have achieved my wonderful aircraft.
Will
William Daniell
LONGPORT
+1 786 878 0246
On Fri, May 14, 2021 at 2:31 PM Griffo <scangriffin(at)bigpond.com.au (scangriffin(at)bigpond.com.au)> wrote:
--> Europa-List message posted by: "Griffo" <scangriffin(at)bigpond.com.au (scangriffin(at)bigpond.com.au)>
Hi Kelv/Peter Z,
My apologies for any offence taken - certainly not intended.
>From my point of view, the saying, should be read as - ideas can be put forward with the best of intentions/experience but not necessarily received/adopted as the need/will to do so is not apparent.
Bear in mind, that my suggestion has also been likened unto a lawn mower fitting - put down? - possibly.
46
http://forums.matronics.com/viewtopic.php?p=501939#501939
WIKI -
<![if !supportLineBreakNewLine]> <![endif]>
DuaneFamly(at)aol.com
PostPosted: Fri May 14, 2021 5:32 pm    Post subject: Water Drain Reply with quote
Well I for one like being the fly on the wall to people’s conversations. Working months with Bud taught me a lot in the way of approaching a problem. But I still learn from other’s conversations. You never know what you don’t know until you know it. Mike Duane
N377EA Europa XS conventional gear
Jabiru 3300 powered
Chandler, Arizona
On May 14, 2021, at 4:49 PM, Bud Yerly <budyerly(at)msn.com> wrote:
 <![endif]--> 80 Clean Clean DocumentEmail false false false EN-US X-NONE X-NONE <![endif]--> <![endif]-->/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri",sans-serif; mso-ascii-font-family:Calibri; mso-hansi-font-family:Calibri; mso-bidi-font-family:"Times New Roman";} <![endif]--> <![endif]--> <![endif]-->
Best Regards,
Bud Yerly
Will
William Daniell
LONGPORT
+1 786 878 0246
Hi Kelv/Peter Z,
46
WIKI -
Page 2 of 2
