VHF antenna in the tail
Goto page Previous  1, 2
gilles.thesee(at)free.fr
PostPosted: Sat Dec 23, 2017 5:03 am    Post subject: VHF antenna in the tail Reply with quote
Robert L. Nuckolls, III a écrit :
  Can you describe the physical configuration of
  the vertical fin vis-a-vis the empennage? Is
  the vertical fin detachable?
Hi Bob,
Thank you for responding.
The vertical fin is integral with the fuselage, which comes as two halves bonded together along the vertical plane of symmetry, like a plastic model.
The whole airframe is carbon, except the vertical fin which is made of glass.
Hope the included picture taken some days ago is getting through.
[img]cid:part1.B2F783AE.59E84245(at)free.fr[/img]
  I presume the antenna, once installed, will
  forever more be inaccessible for tweeking?
The antenna istself will be enclosed in the vertical fin.
We'll have some access by crawling in the fuselage up to "some distance" from the fin base.
Also there will be a removable aft tail-cone to give some access to the control linkage in the tail and -hopefully- to the antenna connection.
Depending on the details, we might be able to make the antenna removable by sliding it into a plastic tube installed in the tail ?
Thanks for your advice,
Best regards,
Gilles
http://contrails.free.fr
 Filesize:  466.29 KB
 Viewed:  4586 Time(s)
PostPosted: Sat Dec 23, 2017 6:28 am    Post subject: Re: VHF antenna in the tail Reply with quote
If there is access to the inside of the tail cone, then put the ground plane inside. It can either be a large sheet of thin metal, or else radials made from wire or metallic tape. The fore and aft radials can be horizontal. The left and right radials can follow the curved tail skin.
Joe Gores
rnjcurtis(at)charter.net
PostPosted: Sat Dec 23, 2017 6:55 am    Post subject: VHF antenna in the tail Reply with quote
I noticed that the inside of the fuselage is black.  Is it carbon fiber or is that just a layer of black poly?
Roger
Sent: Saturday, December 23, 2017 8:06 AM
Subject: Re: VHF antenna in the tail
Hi Bob,
Best regards,
Gilles
 Filesize:  466.29 KB
 Viewed:  4578 Time(s)
ceengland7(at)gmail.com
PostPosted: Sat Dec 23, 2017 7:59 am    Post subject: VHF antenna in the tail Reply with quote
Answered in the post to which you responded....
Smile
On 12/23/2017 8:55 AM, Roger wrote:
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]-->
Roger
Hi Bob,
Best regards,
Gilles
www.avast.com [url=#DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2] [/url]
Page 2 of 2
