Service Bulletin
Goto page Previous  1, 2
gspecketer(at)gmail.com
PostPosted: Tue May 10, 2016 5:08 pm    Post subject: Service Bulletin Reply with quote
The aft side needs to be inspected too. The top rivets on the aft side cannot be seen without access behind the angle close out panel.
Gary Specketer
On May 10, 2016, at 8:45 PM, Jim Combs <jiminlexky(at)gmail.com (jiminlexky(at)gmail.com)> wrote:
Trying to post this for the third time. (Images too large!)
I used my Samsung Galaxy S5 Cell phone camera to take pictures.  I have attached the raw and cropped photos for reference. I only attached the right side so as to not clutter up the forum with picture data.  I reduced the size of the "Raw" image to allow it to post. but you can see what the camera took before I cropped and zoomed the area of interest.
Turn on the flash, auto-focus and insert the camera in the inspection hole with the camera just inside the hole and the phone resting on the edge. Take the picture and then crop / zoom in on the area of interest. Did the same thing on the outside with the aileron up and down.
Both sides took 20 minutes.
I think this is good enough to do the inspection. Someone correct me, but I don't think removing the flaps and ailerons exposes much more of the area?
Aircraft has 856 hours over 5 years of flying.
Jim C
On Tue, May 10, 2016 at 1:55 PM, John Trollinger <john(at)trollingers.com (john(at)trollingers.com)> wrote:
Jim,
Can you attach the photos, trying to see best way to get images of the area.
thanks,
On Tue, May 10, 2016 at 12:26 PM, Jim Combs <jiminlexky(at)gmail.com (jiminlexky(at)gmail.com)> wrote:
I too was able to inspect the area without removal of the flaps or ailerons. I took pictures with my Samsung phone and they turned out just fine.
856 hours total time - no cracks.
Jim Combs
No Archive
On Tue, May 10, 2016 at 11:12 AM, Alan Mekler MD <amekler(at)metrocast.net (amekler(at)metrocast.net)> wrote:
--> RV10-List message posted by: Alan Mekler MD <amekler(at)metrocast.net (amekler(at)metrocast.net)>
were they able to inspect both places without removing anything?
Alan
> On May 10, 2016, at 10:39 AM, iMac <cgroote1(at)yahoo.com (cgroote1(at)yahoo.com)> wrote:
> --> RV10-List message posted by: iMac <cgroote1(at)yahoo.com (cgroote1(at)yahoo.com)>
> This morning the FBO here used their borescope on my -10. There was enough room without doing any extra work. Time - minutes.
WIKI -
<Right-Wing-Small.jpg>
<Right-Wing-Cropped.jpg>
amekler
PostPosted: Tue May 10, 2016 5:15 pm    Post subject: Service Bulletin Reply with quote
Jim,
Which inspection hole did you use?
Alan
Jim C
Jim,
thanks,
Jim Combs
No Archive
Alan
WIKI -
rene(at)felker.com
PostPosted: Tue May 10, 2016 5:43 pm    Post subject: Service Bulletin Reply with quote
I just did mine.  No disassembly.  No cracks.  Use bore scope.  Took longer to remove and replace the inspection plates than to do the instpection.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Alan Mekler MD
Sent: Tuesday, May 10, 2016 7:15 PM
Subject: Re: Re: Service Bulletin
Jim,
Alan
Jim C
Jim,
thanks,
Jim Combs
No Archive
Alan
WIKI -
EdKranz
PostPosted: Tue May 10, 2016 6:18 pm    Post subject: Service Bulletin Reply with quote
Anyone who's done the inspection:
Were you able to fit the borescope inside of the gap fairing without removing the aileron or trimming the gar fairing corner (to inspect the aft side of the spar)?
On Tue, May 10, 2016 at 8:42 PM, Rene <rene(at)felker.com (rene(at)felker.com)> wrote:
From: owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com) [mailto:owner-rv10-list-server(at)matronics.com (owner-rv10-list-server(at)matronics.com)] On Behalf Of Alan Mekler MD
Jim,
Alan
Jim C
Jim,
thanks,
Jim Combs
No Archive
Alan
WIKI -
Ed Kranz
RV10
Finishing
www.edandcolleen.com
cooprv7(at)yahoo.com
PostPosted: Tue May 10, 2016 7:10 pm    Post subject: Service Bulletin Reply with quote
The pictures I attached earlier from the Amazon inspection camera were taken by routing the camera behind the gap fairing using the enclosed mirror.
Marcus
On May 10, 2016, at 10:17 PM, Ed Kranz <ed.kranz(at)gmail.com (ed.kranz(at)gmail.com)> wrote:
Jim,
Alan
Jim C
Jim,
thanks,
Jim Combs
No Archive
Alan
WIKI -
Jim Combs
PostPosted: Wed May 11, 2016 8:06 am    Post subject: Service Bulletin Reply with quote
I used the most outboard one.
Jim C
On Tue, May 10, 2016 at 9:14 PM, Alan Mekler MD <amekler(at)metrocast.net (amekler(at)metrocast.net)> wrote:
Jim,
Alan
Jim C
Jim,
thanks,
Jim Combs
No Archive
Alan
WIKI -
RV-10 -> N312F - Flying as of 12/2008
TimRVator(at)comcast.net
PostPosted: Mon May 16, 2016 9:44 am    Post subject: Service Bulletin Reply with quote
I used the ViVida AbleScope VA-400 ($150 from Amazon) with the tip
articulated to 180 degrees (so the scope is looking back at the
handle). This worked well on both sides, so I don't see the need to
remove the aileron and perform surgery on the gap seal. I'll attach a
photo so you can see what I was able to capture with the scope.
Tim Lewis -- HEF (Manassas, VA)
A&P
RV-6A N47TD -- 1104 hrs - sold
RV-10 N31TD -- 740 hrs
Ed Kranz wrote on 5/10/2016 10:17 PM:
the instpection.
<mailto:owner-rv10-list-server(at)matronics.com>
<mailto:owner-rv10-list-server(at)matronics.com>] *On Behalf Of *Alan
Mekler MD
*Sent:* Tuesday, May 10, 2016 7:15 PM
*To:* rv10-list(at)matronics.com <mailto:rv10-list(at)matronics.com>
*Subject:* Re: Re: Service Bulletin
Jim,
Alan
Jim C
<john(at)trollingers.com <mailto:john(at)trollingers.com>> wrote:
Jim,
images of the area.
thanks,
Jim Combs
No Archive
Alan
minutes.
WIKI -
rel="noreferrer"
 Filesize:  35.12 KB
 Viewed:  10079 Time(s)
Tim Olson
PostPosted: Mon May 16, 2016 10:00 am    Post subject: Service Bulletin Reply with quote
That's great to hear. I got mine and it looks like it will be a very
nice tool for
many things. The best photos of inside the wing I saw came from cell
phones, but, if you need to inspect a cylinder, or under a flap gap seal,
this camera really looks like a time and energy saver.
Tim
philperry9
PostPosted: Mon May 16, 2016 10:44 am    Post subject: Service Bulletin Reply with quote
I just picked mine up off the door step 5 minutes ago.   Connected it to the MacBook, opened photo booth, and bingo!  I can now record video..
Pretty cool to play with.  I'm looking forward to showing my kids the inside of their ears now....  There's no more debate.  Smile
On Mon, May 16, 2016 at 12:59 PM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
--> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
That's great to hear. I got mine and it looks like it will be a very nice tool for
Tim
I used the ViVida AbleScope VA-400 ($150 from Amazon) with the tip articulated to 180 degrees (so the scope is looking back at the handle).  This worked well on both sides, so I don't see the need to remove the aileron and perform surgery on the gap seal. I'll attach a photo so you can see what I was able to capture with the scope.
WIKI -
Kelly McMullen
PostPosted: Mon May 16, 2016 4:42 pm    Post subject: Service Bulletin Reply with quote
That they have rabbits or owls in their ears? Wink
-sent from the microchip implanted in my forearm
On Mon, May 16, 2016 at 11:43 AM, Phillip Perry <philperry9(at)gmail.com (philperry9(at)gmail.com)> wrote:
Tim
WIKI -
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
philperry9
PostPosted: Mon May 16, 2016 4:56 pm    Post subject: Service Bulletin Reply with quote
We call then ear boogers.
I'll use it to inspect an RV-6 tomorrow and see how well it works in that airframe. Pretty neat tool for the price.
On May 16, 2016, at 7:40 PM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
Tim
WIKI -
Page 2 of 2
