RF Interference
Goto page Previous  1, 2
PostPosted: Thu Apr 14, 2016 12:39 pm    Post subject: RF Interference Reply with quote
At 12:34 PM 4/14/2016, you wrote:
I've got a question about substituting a battery for the sender's output.
In my (somewhat dim past) experience, the impedance of the line in question had a major effect on its vulnerability to noise induced on it. So.... is this a valid test? I'd assume that the internal impedance of even a AA battery would be much lower than any electronic sensor normally used around an engine.
The purpose of this test was to divide an conquer.
Until the sensor (a variable voltage source with
ACTIVE hence vulnerable components) then we
are unsure whether the vulnerability is in the
signal source or the panel display.
It isn't the WIRE with a vulnerability, it is
merely a conductor (first) and perhaps an antenna
(second) which carries the antagonistic energy
into the victim. Adding inductance reduces the
wire's ability to conduct . . . as demonstrated
in the video.
99% of the time, the victim is some solid state
device that is being forced out of it's normal
operating boundaries by the interfering energy.
This experiment gave us a high order of confidence
that the transducer is the victim.
The itty-bitty filter is about 0.4 x 0.8 inches.
It was crafted and first used on an LED lamp
assembly being considered for an ultralight.
It did limit VHF emissions sufficiently to
make this fixture useable.
[img]cid:.0[/img]
I've since shipped out several to other builders
but I don't think I've heard back.
The ferrite chip inductors were rated for
700 ohms reactance at 100 mHz, the monolythic
chip capacitors on either side are on the order
of 0.1 ohms . . . so I would expect this
assembly to be an excellent fire wall at
VHF comm frequencies for CONDUCTED noise,
probably so good that any problem energies
remaining are likely to be RADIATED for
which solutions are different.
I've got a new spectrum analyzer and tracking
generator that's still in the box. As soon
as I get some time to have some 'fun', I'll
be able to quantify the effectiveness of
such devices over a range of frequencies.
I sure do miss access to the EMC labs at
Hawker/Beech!
 Filesize:  45.54 KB
 Viewed:  1679 Time(s)
PostPosted: Thu Apr 14, 2016 12:57 pm    Post subject: RF Interference Reply with quote
Your itty-bitty filter:
1. how big is it? perhaps put a penny in the picture
about .4 x .8 inches
2. when you designed the filter, what frequency are you trying to filter? I'm guessing it's somewhere in 110-140 MHz but what about harmonics?
yes, the parts are 'speced' in the VHF comm
range but effectiveness of the array extends
upward a decade or more.
3. are those tiny surface-mount components an inductor & a cap? (or is it the case that: "you could tell me but then you'd have to kill me?" Wink
No big deal. Pick a series reactance from
this array of possibilities . . .
http://tinyurl.com/zn4knzj
Primary concerns are current trough the inductor
and voltage drop in the inductor. Then see
how high a reactance you can get within space
and volume concerns. Capacitors either side need
not me more than 1 to 10 nF . . . These monolythic
capacitors have 'dips'in impedance in the
regions around VHF comm . . . but still quite
useful over the regions on either side.
[img]cid:.0[/img]
Designing these filters is not very technical.
They're easy to craft with a brute force approach
to energy attenuation above 20 MHz or so.
 Filesize:  129.23 KB
 Viewed:  1678 Time(s)
Page 2 of 2
