chaztuna(at)adelphia.net Guest
Posted: Thu Sep 14, 2006 11:19 am Post subject: Iridite Wanted to Buy |
Vini,
Yes 1201 has a gold colored dye in it. The dye helps you determine when the part has been exposed to the chemicals for the correct amount of time. Alodine 1200 is clear, and therefore much harder for the beginner to use.
I would suggest checking with businesses who sell chemicals for the plating trade (ie chrome plating, cadmium plating, anodizing, etc). My local supplier of MacDirmid's Iridite 14-2, is:
Allied Plating Supply
Hialeah, Florida
USA
Note that the company's name tells you that they sell plating supplies. Perhaps a Google search under PLATING SUPPLIES GERMANY would yield results?
Good luck and let me know if you find a supplier.
Charlie Kuss
---- Vinod Wahi <vinod.wahi(at)googlemail.com> wrote:
[quote] Charlie Thanks for info. I will try to contact Henkel in Germany, You say
Alodine 1201 is the product I need.
Vini
2006/9/14, Sherman Butler <lsbrv7a(at)yahoo.com>:
> Try
> http://www.eldoradochem.com/conversion-coatings.htm
> *Vinod Wahi <vinod.wahi(at)googlemail.com>* wrote:
> Hi Every body,
> This my first mail. I am first time builder, started with 9A emp. Can any
> one advise me where I can buy alodine powder in Germany.
> Thanks.
> Vini
> 2006/9/13, Tim Olson <Tim(at)myrv10.com>:
> > I may have some powdered alodine that I might be willing to part
> > with. I'd have to look up my original price to even have a guess
> > at it's value, but I'm sure I have enough to make a few gallons
> > anyway. Contact me off-list if you think you might be interested
> > and I'll try to figure out what quantity I have.
> > Tim Olson - RV-10 N104CD - Flying
> > do not archive
> > RV Builder (Michael Sausen) wrote:
> > rvbuilder(at)sausen.net>
> > > I also saw the same effect with the older solution. I keep it in a
> > 32
> > > gallon Rubbermaid trash can that doubles as the dip tank. As it
> > > approached 6 months old it was taking forever for it to convert a
> > layer
> > > on the aluminum. I guessed that it was mainly due to the chemicals
> > > precipitating out and was apparently correct. I added a couple
> > aquarium
> > > style circulating power heads and it was like new after that. Going
> > on
> > > 1.5 years on the same original batch and completed the majority of
> > parts
> > > on my RV-10. I also keep it covered and out of direct sunlight.
> > > Michael Sausen
> > > -10 #352 Fuselage
Doug Gray
Joined: 10 Jan 2006 Posts: 112 Location: Sydney, Australia
Posted: Fri Sep 15, 2006 2:30 pm Post subject: Iridite Wanted to Buy |
How would I alodine the outside skin prior to painting?
I am thinking of sloshing it on with a cloth rag from a bucket or is
there a better way?
Doug Gray
On Thu, 2006-09-14 at 12:18 -0700, chaztuna(at)adelphia.net wrote:
Vini,
Hialeah, Florida
USA
Charlie Kuss
> Vini
> > Try
> > Hi Every body,
> > Thanks.
> > Vini
> > > do not archive
> > > 32
> > > layer
> > > aquarium
> > > on
> > > parts
> > > > Michael Sausen
> > > > -10 #352 Fuselage
