Ray.R.Doerr(at)sprint.com Guest
Posted: Fri May 26, 2006 8:27 pm Post subject: N519RV did two very short first Flights today. |
Thank You
Ray Doerr
CDNI Principal Engineer
Sprint PCS
16020 West 113th Street
Lenexa, KS 66219
Mailstop KSLNXK0101
(913) 859-1414 (Office)
(913) 226-0106 (Pcs)
(913) 859-1234 (Fax)
Today we did the first flight of N519RV (40250). Takeoff seemed
normal at first except my test Pilot Joe Shetterly was only climbing out
at 90 Knots and maybe 500 ft/min with only 2200 lbs. Turns out the
engine was only running at 2100RPM with MP at 28". I think this is what
resulted in the Oil temp running very hot at 250 degrees. Joe landed it
right away and we removed the cowl to let it cool down. OAT was about
90 degrees. Once the oil temp was down to 160, Joe tried another
flight, this time trying to keep the airspeed around 120 Knots, this
airspeed with the low RPM did not allow for very much climb at all.
Around this RPM, I figure it was only developing around 45% power,
enough for a take off compare to a Cessna 150, but no where near the
2,000 ft/min I expected for a 2200 lb gross weight. The prop is able to
cycle fine, but we can't get more that 2100 rpm static on the ground and
that is even after I change the Prop Gov stop to the point where it hit
the hard stop of the metal that hold the stop bolt. It seems that the
prop gov is not allowing the prop to go to full flat pitch to allow the
engine to run to it's full 2700 rpm. I have asked everyone at my local
airport for any suggestion, but so far, no one has come up with anything
we can try to get the RPM up to Take Off RPM. My setup is identical to
most of the other RV-10's that are flying. I bought the Firewall
Forward kit from Van's which included the MT Prop Gov P/N P-860-3 and
the Blended Hartzell Prop HC-C2YR-1BFP/F8068D. My engine is a rebuilt
IO-540-D4A5, dual mags, Precision Silver Hawk EX fuel injection, 260 HP.
If anyone has any ideas on what my problem could be, I would really
appreciate it. We were hoping to fly the 25 hours off this long
weekend, but it's not worth attempting another flight till we try
something that might make a positive change of this situation.
Ray Doerr
40250
N519RV (Flying, but still having problems)
Posted: Sat May 27, 2006 2:06 am Post subject: N519RV did two very short first Flights today. |
Since I went to bed all I could think about is how to solve this
problem of low RPM. According to the Prop Gov P/N, the 6 in the P-860-3
means Pressure to increase pitch - CW. Also ther is a paragraph in
section 5.5 that states "As a general rule, engine redline RPM cannot be
reached during a full power static run-up Contrary to popular belief,
the governor is not controlling the propeller at this time, the
propeller is against its low pitch stop. Attempting to increase
propeller static run-up RPM by adjusting the governor high RPM screw
will have no effect and will probably result in a propeller overspeed
during the take-off roll".
Once I read that and confirmed that backing off the high RPM
stop screw on the Gov by 3/8" had no effect, it looks like my problem
lies in the low picth stop of the Propellar hub.
By the way the fuel flow on a high speed taxi test was 21 GPH.
With this info in hand, I went at the Prop manual and found that
the low pitch stop is the one at the center front of the hub. This bolt
has 24 threads per inch and by turning it out one full turn is
approximately an increase by 200 RPM.
At this moment, I think I will try and turn it out one full turn
and see if the RPM will come up the 200 RPM to 2300. If that works, I
will need to turn it out two more full turns for the 2700 RPM required
for take-off. I will then return the prop gov stops back to there
original setting.
If anyone has had to do this on there flying RV-10, I would like
to here from you. If anyone has any other ideas, I would also like to
hear them.
Thanks for now. I'm off to the airport.
Ray Doerr
40250
N519RV
Ray Doerr
40250
Tim(at)MyRV10.com Guest
Posted: Sat May 27, 2006 4:19 am Post subject: N519RV did two very short first Flights today. |
Good luck today Ray! When you called yesterday, that center of the hub
screw/nut was the one I was talking about, but I'm not too in-the-know
about it because how mine allowed for 2690 or so with no tweaking.
I bet you change that today and everything goes much better. My dad
came by while I was talking to you and after we were off the phone
we thought through it and agree that your oil temp could very well
be related to lugging the engine along at high MP with low RPM.
My advice is to make sure you get your static RPM up to at least 2600
before you take her for another spin, and shoot for that 2700. I'm
sure you're on the right track, and good luck again! When everything
goes perfectly and you've got that RV grin still plastered on your
face, give me another call.
Doerr, Ray R [NTK] wrote:
original setting.
hear them.
Ray Doerr
40250
N519RV
Ray Doerr
40250
jesse(at)itecusa.org Guest
Posted: Sat May 27, 2006 6:29 am Post subject: N519RV did two very short first Flights today. |
Are you sure you are only getting that RPM? We thought we were having a
similar problem, but when we used an external (laser-type-thingy) tach we
were actually over RPM. Your experience on power, however, would certainly
agree with you. I didn't do the adjustments on the prop governor, but I
know it can be picky.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
352-465-4545
toaster73(at)earthlink.ne Guest
Posted: Sat May 27, 2006 6:30 am Post subject: N519RV did two very short first Flights today. |
This seems to be a heads up to the rest of us on our test flight preps. I am
just now starting on the fuselage so I am not up on all the engine stuff
yet...But for the certified aircraft, the type certificate data sheet
usually lists the engine propeller combination along with the maximum
allowed and minimum allowed full throttle static rpms. Do we not have this
info for a 540 with blended airfoil prop? Seems to me this first flight
could have been the last flight very easily.
In my Bonanza I had an electric prop and descended over NYC down the Hudson
for sight seeing, when I got to the Statue of Liberty I went to climb back
out only to find that my prop would not go to fine pitch, it was stuck. So I
landed at the next airport and on final my partner/co-pilot suggested I make
the landing. No room for a go-around! A broken wire kept my prop motor from
going fine. This happened to the previous owner and on landing he had
barely enough thrust to taxi since the engine was so loaded up by the pitch
being stuck in nearly full coarse.
Did your test pilot monitor for full static rpm before releasing brakes for
takeoff? We always did that in the Bonanza.
Thanks for the report another possible gotcha for Tim's website.
-Chris Lucas
#40072
Posted: Sat May 27, 2006 7:35 am Post subject: N519RV did two very short first Flights today. |
Jesse, is there anything strange about setup on the Dynon? I
know Ray has a Dynon too, and if there is anything that needs
to be set properly to display RPM correctly, I'm sure he'd love
to hear it....as would the list. On my setup, I have the
GRT EIS6000, and I just had to set the tach Pulses per revolution
to I believe 3, because that's what the Lightspeed ignition
put out. And the wire out of the Lightspeed feeds directly to
the EIS6000. (That info is just for future reference by archive
searchers)
T
Jesse Saint wrote:
Jesse Saint
I-TEC, Inc.
www.itecusa.org
352-465-4545
Posted: Sat May 27, 2006 7:38 am Post subject: N519RV did two very short first Flights today. |
Your point is very well taken Chris. My DAR didn't care to see
much of the engine running. He wanted me to taxi it out, and
back, and turn. But then he did have just one thing that he
insisted on....that he be in the plane for a full-power static
RPM runup test to see what RPM it came to. I know that with
a new engine, people don't want to run it on the ground at high
power, but hey, your engine can handle the 15 seconds of
full-power runup required to verify static RPM before you
take your first flight.
Just FYI to the list, I think I saw 2690 RPM or something like
that when I did my runup, and I *think* the spec is 2700 for
your target. I'll add some info to the tips area next time
I update the site.
I am just now starting on the fuselage so I am not up on all the engine
stuff yet...But for the certified aircraft, the type certificate data
sheet usually lists the engine propeller combination along with the
maximum allowed and minimum allowed full throttle static rpms. Do we not
have this info for a 540 with blended airfoil prop? Seems to me this
first flight could have been the last flight very easily.
Hudson for sight seeing, when I got to the Statue of Liberty I went to
climb back out only to find that my prop would not go to fine pitch, it
was stuck. So I landed at the next airport and on final my
partner/co-pilot suggested I make the landing. No room for a go-around!
A broken wire kept my prop motor from going fine. This happened to the
previous owner and on landing he had barely enough thrust to taxi since
the engine was so loaded up by the pitch being stuck in nearly full coarse.
for takeoff? We always did that in the Bonanza.
-Chris Lucas
#40072
johnwcox(at)pacificnw.com Guest
Posted: Sat May 27, 2006 8:17 am Post subject: N519RV did two very short first Flights today. |
Ray it is exciting that you and your test pilot Joe were able to get a
test flight in and that you shared with the group your initial findings.
My mental questions were;
#1 did you and the test pilot confirm static rpm output to the limit
prescribed by the manufacturer BEFORE taxi testing?
#2 Did you do high speed taxi and did the anomaly of oil temp appear?
#3 Did the test pilot do a complete run up to proper rpm, check the mags
and FULLY cycle the prop stop to stop 3x before takeoff? If you only
get 2100, I would not call that fine.
#4 Did you visually witness full blade pitch change from outside the
cockpit during each of the three cycles?
#5 Did you confirm full range of motion on the Prop Control cable at the
governor with cable springback at the instrument panel?
#6 Was the oil up to minimum temperature (which on a new engine should
have been a non issue)? Sounds like a possible viscosity issue with the
oil or a control cable miss setting. You may have something on the MT
governor set screw. Oil passages are the rarest of causes.
Did the problem then develop only after each of the previous questions
confirmed proper operation? Don't tell me the test pilot took off
without everything in the green first. I know a lot of pilots who do not
know how or why a prop check is properly done (A great question for this
forum). I agree with Tim, get the problem fixed and we hope to hear the
final solution and the grin appearing on your face soon. "Take off
power" when you want it is really important all the time. Go Rounds
would be another.
John Cox
Posted: Sat May 27, 2006 8:58 am Post subject: N519RV did two very short first Flights today. |
The dynon is the same way on the tack, I think. You need to set it to the
number of pulses per revolution. It also depends on where you are getting
the tach information. We are on the p-leads and had to set it to match.
Nobody that we talked to knew what the setting should be, so we used the
lasar tach and changed the Dynon until it matched and then we had it.
The main thing to remember with the Dynon is that there are different probes
that put out different signals for different functions, and until you have
the right info in the settings, you won't be displaying correct information.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
352-465-4545
dmasys(at)cox.net Guest
Posted: Sat May 27, 2006 11:45 am Post subject: N519RV did two very short first Flights today. |
I have heard of a similar problem occuring when the gasket for the prop governor was installed in the wrong position, and it blocked oil from getting to the governor. The prop governor is basicly an oil pump and when it's own oil supply is altered strange things happen.
-Dan Masys
#40448
| Quote: | From: owner-rv10-list-server(at)matronics.com
[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Doerr, Ray R
[NTK]
Sent: Friday, May 26, 2006 9:23 PM
Subject: N519RV did two very short first Flights today.
engine was only running at 2100RPM with MP at 28". The prop is able
to
Ray Doerr
40250
Posted: Sat May 27, 2006 12:22 pm Post subject: N519RV did two very short first Flights today. |
Slight modification to previous post. The blockage caused by the incorrectly positioned gasket (or maybe it was the wrong gasket -- I think the builder used the gasket that came with the plate put on the pad by Lycoming, instead of the gasket provided with the governor) and the *return* oil passage of the governor was blocked, and so it sent max pressure oil to the prop regardless of linkage position and drove the blades into cruise rather than climb (flat) pitch.
Hope this helps,
-Dan Masys
---- Dan Masys <dmasys(at)cox.net> wrote:
-Dan Masys
#40448
> [NTK]
> To: rv10-list(at)matronics.com
> to
> Thanks
> Ray Doerr
> 40250
Posted: Sat May 27, 2006 8:27 pm Post subject: N519RV did two very short first Flights today. |
Guys, thanks for all the ideas. This is one awesome group of
people coming together to help each other out in time of great stress.
I went out to the hanger this morning to try and solve my 2100
RPM max statis issue with the new info I had in had from the prop gov
and prop manual. But before I was about to change anything, I wanted a
second option from a separate source on Engine RPM. I borrowed a
optical tach sensor ($17 item from tower hobbies, same item used on R/C
Airplanes) and test the prop rpm at idle with the parking brake set. I
made sure the brake was going to hold the airplane back with at least
twice this RPM before I was about to jump out of the plane and stand in
front of the running prop. The tach sensor read 990 RPM while the Dynon
was reading 740. The Dynon manual states the setting should either be a
fact or 1/2 or 1/4 of the number of cylinders. Mine was set to 2, which
was incorrect for a 6 cyl engine. I set it to 3 and that went in the
wrong direction, so I set it to 1.5 and that was bang on (990 RPM).
Now here comes the math, with it set to 2 before and now at 1.5,
that's .5 less than the 1.5 that it is now set at. So it is now 1/3
less than before. So if you take the 740 RPM I was getting before and
multiply by 1.33, that is exactly 990. Bingo, this all adds up. So
when we were getting 2100 RPM before for takeoff, that was actually 2100
* 1.33 = 2800 RPM. So we were running the crap out of the engine. So
we were getting basically 28 squared. This would help explain some of
the engine oil high temps. This also explains the lack of climb
performance. With the engine running faster than 2700 RPM (recommended
Take Off RPM), the Prop was having to flatten the pitch to a point where
the thrust just wasn't there. This all proved out perfectly with
another test flight of 2 hours. She climbed at 1600 ft/min at 2200 lbs
at 100 knots. MUCH BETTER, can you see the smile on my face now?
Now on to the high oil temperature reading on the dynon. Just
for fun a changed the Dynon Oil Temp setting to sensor type 2 from 1 on
the ground with the oil at room temp. It read 75 regardless of it being
set to 1 or 2. So we fly it again and were still seeing 254 on the oil
temp, but that was as high as it got. Other flight through out the day
it was slowing coming down to 246. So then I decided to have the test
pilot set the Oil Temp Sensor type in flight from 1 to 2 and the temp
was indicating 23 degrees cooler on type 2. So I started surfing
Dynon's support site and found that I did in fact have the Type 1
sensor. So much for that thought. After digging a little more I found
a service bulletin about how the Type 1 Oil Temp probe is high by about
20 degrees. If you have a software version greater than 1.02, than this
issue was resolved. But since I have version 1.02, I had this 20 degree
error on the high side. So we left it at sensor type 2 until I get a
chance tomorrow to update the software with 1.02.01. So all of this
info means we were not running above the recommended oil temp of 245.
At 254 before the change, it was actually only 234 degree. 11 shy of
the max red line. Can you see my smile getting bigger.
Now my two test pilot were simply having fun running the plane
around at 70 - 75 % power with rich mixture to break in the engine. It
was burning 19.5 Gal/Hr at this rate. Greg (Joe's dad, ATP and examiner
for ATP's) is the other test pilot, and between the two of them they
were tag teaming the fly off hours. By the end of the day, we had 9.2
hours on the hobbs and I started the first oil change in prep for
tomorrows marathon. The outside air temp was 90 - 95 on the ground at
1040 MSL and at 7500 MSL it was 71 degrees. Greg's felt a slight sake
and different engine sound briefly on the last flight of the day and
then the cylinder temp coming down a fair amount. His thoughts so far
is that the rings may be finally seating in place. Does this sound
right? I also notice some light blue dust around some of the injectors.
The only blue I know is the dye in the 100LL fuel. Is this anything to
be concerned amount?
I will keep everyone posted on my progress from tomorrow.
Ray Doerr
40250
N519RV (I still can't belive it is no longer a project)
jjessen
Posted: Sun May 28, 2006 7:47 am Post subject: N519RV did two very short first Flights today. |
Ray, congratulations on getting your grin!
I think one of the lessons here for me is to not take off in the first place
if not seeing the correct RPM. You were either under powered or now it
seems over revving. The latter less serious, I conjecture, than the former,
but now that I know one can test the RPM with a $17 gadget to verify that
the electronics are correct, you can bet that will be one of my first steps,
no matter what the electronics are saying. Thanks so much for all the great
information. Taking the time to post this amongst all the excitement is
highly commendable and highly recommended for all of us to do.
One favor. I'm not that good at conceptualizing a math problem and need a
little help with your calculations. 0.5 is indeed 1/3 of 1.5. But, and
this is the conceptual thing that I'm having trouble with, if you're
original was 2 and you're down .5 from that original number, don't you then
figure what percentage that is from the original number? So .5 down from 2
means you are down 1/4, not 1/3? Again, I am horrible at these things, so
please forgive the dumb question.
Again, congratulations!
John Jessen
~328 Tailcone
deej(at)deej.net Guest
Posted: Sun May 28, 2006 8:24 am Post subject: N519RV did two very short first Flights today. |
| Quote: | --> <Ray.R.Doerr(at)sprint.com>
from a separate source on Engine RPM. I borrowed a optical tach sensor ($17
Airplanes) and test the prop rpm at idle with the parking brake set. I made
sure the brake was going to hold the airplane back with at least twice this
RPM before I was about to jump out of the plane and stand in front of the
running prop. The tach sensor read 990 RPM while the Dynon was reading 740.
A search on their website revealed the following:
<http://www2.towerhobbies.com/cgi-bin/WTI0095P?FVSEARCH=tach&FVPROFIL=++&search3=Go>
All of them say you must be within 12 inches of the prop. That is a
little scary, but what really scares me
is "I was about to jump out of the plane and stand in front of the
running prop".
Did you have anyone inside the plane at the controls when you did this?
Your statement is
phrased such that you did this alone, which makes the hairs stand up on
the back of my neck...
Could you have made this measurement from the back side of the prop?
Very glad to hear you worked out the issue, are safe, and that the
plane is going well.
-Dj
Posted: Sun May 28, 2006 1:55 pm Post subject: N519RV did two very short first Flights today. |
That's great to hear. Now, for everybody else out there who hasn't done
this yet, don't think your engine is messing up until you have first checked
out your instruments. The engine shop that tested the engine for N256H had
the tach set wrong and realized they took it as high as almost 3,000rpm
while thinking it wasn't giving them the 2,700 they were looking for. This
was not a Dynon, so other instruments have the same issues as well. Great
to hear about the probe too. I'll have to keep my eyes on all that when I
get N415EC flying in about a month, hopefully, with a Dynon FlightDek D180.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
Posted: Sun May 28, 2006 3:43 pm Post subject: N519RV did two very short first Flights today. |
Dj, Ray's not that crazy. He has 2 professional
pilots helping him with the flyoff, so I'm sure it was one
of them running the controls. I can't imagine getting out
of my running plane.
Dj Merrill wrote:
running prop".
Your statement is
-Dj
VHMUM(at)bigpond.com Guest
Posted: Sun May 28, 2006 4:45 pm Post subject: N519RV did two very short first Flights today. |
2 professional pilots that should have done a static test before first
flight!!!!! Common sense!!
Safety first!!!
Chris
armywrights(at)adelphia.n Guest
Posted: Sun May 28, 2006 6:03 pm Post subject: N519RV did two very short first Flights today. |
Ok, enough armchair quarterbacking. Ray, thanks for the update, keep the
info coming despite the peanut galleries.
Rob Wright
#392 QB Wings
Posted: Sun May 28, 2006 8:00 pm Post subject: N519RV did two very short first Flights today. |
N519RV update. We now have 16 of our 25 hours flown off. My
two test pilots are extremely impressed with the performance of the 260
HP RV-10. Some of there comments are "Short field performance is better
than a Cessna 182", "More cabin and leg room than a Bonanza and just as
fast or faster", "Acceleration is about 3/4 of a Pitt's S2B with the
same engine", "It's likely easier and more stable to fly than my RV-9".
I asked Greg (ATP pilot examiner) how many hours it would take
for a female student pilot (that he just did her check ride and passed)
to get use to the RV-10 to the point where he would sign her off. His
answer was 8 hours. That just goes to show how easy the RV-10 is to
fly.
I finished changing the oil today and everything ran great. I
should finally be able to fly my own plane this coming weekend once the
25 hours are flown off. I will post some of the stall numbers etc once
we finish up tomorrow. We are going to do weight testing up to 2900 lbs
tomorrow. Today Greg also did some spin testing today with it and said
it was a piece of cake to recover from. These boys are really putting
this bird through its paces and are more impressed with every test they
do.
Thank You
Ray Doerr
N519RV (Flying)
Posted: Sun May 28, 2006 8:14 pm Post subject: N519RV did two very short first Flights today. |
Another way to think of it from a math standpoint is this.
740 A
--- X ---
990 2
What we are trying to find is the relationship between 740 and 990 vs
something is to the value of 2. So (740 x 2)/990 is equal to 1.5.
Thank You
Ray Doerr
N519RV (Flying)
