d-m-hague(at)comcast.net Guest
Posted: Wed Nov 21, 2007 2:00 pm Post subject: Ultrastar fuel tanks |
Does anybody know what the capacity is of the original standard fuel
tank(s) on the Ultrastar?
-Dana
Never vote for a politician who has to borrow a gun to go duck hunting
Posted: Sun Nov 25, 2007 4:33 pm Post subject: Re: Ultrastar fuel tanks |
The capacity of the orginal US tanks was 1 3/4 gal.
I could not do much flying on the stock two each tanks. Got Little Mike at Kolb to send me a third which I mounted above the engine for my reserve tank. Gravity fed it into the two lower tanks. Worked great.
Later on Kolb had some 6 gal tanks made that would fit in the place of the two gokart tanks. That increased my fuel capacity to 7.75 gals.
_________________ John Hauck
Titus, Alabama |
Posted: Sun Nov 25, 2007 4:47 pm Post subject: Ultrastar fuel tanks |
At 07:33 PM 11/25/2007, John Hauck wrote:
two gokart tanks...
I likely will add a third tank as you describe... if it's 1.5 gallons then
the total will still be the legally allowed 5 gallons.
OTOH... do you know if Kolb still has the 6 gallon tank you describe? Was
the mounting the same, or does the cage need to be modified?
Had a beautiful flight today, if chilly... good weather like this is rare
this time of year in New England.
-Dana
If we wish to "restore" respect for the law, a good start would be to
pass only laws that people will respect.
Posted: Wed Nov 28, 2007 7:05 am Post subject: Re: Ultrastar fuel tanks |
The little gokart tank is 1.75 gal as indicated in my previous post.
Doubt very seriously Kolb has the old US 6 gal tanks.
The six gal tank mounted to the existing tank mount tabs.
Titus, Alabama |
Posted: Wed Nov 28, 2007 9:51 am Post subject: Ultrastar fuel tanks |
At 10:05 AM 11/28/2007, John Hauck wrote:
I'll give it a shot... I'm sure you're right that they don't have any more,
but like the little kart tanks, I doubt they used anything custom made so
somebody might remember where to get it. Anyway, one can hope.
-Dana
The man who would be fully employed should procure a ship or a woman, for
no two things produce more trouble" - Plautus 254-184 B.C.
Posted: Wed Nov 28, 2007 1:24 pm Post subject: Ultrastar fuel tanks |
Dana:
The 6 gal fuel tank for the US was custom made.
Rio Rancho, NM
Titus, Alabama |
Posted: Wed Nov 28, 2007 2:03 pm Post subject: Ultrastar fuel tanks |
At 04:23 PM 11/28/2007, John Hauck wrote:
| Quote: | The 6 gal fuel tank for the US was custom made.
Wow, that must've cost a bit considering the relatively low production
volume... but back then all the ultralight companies were pretty optimistic...
-Dana
They say that politics makes strange bedfellows.
Of course, the main reason they cuddle up is to screw somebody else.
Posted: Wed Nov 28, 2007 2:18 pm Post subject: Ultrastar fuel tanks |
production
optimistic...
| -Dana
Dana:
If Dennis Souder is monitoring the List he could fill you in on cost
back in 1984-85 to have those tanks blown.
I don't know of any other application the tank could have been used
for.
I remember securing the 6 gal tank in my US with 4 each really big
heavy duty nylon tie wraps. Worked great!
Rio Rancho, NM
Titus, Alabama |
jb92563
Joined: 23 Mar 2007 Posts: 314 Location: Southern California
Posted: Thu Nov 29, 2007 12:34 pm Post subject: Re: Ultrastar fuel tanks |
I am beginning to think that the fiberglass tank that sits in the cage behind the seat on my US is custom made.
Its a really great job who ever made it .....looks production and fits perfectly and snugly right near the CG and the carb is all downhill from the tank's pickup with a 24" run of fuel line via a low point fuel filter/water trap and the pump....can't imagine a better arrangement is even possible.
Just got a fuel sender unit to install and wire to my E1 digital engine monitor since I can't see the fuel level behind my seat.
It will show up on my instrument where the oil Pressure sensor would normally be and have a settable low fuel alarm.
Don't you just love digital instruments!
_________________ Ray
Moni MotorGlider
Schreder HP-11 Glider
Grob 109 Motorglider
Do Not Archive |
Posted: Thu Nov 29, 2007 3:43 pm Post subject: Ultrastar fuel tanks |
At 03:34 PM 11/29/2007, jb92563 wrote:
perfectly...
Do you have a picture you could post?
-Dana
Politicians and diapers have one thing in common. They should both be
changed regularly, and for the same reason.
jb92563
Posted: Thu Nov 29, 2007 9:33 pm Post subject: Re: Ultrastar fuel tanks |
Here are some pics of my fiberglass tank.
232.23 KB |
542 Time(s) |
1.24 MB |
547 Time(s) |
Moni MotorGlider
Do Not Archive |
Posted: Fri Nov 30, 2007 3:56 am Post subject: Ultrastar fuel tanks |
At 12:33 AM 11/30/2007, jb92563 wrote:
Thanks Ray,
That does look like it was nicely done. How does it attach to the
frame? If I change the tank or add an aux tank I'd rather not do any
welding on the frame.
Always interesting to see the differences... sometimes I think I'm the only
one without a nose fairing! Though yours is the only one I've seen besides
mine with the wing leading edge tubes extended outside of the center rib...
I have a tube that sleeves over them, that gets slipped into place joining
them together after the wings are unfolded. What are those rectangular
projections that look like "handles" on the main downtubes, just behind and
above the seat? Also, no fuel pump? And is that a crack in the engine
frame, just above the left rear mounting bolt, or just dirt?
-Dana
Celebrate Freedom... read a banned book.
jb92563
Posted: Fri Nov 30, 2007 7:19 am Post subject: Re: Ultrastar fuel tanks |
Those pictures are of the plane as I received it.....dirty.....but no cracks.
Those things that look like handles are handles.
I hang on to it, plus put my foot in front of the wheel when pull starting so I don't end up in the prop if the Kolb start rolling.
The glass tank inserts from the seat area(remove seat) and has molded in saddles on the bottom and top so it can ride on the frame cross members and is attached with hose clamps.
It is offset to the left side well clear of the control rods on the right side of the frame.
I also think its more than 5 gallons......perhaps 6.
I installed a different fuel filter....sump type and also put a pump on the engine bracket where you see those 2 holes.
Also missing from that pic is the short whindshield, my instruments and the 4" drum brakes I just got that I need to install.
I also need to zinc chromate a bunch of parts and do some painting.
But the poly fiber is all patched and ready to go.
Moni MotorGlider
Do Not Archive |
Posted: Fri Nov 30, 2007 12:25 pm Post subject: Ultrastar fuel tanks |
At 10:19 AM 11/30/2007, jb92563 wrote:
| Quote: | Those things that look like handles are handles.
I hang on to it, plus put my foot in front of the wheel when pull starting so I don't end up in the prop if the Kolb start rolling. |
After looking at some other pictures on the web (including the other pix of your plane on the Ultrastar yahoo group), it looks like many Ultrastars have a headrest there. On mine, the starter cord runs up and and through a pulley attached to the wing universal bolt, so I'm pulling down to start the engine. This way, I can start while standing right in front of the landing gear leg so it can't roll past me. I can also start it (though not easily given the condition of my shoulder) while sitting in the seat, which is nice.
Most likely I'll add a third 1.5 gallon auxiliary tank behind the seat, and keep the existing tanks, for the 5 gallon total. Possibly this one (easy to mount), or something similar:
http://fluids.flambeau.com/multipurpose_tanks/6.0_quart.html
-Dana
I'm as confused as a baby in a topless bar. [quote][b]
jb92563
Posted: Fri Nov 30, 2007 1:47 pm Post subject: Re: Ultrastar fuel tanks |
Dana,
Do you think you could do an in air restart with your pull starter?
Not sure how valuable this would be since once an engine has stopped in flight I don't think there is much chance of it running again and the time would be better spent concentrating on a landing spot rather than trying repeatedly to relight the engine.
I assume the engine would only stop from fuel starvation, seizure, or plug fouling and hence futile to attempt a restart.
I had considered that but turning the engine off to soar is the only reason I could think of to make restarting from the seat desirable.
Anyone have opinions about this?
Dana, I also wondered if you had brakes on yours?
Seeing that you fly from grass however it may not be necessary.
I have not seen an UltraStar headrest...is that what the "Handles" are for?.
Looks like a good tank with plenty of attachment options, but how are all the tanks plumbed together? T fittings or in series?
Moni MotorGlider
Do Not Archive |
Posted: Fri Nov 30, 2007 2:16 pm Post subject: Ultrastar fuel tanks |
At 04:47 PM 11/30/2007, jb92563 wrote:
| Quote: | Do you think you could do an in air restart with your pull starter?
I don't see why not, though I haven't tried it yet. I will, though, once I
get more confident in my spot landings.
| Quote: | Not sure how valuable this would be since once an engine has stopped in
Only with plenty of altitude!
It did quit on me once, just as I was flaring to land; the idle mixture
wasn't set right. I rolled off the runway, and restarted it from the seat
with one pull at about 1/4 throttle. Having a remote choke (I don't, now)
would make an in-air restart more likely.
| Quote: | I had considered that but turning the engine off to soar is the only
Yes, and I love doing that with my PPG, though I can't restart that in the
air. The ability to restart from the seat could be useful if I'm at
another airport and have to start in a tight spot on pavement; I wouldn't
want the plane to start rolling as I'm climbing in.
| Quote: | Dana, I also wondered if you had brakes on yours?
Yes, I do (and I don't fly from grass though I'd prefer to; the airport
owner doesn't allow takeoffs and landings from the grass). Mine are Free
Bird's Black Max disk brakes with Hegar heel cylinders. A very nice setup.
-Dana
Be wary of strong drink. It can make you shoot at tax collectors-- and miss.
KolbFlyerJim(at)aol.com Guest
Posted: Sat Dec 01, 2007 4:03 pm Post subject: Ultrastar fuel tanks |
Hi Dana
Just Fly your UltraStar
Its not rocket sience
Jim N2641M
Posted: Sat Dec 01, 2007 6:39 pm Post subject: Ultrastar fuel tanks |
At 06:41 PM 12/1/2007, KolbFlyerJim(at)aol.com wrote:
I _am_ flying it... I just want to fly it a little farther, airports aren't
too close together around here.
-Dana (rocket engineer)
New safety announcement from the Department of Homeland
Security: Securely duct tape shut any books you may own about civil
liberties or the U.S. Constitution.
undoctor(at)ptd.net Guest
Posted: Sun Dec 02, 2007 9:30 am Post subject: Ultrastar fuel tanks |
Dana,
If the attachment comes through you can see how the Exmark Turf Tracer 5 gal. tank fits nicely in gravity-feed position.
Dave Kulp
FireFly 098
106.15 KB |
521 Time(s) |
Posted: Sun Dec 02, 2007 9:47 am Post subject: Ultrastar fuel tanks |
Hi Dana,
I did a reply to the list with an attachment showing the Exmark fuel tank in my Ultrastar. Hope it helps. If it doesn't come through and you'd like to see it just email me and I'll send it off line.
I got a kick out of your response to the wisea$$ about "just fly it." Got curious as to what you actually do and found your info on Google. It may interest you to know that my bro is the same. If you go to the REM site at http://www.remassociates.com/ , expand the consultants tab in the nav column and click on Linwood Kulp, you can read about him. Maybe your paths have crossed.
Dave Kulp
