rparigor(at)suffolk.lib.n Guest
Posted: Tue Mar 14, 2006 3:49 pm Post subject: Fastest groundspeed seen in a Europa? |
Curious, what is the fastest groundspeed anyone has seen in a Europa for
at least a half hour?
At what altitude?
Ron Parigoris
M.Grass(at)comcast.net Guest
Posted: Tue Mar 14, 2006 4:33 pm Post subject: Fastest groundspeed seen in a Europa? |
Ron,
Isn't this absolute meaningless?
I would understand and think it would be meaningful to get max indicated
airspeed with what type (tri or mono) and what engine and at what pressure
altitude.
Just my thought about this.
Michael Grass
Posted: Tue Mar 14, 2006 6:07 pm Post subject: Fastest groundspeed seen in a Europa? |
Hello Michael
"Ron, Isn't this absolute meaningless?"
I am a balloonist. I have an interest machines that are pursuaded to take
advantage of the atmosphere moving from high pressure to a lower pressure.
There are many a balloonist that break the hundred per hour mark.
Just wondering if a Europa has broken the 300MPH mark.
To me that is not meaningless, it means that a Europa pilot maneuvered his
craft in position with a hundred MPH tailwind.
Right conditions (Jetstream), perhaps glider wings, oxygen and I don't
think that 400MPH is out the question.
Choosing to fly when in favorable conditions can and does play an
important role into ultimate speed of a aircraft. Choose a day to fly to
Florida from New York on the East side of a powerful high pressure area,
and return on the West side and see if that does not put a smile on ones
face, even if flying a slug.
Sincerely
Ron Parigoris
jthursby(at)tampabay.rr.c Guest
Posted: Tue Mar 14, 2006 7:42 pm Post subject: Fastest groundspeed seen in a Europa? |
Hi Ron,
I have seen 252 knots coming home from WA (at) 21,000.
Jim T.
BEBERRY(at)aol.com Guest
Posted: Wed Mar 15, 2006 12:57 am Post subject: Fastest groundspeed seen in a Europa? |
In a message dated 15/03/2006 00:34:18 GMT Standard Time,
M.Grass(at)comcast.net writes:
Ron,
altitude.
Agreed. Fastest speed would depend on altitude, temperature, wind
direction, type of engine, speed kit or not, weight of crew, passengers, fuel and
luggage and a host of other variables. My experience is mostly with military
aircraft and graphs to show indicated airspeed against fuel consumption are
basic to pilot's notes. There is no absolute equivalent in the GA or PFA world,
even allowing for different builds.
Patrick
NevEyre(at)aol.com Guest
Posted: Wed Mar 15, 2006 3:04 pm Post subject: Fastest groundspeed seen in a Europa? |
I claim the fastest ground speed for a Europa, just over the Ton, coming off
the Thelwall Viaduct, northbound on the M6 Motorway , sat on the Europa
trigear trailer !
Does that count ?
Nev.
hdwysong(at)gmail.com Guest
Posted: Wed Mar 15, 2006 3:14 pm Post subject: Fastest groundspeed seen in a Europa? |
... doesn't count unless you were riding in it, Nev. You can claim to
have the world's fastest high-speed taxi test of an UNMANNED Europa,
though.
trigear trailer !
Does that count ?
Nev.
rmrrick(at)aol.com Guest
Posted: Wed Mar 15, 2006 3:50 pm Post subject: Fastest groundspeed seen in a Europa? |
hdwysong(at)gmail.com wrote:
Quote: |
.... doesn't count unless you were riding in it, Nev. You can claim to
though.
>trigear trailer !
>Does that count ?
>Cheers,
>Nev.
Not bad behind a rusty old AVENGER!?
topglock(at)cox.net Guest
Posted: Wed Mar 15, 2006 4:11 pm Post subject: Fastest groundspeed seen in a Europa? |
Can't come anywhere close to that, but N55XS has seen 181 kts at 3,000
feet, in cruise...
Jeff - N55XS
Doing 150 hr check and adding a new Trio autopilot, while at it...
James wrote:
Hi Ron,
Jim T.
Trevpond(at)aol.com Guest
Posted: Thu Mar 16, 2006 3:56 am Post subject: Fastest groundspeed seen in a Europa? |
In a message dated 15/03/2006 23:04:45 GMT Standard Time, NevEyre(at)aol.com
writes:
off
trigear trailer !
Does that count ?
Nev.
Only if you weren't strapped on!!
Trev
hurstkr(at)growzone.com.a Guest
Posted: Thu Mar 16, 2006 4:47 am Post subject: Fastest groundspeed seen in a Europa? |
Quote: | I claim the fastest ground speed for a Europa, just over the Ton, coming
off
trigear trailer !
Sorry Nev but I don't believe you. You would not have enough room to get up
to the Ton in that country lest you would run off the edge !!
Hang on ! are you talking a Ton of Kilometres or a Ton of Miles ? If you
are talking K's, then you might just about be able to do it but you must
have had good brakes !
Your humble and obedient antipodean Cousin - obviously about to be sent to
the next colony.
Kingsley
Posted: Thu Mar 16, 2006 2:00 pm Post subject: Fastest groundspeed seen in a Europa? |
Hi Kingsly,
If you had ever been in my Workshop, you would know Metric is totally
forbidden !
I only use proper Imperial measurements, I can assure you it was miles per
hour.
The metric system was invented by ''cheese eating surrender monkeys'' They
are welcome to keep it to themselves.I am quite happy with ounces, pounds,
pints, gallons, inch, feet, yards and miles thank you very much.
God save the Queen.
Nev.
Gilles.Thesee(at)ac-greno Guest
Posted: Thu Mar 16, 2006 2:28 pm Post subject: Fastest groundspeed seen in a Europa? |
NevEyre(at)aol.com a crit :
Quote: | If you had ever been in my Workshop, you would know Metric is totally
forbidden !
hour.
God save the Queen.
Hey Nev,
Of course you installed some engine made in the colonies, Jab or Lyc,
with imperial nuts and bolts ?
I suggest you rename your plane "Britannia" )
Gilles Thesee
Grenoble, France
Just one of the 6 billion other metric monkeys...
http://contrails.free.fr
Posted: Thu Mar 16, 2006 3:30 pm Post subject: Fastest groundspeed seen in a Europa? |
In a message dated 16/03/2006 22:02:00 GMT Standard Time, NevEyre(at)aol.com
writes:
Hi Kingsly,
forbidden !
hour.
God save the Queen.
Nev.
Well said Nev..... why the hell should we be conned into accepting a French
Revolutionary method of mensuration ( have to be careful how I spell that!).
I do the same. Interesting that I have NEVER heard anyone boast abut how
many Km to the Ltr they get out of their car or aeroplane even amongst the Euro
enthusiasts.
Patrick
Posted: Thu Mar 16, 2006 4:01 pm Post subject: Fastest groundspeed seen in a Europa? |
Nev,
Hope you understood my accidental cynical remark. When I said you would
run off the edge, I meant the edge of the country not the edge of the
road ! <grin>
Shame on you Nev for not accepting the metric system however, I have to
admit you do have a point. I remember reading once why the French
always used the guillotine instead of the gallows, the reason being
there was no exact metric equivalent for the drop on the gallows so they
could never get it to work properly! Not sure if you knew this little
bit of trivia mate ?
You also remind me of a bloke we used to have here at work. He was
responsible for spraying noxious weeds. When he recorded the amount of
poison used, because he hated metric, he would write something like 2/3
of 3/4 of 1/2 a Cup. That was much simpler than saying 200ml or
whatever !!
Anyway, we can settle all this stuff next year 'cause I'm comin ova ta
say gidday. Hope you'll be around !
Best
Kingsley
PS I note you called me Kingsly - were you inferring something when you
dropped out the 'e' in the last four letters ??
Cheers
