Posted: Fri May 16, 2008 2:24 pm Post subject: Fuel Levels |
One problem with capacitive probes is that they are sensitive to the
composition of the fuel. You will get different reading with 100LL vs. car
gas. I suspect that different ethanol blends will give different readings
but I don't know how much. I recall being told by the instrument maker MGL
in South Africa that they don't use capacitive probes because the
composition of auto gas there is inconsistent enough to cause significant
errors.
-- Craig
| - The Matronics Zenith701801-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
ashontz
![](images/avatars/111614990045dc5e59095ab.jpg)
Posted: Wed May 28, 2008 12:13 pm Post subject: Re: Fuel Levels |
This would explain why I ran out of gas, for the first time in 13 years, in my pickup truck a few months ago. The gauge works and was reading a little less than 1/4 tank.
craig(at)craigandjean.com wrote: | One problem with capacitive probes is that they are sensitive to the
errors.
-- Craig
SafeAirOne
Joined: 18 May 2008 Posts: 17 Location: Manchester, NH
Posted: Thu May 29, 2008 6:15 pm Post subject: Re: Fuel Levels |
ashontz wrote: | This would explain why I ran out of gas, for the first time in 13 years, in my pickup truck a few months ago. The gauge works and was reading a little less than 1/4 tank. |
You have a capacitance fuel sender in your pickup? Most are simple float-types...
-Mark
ashontz
Posted: Fri May 30, 2008 4:31 am Post subject: Re: Fuel Levels |
I've never seen the sender in my '85 Nissan, but I'm guessing it's capacitance due to the fact that my 91 suburban obviously has a float because the needle jumps around all over the place when I make a turn and the fuel sloshes around. The pickup truck doesn't do that, it takes it's good old time coming up to level after I fill it up at the gas station. It acts like it's a capacitance type sender.
Interesting concept though that an ethanol blend would change the characteristics of the sender signal. Good argument for a float type sender.
SafeAirOne wrote: | ashontz wrote: | This would explain why I ran out of gas, for the first time in 13 years, in my pickup truck a few months ago. The gauge works and was reading a little less than 1/4 tank. |
-Mark |
dougsnash
Posted: Fri May 30, 2008 5:19 am Post subject: Fuel Levels |
Andy, it has been my exprience that automotive senders
are almost exclusivly float type senders. I belive
the lag time in the fuel readings is a function of lag
built into the gauge. My reasoning is that the
circuitry for the capacitance type sender would be
more complicated and therefor more expensive with
little added benifit. Automotive companies would not
spend the additional amount on something that is not
obvious.
Of course with an import vehicle, anything is
possible.
Doug MacDonald
CH-701 Scratch Builder
NW Ontario, Canada
