jeffrey_davidson(at)earth Guest
Posted: Mon Mar 26, 2007 4:34 pm Post subject: Jabiru fuel pressure sensor hookup |
It is amazing how little things can stop me cold. I'm installing the Dynon Engine Management System (EMS) in my 601 with a Jabiru 3300A (solid lifters). I'm installing the fuel flow sensor. The Dynon sensor has a 1/8 inch NPT male thread on it. I am using the Zenith supplied 1/4 Inch inside diameter ( I know about using 3/8ths) fuel hose. Has anyone found a fitting or set of fittings that has a female 1/8th NPT on one end and a hose barb on the other? Dynon has not replied so far. Thanks …
Jeff Davidson
| - The Matronics JabiruEngine-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
Jim McCormick
Posted: Mon Mar 26, 2007 5:18 pm Post subject: Jabiru fuel pressure sensor hookup |
Hi Jeff
So your looking for a 1/8 pipe female to a 1/4 or 3/8 male hose barb?
If you have a local hydraulic supply shop, they would most likely have a fitting like that.
If you can't find one let me know and I'll check with mine.
Thank you
Jim McCormick
Jabiru Pacific LLC
255 W Fallbrook 202B
Fresno, CA 93711
Office 559-431-1701
Fax 559-233-3676
www.jabirupacific.com [quote] --
rickpitcher
Posted: Mon Mar 26, 2007 6:48 pm Post subject: Jabiru fuel pressure sensor hookup |
NAPA had all the hose barbs/1/8 pipe that I needed when I did the fuel
system on my 601. There's a NAPA almost everywhere. You can go to their
website and enter your Zip Code to find the nearest store
www.napaonline.com/
Rick Pitcher
601HD/Jab3300
Peter H
Posted: Mon Mar 26, 2007 7:52 pm Post subject: Jabiru fuel pressure sensor hookup |
Jeff I got all sorts of fittings and some made up by the local hydraulics hose shop.
Peter H
From: owner-jabiruengine-list-server(at)matronics.com [mailto:owner-jabiruengine-list-server(at)matronics.com] On Behalf Of Jeff
Sent: Tuesday, 27 March 2007 10:34 AM
To: zenith-list(at)matronics.com; jabiruengine-list(at)matronics.com
Subject: Jabiru fuel pressure sensor hookup
Jeff Davidson
Quote: | http://www.matronics.com/Navigator?JabiruEngine-List | 01234
Posted: Mon Mar 26, 2007 7:54 pm Post subject: Jabiru fuel pressure sensor hookup |
Thanks to all that responded.
Jeff Davidson
